CL011-0111
CL011-0111
    BOWMAN
    PERSONAL WIPE DISPENSER
CL011-0111 数据手册
CL011-0111 Personal Wipe Dispenser - Short Product Description: • • • • Personal Wipe Dispenser - Short Holds one pack of personal wipes Two-way keyholes for vertical or horizontal wall mounting Made of Clear PETG Plastic Primary Area for Product Usage: • Any location which requires any type of personal wipes at the point of use: bathrooms, laboratory, O.R., clinical areas, dental, veterinary, salons Dispenses: • One short, thin pack of personal wipes • Packages no larger than 4.25˝W x 7.00˝H x 1.25˝D (10.8 cm x 17.8 cm x 3.2 cm) Package Specifications: • Package Quantity: 12 per case • 12˝W x 10˝H x 9˝D (40.6 cm x 30.5 cm x 30.5 cm) • 5.0 lbs (2.3 kg) - approximated Product Specifications (overall external dimensions): • 4.45˝W x 6.10˝H x 1.45˝D (11.3 cm x 15.5 cm x 3.7 cm) • 0.3 lbs (0.1 kg) - approximated Mounting Specifications: Alternative Products (each sold separately): 1.50 R.13 (TYP.) R.25 (TYP.) 3.60 • CL012-0111, Personal Wipe Dispenser - Short-Thick • CL021-0111, Personal Wipe Dispenser - Tall • CL022-0111, Personal Wipe Dispenser - Tall-Thick .50 (TYP.) 2.23 CL012-0111 Product Videos: CL021-0111 BowmanDispensers.com/Product-Videos CL022-0111 BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com CL011-0111 Personal Wipe Dispenser - Short Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Clear design enables unobstructed view of package information. • Open front accommodates a wide variety of precut box openings. Care and Construction PETG Plastic Material Characteristics Designed for Long-Term Heavy-Duty Applications Copolyester resin is designed for heavy-duty applications, and is used by BOWMAN® Dispensers. We never use acrylic in our products. Copolyester (PETG) is typically 15-20 times tougher than general purpose acrylic. PETG is made to withstand handling and reduce losses due to breakage. PETG resists a variety of chemicals and commonly used cleaning agents. It is tough and durable (not brittle), providing years of trouble-free functionality and long life. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Clear optical characteristics mean the viewer can see the content, read text, and see true colors through the material. It complies with FDA regulations for food contact. Care and Cleaning Most cleaning chemicals do not weaken the surface or cause damage to the material. Suggested cleaning method is to use a soft cloth, warm water, and mild soap. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser CL011-0111 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2018 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. CL0110111TDSb
CL011-0111 价格&库存
很抱歉,暂时无法提供与“CL011-0111”相匹配的价格&库存,您可以联系我们找货
