GB-067
GB-067
    BOWMAN
    GLOVE BOX DISPENSER - DOUBLE - S
GB-067 数据手册
GB-067 Glove Box Dispenser - Space Saver - Double Product Description: • • • • Glove Box Dispenser - Space Saver - Double Holds two boxes of gloves Two-way keyholes for vertical or horizontal wall mounting White Powder-Coated Steel Primary Area for Product Usage: • Anywhere glove boxes are needed Dispenses: • Box(es) no larger than 5.25"W x 10.00"H x 3.75"D (13.3 cm x 25.4 cm x 9.5 cm) • Box(es) no smaller than 3.60"W x 9.00"H x 3.00"D (9.1 cm x 22.9 cm x 7.6 cm) Package Specifications: • Package Quantity: 4 per case • 24"L x 16"W x 6"H (61.0 cm x 40.6 cm x 15.2 cm) • 14.0 lbs (6.4 kg) - approximated Product Specifications (overall external dimensions): • 5.60"W x 20.04"H x 3.94"D (14.2 cm x 50.9 cm x 10.0 cm) • 2.5 lbs (1.1 kg) - approximated Mounting Specifications: Related Products (each sold separately): .85 1.37 Product Videos: BowmanDispensers.com/Product-Videos .50 (TYP.) R.13 (TYP.) R.25 (TYP.) 1.50 8.50 8.50 • GB-068: Glove Box Dispenser - Space Saver - Triple (shown below) BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com GB-067 Glove Box Dispenser - Space Saver - Double Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Vertical build and top load accommodate narrow space availability. Care and Construction Powder-Coated Steel Material Characteristics Designed for Long-Term Use Our steel dispensers and stands are coated with polyester powders which makes them highly resistant to corrosion. Powder-coated steel is ideal for dispensers used in a healthcare or an industrial setting because it is impact resistant and is not affected by extremes in temperature. Dispensers and stands made of powder-coated steel are both attractive and functional, providing years of service. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning For best results, clean by washing the surface with a diluted solution of a mild, non-abrasive detergent in cold or warm water and a non-abrasive cloth. Standard hospital cleaning supplies can be used. 2 Dry with a soft cloth. Do not use any solvent-based materials, abrasives (e.g. Scotch-brite, steel wool), or apply excessive force during cleaning. Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser GB-067 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. GB067TDSa
GB-067 价格&库存
很抱歉,暂时无法提供与“GB-067”相匹配的价格&库存,您可以联系我们找货
