FM013-0212
FM013-0212
    BOWMAN
    FACE MASK DISPENSER - TRIPLE
FM013-0212 数据手册
FM013-0212 Face Mask Dispenser - Triple Product Description: • • • • Face Mask Dispenser - Triple Holds three boxes of earloop or tie masks Keyholes for wall mounting Quartz Beige ABS Plastic Primary Area for Product Usage: • Anywhere protective equipment products are needed Dispenses: • Box(es) no larger than 7.80"W x 8.50"H x 5.50"D (17.2 cm x 21.6 cm x 14.0 cm) • Box(es) no smaller than 6.75"W x 7.00"H x 4.13"D (10.9 cm x 17.8 cm x 10.5 cm) Package Specifications: • Package Quantity: 6 per case • 21"L x 17"W x 13"H (53.3 cm x 43.2 cm x 33.0 cm) • 9.0 lbs (4.1 kg) - approximated Product Specifications (overall external dimensions): • 8.01"W x 13.98"H x 5.83"D (20.3 cm x 35.5 cm x 14.8 cm) • 1.1 lbs (0.5 kg) - approximated Mounting Specifications: 4.01 Companion Products (each sold separately): 9.00 2.75 .75 (2x) • FM014-0212: Face Mask Dispenser - Quint (shown below) R.13 (4x) R.25 (2x) Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com FM013-0212 Face Mask Dispenser - Triple Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Mount securely to a wall with screws approved and supplied by building maintenance. Characteristics & Care ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. ABS is chemical, stress-crack resistant, dimensionally stable, and will hold up to long-term use. It possesses high strength and performance characteristics at a reasonable cost. 1 • Stack mask boxes so they dispense from the front of the dispenser. Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser FM013-0212 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. FM0130212TDSa
FM013-0212 价格&库存
很抱歉,暂时无法提供与“FM013-0212”相匹配的价格&库存,您可以联系我们找货
