ED-097
ED-097
    BOWMAN
    INFECTION PREVENTION STATION
ED-097 数据手册
ED-097 Infection Prevention System Product Description: • Infection Prevention System • Holds one to two boxes of facial tissues or one box of gloves, one hand sanitizer bottle, and one wet wipe canister • 11.00"W x 8.50"H MP-075 Sign Holder (included) • Keyholes for wall mounting, can sit on a counter, or mount to a Bowman® Floor Stand • Quartz Beige ABS Plastic and Clear PETG Plastic Primary Area for Product Usage: • Anywhere personal protective equipment is needed Dispenses: • Left: Bottles/canisters no larger than 3.75" (9.5 cm) in diameter • Middle: Box(es) no larger than 5.00"W x 10.00"H x 5.50"D (12.7 cm x 25.4 cm x 14.0 cm) • Right: Canisters/bottles up to 5.50" (14.0 cm) in diameter Package Specifications: • Package Quantity: 1 per case • 16"L x 12"W x 12"H (40.6 cm x 30.5 cm x 30.5 cm) • 5.0 lbs (2.3 kg) - approximated Product Specifications (overall external assembled dimensions): • 15.00"W x 20.28"H x 5.75"D (38.1 cm x 51.5 cm x 14.6 cm) • 1.8 lbs (0.8 kg) - approximated Alternative Uses: 12.00 • ED-097 shown below with gloves instead of tissues 1.50 R.13 (2x) 1.88 .75 R.25 (2x) .75 Mounting Specifications: Ø.25 Product Videos: BowmanDispensers.com/Product-Videos 8.63 BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ED-097 Infection Prevention System Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Attach sign holder using included barrel screws. • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Construction ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. ABS is chemical, stress-crack resistant, dimensionally stable, and will hold up to long-term use. It possesses high strength and performance characteristics at a reasonable cost. Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. 1 Standard hospital cleaning supplies are approved for use on our ABS plastic products. • System can also be mounted to a BOWMAN Floor Stand (sold separately) as shown below. • Load with product only AFTER dispenser is secured. PETG Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications Copolyester resin is designed for heavy-duty applications, and is used by BOWMAN® Dispensers. We never use acrylic in our products. Copolyester (PETG) is typically 15-20 times tougher than general purpose acrylic. PETG is made to withstand handling and reduce losses due to breakage. PETG resists a variety of chemicals and commonly used cleaning agents. It is tough and durable (not brittle), providing years of trouble-free functionality and long life. 2 Clear optical characteristics mean the viewer can see the content, read text, and see true colors through the material. It complies with FDA regulations for food contact. Care and Cleaning Parts included: • Dispenser • Barrel Screws (2x Sets) • Sign Holder • Infection Prevention signage Tools Required: • No tools required to assemble dispenser ED-097 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) Most cleaning chemicals do not weaken the surface or cause damage to the material. Suggested cleaning method is to use a soft cloth, warm water, and mild soap. BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2020 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. ED097TDSb
ED-097 价格&库存
很抱歉,暂时无法提供与“ED-097”相匹配的价格&库存,您可以联系我们找货
