FM404-0213
FM404-0213
    BOWMAN
    FACE MASK DISPENSER - LOCKING
FM404-0213 数据手册
FM404-0213 Face Mask Dispenser - Bulk - Locking - Short Product Description: • Face Mask Dispenser - Bulk - Locking - Short • Holds contents of two - three boxes of earloop or tie face masks or other items in bulk • Locking pivot hinge lid • Top loading, bottom dispensing • Supply level view slot • Keyholes for wall mounting • White ABS Plastic Primary Area for Product Usage: • Anywhere face masks are needed in large quantities Dispenses: • Standard earloop or tie face masks or miscellaneous items in bulk Product Specifications (overall external dimensions): • 8.38"W x 10.00"H x 4.43"D (21.3 cm x 25.4 cm x 11.3 cm) • 1.4 lbs (0.5 kg) - approximated Mounting Specifications: 2.00 4.00 1.40 R.13 (2x) R.25 (2x) Companion Products (sold separately): 7.00 .50 • FM404-0111: Face Mask Dispenser - Bulk - Locking - Short (shown below) Ø.25 (2x) Package Specifications: • Package Quantity: 6 per case - 20"W x 16"H x 12"D (50.8 cm x 40.6 cm x 30.5 cm) - 11.0 lbs (5.0 kg) - approximated • Package Quantity: 1 per case - 12"W x 10"H x 9"D (30.5 cm x 25.4 cm x 22.9 cm) - 4.0 lbs (1.8 kg) Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com FM404-0213 Face Mask Dispenser - Bulk - Locking - Short Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Supply level view slot enables tracking of contents and supply level. • Hingeless lid and bottom dispensing protects contents from dust and debris. Care and Construction ABS Plastic Material Characteristics Designed for Long-Term Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. ABS is chemical, stress-crack resistant, dimensionally stable, and will hold up to long-term use. It possesses high strength and performance characteristics at a reasonable cost. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. • Dispenser can also be mounted to one or both sides of the BOWMAN® Dual-Sided Floor Stand, KS022-0012, with VHB tape. (each purchased separately) Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 2 Parts included: • Dispenser • 2x keys Tools Required: • No tools required to assemble dispenser FM404-0213 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2021 BOWMAN® Dispensers, LLC. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. FM4040213TDSa
FM404-0213 价格&库存
很抱歉,暂时无法提供与“FM404-0213”相匹配的价格&库存,您可以联系我们找货
