FB-063
FB-063
    BOWMAN
    FACE MASK DISPENSER - TIE
FB-063 数据手册
FB-063 Face Mask Dispenser - Tie Product Description: • • • • Face Mask Dispenser - Tie Style Holds one box of tie style face masks Two sets of keyholes for dual position wall mounting Made of White Powder-Coated Steel Primary Area for Product Usage: • Surgical areas, interventional radiology, areas with a scrub sink Dispenses: • Most major manufacturers’ standard tie style face mask boxes • Boxes no larger than 7.69”W x 9.50”H x 5.13”D (19.5 cm x 24.1 cm x 13.0 cm) • Boxes no smaller than 6.94”W x 5.50”H x 3.75”D (17.6 cm x 14.0 cm x 9.5 cm) Package Specifications: • Package Qty 12 per case • 18”W x 16”H x 10”D (45.7 cm x 40.6 cm x 25.4 cm) • 19.0 lbs (8.6 kg) - approximated Product Specifications (overall external dimensions): • 7.80”W x 7.50”H x 5.25”D (19.8 cm x 19.1 cm x 13.3 cm) • 1.4 lb (0.6 kg) - approximated Mounting Specifications: Related Products (each sold separately): R.13 (TYP.) R.25 (TYP.) 3.25 .75 • FB-021: Face Mask Dispenser - Tie Style (shown below) • FB-037: Face Mask Dispenser - Earloop Style • FB-090: Face Mask Dispenser - Shield Style 5.80 3.75 .75 1.00 1.00 Product Videos: BowmanDispensers.com/Product-Videos 5.80 BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com FB-063 Face Mask Dispenser - Tie Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Mountable in two directions, dispenser is designed for wall mounting or inside a cabinet. Care and Construction Powder-Coated Steel Material Characteristics Designed for Long-Term, Heavy-Duty Applications Our steel dispensers and stands are coated with polyester powders which makes them highly resistant to corrosion. Powder-coated steel is ideal for dispensers used in a healthcare or an industrial setting because it is impact resistant and is not effected by extremes in temperature. Dispensers and stands made of powder-coated steel are both attractive and functional, providing years of service. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning For best results, clean by washing the surface with a diluted solution of a mild, non-abrasive detergent in cold or warm water and a non-abrasive cloth. Standard hospital cleaning supplies can be used. 2 Dry with a soft cloth. Do not use any solvent-based materials, abrasives (e.g. Scotch-brite, steel wool), or apply excessive force during cleaning. Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser FB-063 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. FB063TDSa
FB-063 价格&库存
很抱歉,暂时无法提供与“FB-063”相匹配的价格&库存,您可以联系我们找货
