CL006-0212
CL006-0212
    BOWMAN
    HAND AND NAIL BRUSH DISPENSER
CL006-0212 数据手册
CL006-0212 Scrub Brush Dispenser Product Description: • • • • Scrub Brush Dispenser Holds one box of scrub brushes Keyholes for wall mounting Quartz Beige ABS Plastic Primary Area for Product Usage: • Surgical/procedure areas • Any location where scrub brushes are needed Dispenses: • Box(es) no larger than 4.83"W x 20.00"H x 5.00"D (13.3 cm x 50.8 cm x 13.3 cm) • Box(es) no smaller than 4.08"W x 8.00"H x 4.25"D (12.1 cm x 20.3 cm x 12.7 cm) Package Specifications: • Package Quantity: 6 per case • 16"L x 12"W x 12"H (40.6 cm x 30.5 cm x 30.5 cm) • 5.0 lbs (2.3 kg) - approximated Product Specifications (overall external dimensions): • 5.08"W x 9.10"H x 5.33"D (12.9 cm x 23.1 cm x 13.5 cm) • 0.3 lbs (0.2 kg) - approximated Mounting Specifications: 2.73 Companion Products (each sold separately): R.13 (2x) R.25 (2x) FM100-0212: Face Mask Dispenser - Universal Boxed - Earloop FM200-0212: Face Mask Dispenser - Universal Boxed - Face Shield FM300-0212: Face Mask Dispenser - Universal Boxed - Cone PD100-0212: Protection Dispenser - Universal Boxed - Shoe Cover/ Cap/Other • PD200-0212: Protection Dispenser - Universal Boxed - Shoe Cover/ Cap/Other - Large • PD300-0212: Protection Dispenser - Universal Boxed - Shoe Cover/ Cap/Other 6.60 .75 • • • • FM200-0212 Product Videos: BowmanDispensers.com/Product-Videos PD100-0212 BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com CL006-0212 Scrub Brush Dispenser Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Wide, open front design allows for most box openings. • High sides hold tall boxes. Characteristics & Care ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. ABS is chemical, stress-crack resistant, dimensionally stable, and will hold up to long-term use. It possesses high strength and performance characteristics at a reasonable cost. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser CL006-0212 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. CL0060212TDSc
CL006-0212 价格&库存
很抱歉,暂时无法提供与“CL006-0212”相匹配的价格&库存,您可以联系我们找货
