FM001-0212
FM001-0212
    BOWMAN
    FACE MASK DISPENSER - SURGICAL
FM001-0212 数据手册
FM001-0212 Surgical Face Mask Dispenser Product Description: • • • • • • Surgical Face Mask Dispenser Holds up to six boxes of face masks and/or face shields Hinged lid Optional 8.50˝ x 11.00˝ Sign Holders (MP-035) sold separately Keyholes for wall mounting or can be placed on countertop Made of Quartz Beige ABS Plastic Primary Area for Product Usage: • Surgical areas, interventional radiology, areas with a scrub sink Dispenses: Most major manufacturers’ standard surgical earloop/tie face masks and face shield boxes: • Left Section: Boxes no larger than 9.00"W x 10.00"H x 9.00"D (22.9 cm x 25.4 cm x 22.9 cm) • Middle and Right Sections: Boxes no larger than 8.25″W x 10.00″H x 9.00″D (21.0 cm x 25.4 cm x 22.9 cm) Package Specifications: • Package Quantity: 1 per case • 31"L x 15"W x 15"H (78.7 cm x 38.1 cm x 38.1 cm) • 12.0 lbs (5.4 kg) - approximated Product Specifications (overall external dimensions): • 26.50"W x 12.75"H x 10.62"D (67.3 cm x 32.4 cm x 27.0 cm) • 8.3 lbs (3.8 kg) - approximated Companion Products (each sold separately): • CL006-0212, Scrub Brush Dispenser • CL007-0212, Scrub Brush Dispenser - Large • FP-017, Face Mask Dispenser Mounting Specifications: 6.00 3.50 .50 R.13 (2x) R.25 (2x) 5.25 16.00 R.25 (2x) CL006-0212 Product Videos: CL007-0212 BowmanDispensers.com/Product-Videos FP-017 BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com FM001-0212 Surgical Face Mask Dispenser Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Hinged lid makes filling the compartments quick and easy. Characteristics & Care ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. ABS is chemical, stress-crack resistant, dimensionally stable, and will hold up to long-term use. It possesses high strength and performance characteristics at a reasonable cost. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. • Dispenser can also set on a countertop. Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser FM001-0212 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2018 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. FM0010212TDSb
FM001-0212 价格&库存
很抱歉,暂时无法提供与“FM001-0212”相匹配的价格&库存,您可以联系我们找货
