BP-022
BP-022
    BOWMAN
    BULK DISPENSER - DOUBLE
BP-022 数据手册
BP-022 Bulk Dispenser - Double Bin Product Description: • Bulk Dispenser - Double Bin • Holds a variety of protective apparel or other miscellaneous items in bulk • Two compartments • Pivot hinge lid • Top loading, top or bottom front dispensing • Keyholes for wall mounting • Clear PETG Plastic Primary Area for Product Usage: • Anywhere bulk items are needed Dispenses: • Personal protection apparel or other miscellaneous items in bulk quantity Package Specifications: • Package Quantity: 1 per case • 14"W x 12"H x 9"D (35.6 cm x 30.5 cm x 22.9 cm) • 5.0 lbs (2.3kg) - approximated Product Specifications (overall external dimensions): • 12.27"W x 11.13"H x 5.78"D (31.2cm x 28.3cm x 14.7cm) • 2.4 lbs (1.1kg) - approximated Mounting Specifications: Related Products (each sold separately): • BP-021: Bulk Dispenser - Single Bin (shown below) • BP-023: Bulk Dispenser - Triple Bin 8.00 R.13 (2x) R.25 (2x) 7.00 2.00 .75 2.03 Ø .25 (2x) Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com BP-022 Bulk Dispenser - Double Bin Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Clear design allows full view of contents and supply level. • Product is loaded through the top and dispensed either through the top or bottom front. Care and Construction PETG Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications Copolyester resin is designed for heavy-duty applications, and is used by BOWMAN® Dispensers. We never use acrylic in our products. Copolyester (PETG) is typically 15-20 times tougher than general purpose acrylic. PETG is made to withstand handling and reduce losses due to breakage. PETG resists a variety of chemicals and commonly used cleaning agents. It is tough and durable (not brittle), providing years of trouble-free functionality and long life. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Clear optical characteristics mean the viewer can see the content, read text, and see true colors through the material. It complies with FDA regulations for food contact. Care and Cleaning Most cleaning chemicals do not weaken the surface or cause damage to the material. Suggested cleaning method is to use a soft cloth, warm water, and mild soap. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser BP-022 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. BP022TDSa
BP-022 价格&库存
很抱歉,暂时无法提供与“BP-022”相匹配的价格&库存,您可以联系我们找货
