GL008-0420
GL008-0420
    BOWMAN
    GLOVE BOX DISPENSER - SINGLE
GL008-0420 数据手册
GL008-0420 Glove Box Dispenser - Single Product Description: • • • • • Glove Box Dispenser - Single Holds one box of gloves Flexible spring pushes smaller boxes forward for secure fit Three-way keyholes for vertical or horizontal wall mounting Black Powder-Coated Steel Primary Area for Product Usage: • Anywhere gloves are needed Dispenses: • Box(es) no larger than 5.50"W x 10.00"H x 3.74"D (14.0 cm x 25.4 cm x 9.5 cm) • Box(es) no smaller than 3.60"W x 8.50"H x 3.00"D (9.1 cm x 21.6 cm x 7.6 cm)   Product Specifications (overall external dimensions): • 5.60"W x 9.96"H x 3.80"D (14.2 cm x 25.3 cm x 9.7 cm) • 1.4 lbs (0.6 kg) - approximated Mounting Specifications: .50 (2x) .50 (2x) 1.38 2.80 • GL028-0420: Glove Box Dispenser - Double (shown below) • GL038-0420: Glove Box Dispenser - Triple • GL048-0420: Glove Box Dispenser - Quad 7.00 Related Products (each sold separately): R.25 (TYP.) R.13 (TYP.) Package Specifications: • Package Quantity: 12 per case - 18"W x 16"H x 10"D (45.7 cm x 40.6 cm x 25.4 cm)  - 18.0 lbs (9.1 kg) - approximated • Package Quantity: 1 per case - 12"W x 10"H x 9"D (30.5 cm x 25.4 cm x 22.9 cm)  - 3.0 lbs (1.4 kg) - approximated Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com GL008-0420 Glove Box Dispenser - Single Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Flexible spring in back pushes box forward and holds securely even as supply level decreases. Care and Construction Powder-Coated Steel Material Characteristics Designed for Long-Term, Heavy-Duty Applications Dispensers and stands made of powder-coated steel are both attractive and functional, providing years of service. Our powder-coated steel dispensers and stands provide long-lasting products that hold up well in tough environments. Powder-coated steel is ideal for dispensers used in a healthcare or an industrial setting. It is impact resistant and is not effected by extremes in temperature. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning The powder-coated finish resists common chemicals and cleaning agents and can be easily wiped clean with soap and water. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser GL008-0420 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2021 BOWMAN® Dispensers, LLC. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. GL0080420TDSa
GL008-0420 价格&库存
很抱歉,暂时无法提供与“GL008-0420”相匹配的价格&库存,您可以联系我们找货
