ED-760
ED-760
    BOWMAN
    EPINEPHRINE INJECTOR DISPENSER -
ED-760 数据手册
ED-760 Epinephrine Injector Dispenser - 10 Product Description: • • • • • • Epinephrine Injector Dispenser - 10 Holds up to 10 Epinephrine injectors Dual-sided clear PETG plastic divider for identification signage Tabs on front for lock placement Keyholes for wall mounting Yellow Sintra Plastic and Clear PETG Plastic Primary Area for Product Usage: • Anywhere Epinephrine injector organizers are needed Dispenses: • Epinephrine auto injectors for anaphylactic emergencies (injectors not included) Package Specifications: • Package Quantity: 1 per case • 16"W x 12"H x 12"D (40.6 cm x 30.5 cm x 30.5 cm) • 5 lbs (2.3 kg) - approximated Product Specifications (overall external dimensions): • 9.49"W x 11.19"H x 4.65"D (24.1 cm x 28.4 cm x 11.8 cm) • 2.4 lbs (1.1 kg) - approximated Mounting Specifications: R.13 (2x) 1.37 1.25 6.00 Related Products (each sold separately): .75 • ED-750: Epinephrine Injector Dispenser - 5 (shown below) 8.75 R.25 (2x) Ø.25 4.37 Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ED-760 Epinephrine Injector Dispenser - 10 Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Interior divider holds signage to indicate each recipient’s information. • Includes a cutout in the back for hand carrying. Care and Construction Sintra® Plastic Material Characteristics Designed for Long-Term Applications Sintra® plastic is a lightweight, yet rigid, board of moderately expanded closed-cell polyvinyl chloride (PVC). It is dent resistant and provides an excellent combination of rigidity and durability. Sintra® has a high strength-to-weight ratio and offers excellent corrosion, dent, and scratch resistance. It’s resistance to moisture makes it an excellent choice for locations prone to high humidity. Products constructed of Sintra® should not be located in areas subject to high temperatures (above 140° F). The surface of Sintra® has a low gloss, matte finish. Care and Cleaning Sintra® can be wiped clean with a mild cleaner or soap and lukewarm water. Isopropyl alcohol is recommended to remove grease or oil. Ammonia and acetone should not be used. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Standard hospital cleaning supplies are approved for use on our Sintra® products. PETG Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications Copolyester resin is designed for heavy-duty applications, and is used by BOWMAN® Dispensers. We never use acrylic in our products. Copolyester (PETG) is typically 15-20 times tougher than general purpose acrylic. PETG is made to withstand handling and reduce losses due to breakage. PETG resists a variety of chemicals and commonly used cleaning agents. It is tough and durable (not brittle), providing years of trouble-free functionality and long life. 2 Clear optical characteristics mean the viewer can see the content, read text, and see true colors through the material. It complies with FDA regulations for food contact. Parts included: Care and Cleaning • Dispenser Most cleaning chemicals do not weaken the surface or cause damage to the material. Suggested cleaning method is to use a soft cloth, warm water, and mild soap. Tools Required: • No tools required to assemble dispenser ED-760 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. ED760TDSa
ED-760 价格&库存
很抱歉,暂时无法提供与“ED-760”相匹配的价格&库存,您可以联系我们找货
