BK314-0300
BK314-0300
    BOWMAN
    BULK DISPENSER - QUAD - TALL
BK314-0300 数据手册
BK314-0300 Bulk Dispenser - Tall Quad Bin Product Description: • Bulk Dispenser - Tall Quad Bin • Holds a variety of protective apparel or other miscellaneous items in four compartments • Top loading, front dispensing • Hinged lid • Keyholes for wall mounting • Made of Stainless Steel Primary Area for Product Usage: • O.R. dressing areas, outside O.R. rooms, emergency rooms, operating rooms, labor and delivery, and burn units • Surgical areas, interventional radiology, areas with a scrub sink • Clean rooms, food service areas, or anywhere bulk items are needed Dispenses: • Fits miscellaneous bulk items in each compartment, up to 6.00″W x 15.80″H x 5.43″D (15.2 cm x 40.1 cm x 13.8 cm) Package Specifications: • Package Quantity: 1 per case • 30″L x 20″W x 9″H (76.2 cm x 50.8 cm x 22.9 cm) • 16.0 lbs (7.3 kg) - approximated Product Specifications (overall external dimensions): • 24.16″W x 17.91″H x 5.75″D (61.4 cm x 45.5 cm x 14.6 cm) • 12.7 lbs (5.7 kg) - approximated Alternative Products (each sold separately): • BK001-0300, Bulk Dispenser - Tall Single Bin (not pictured) • BK312-0300, Bulk Dispenser - Tall Double Bin • BK313-0300, Bulk Dispenser - Tall Triple Bin Mounting Specifications: 20.03 13.25 .67 .75 2.03 R.13 (2x) R.25 (2x) BK312-0300 Product Videos: BowmanDispensers.com/Product-Videos BK313-0300 R.13 (2x) BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com BK314-0300 Bulk Dispenser - Tall Quad Bin Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Product is loaded from the top, then can be dispensed through the top or bottom front. Care and Construction Stainless Steel Material Characteristics Designed for Long-Term Heavy-Duty Applications Stainless steel is used overwhelmingly for its corrosion and oxidation resistance characteristics. Along with being sturdy, stainless steel is also fire and heat resistant. The work-hardening properties of stainless steel gives the material a great strength-to-weight advantage over other materials. It also provides impact resistance and high toughness in extreme temperatures. 1 Stainless steel has a bright, stain resistant surface and pleasing aesthetic appearance. • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning Stainless steel resists a variety of common chemicals and cleaning agents. Clean using warm water, a gentle detergent, and soft cloth. Standard hospital cleaning supplies are approved for use on our stainless steel products. Dry thoroughly to avoid spotting. Do not use steel wool. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser BK314-0300 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2018 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. BK3140300TDSb
BK314-0300 价格&库存
很抱歉,暂时无法提供与“BK314-0300”相匹配的价格&库存,您可以联系我们找货
