GL020-0212
GL020-0212
    BOWMAN
    GLOVE BOX DISPENSER - DOUBLE - D
GL020-0212 数据手册
GL020-0212 Glove Box Dispenser - Double with Divider Product Description: • • • • Glove Box Dispenser - Double with Divider Holds two boxes of gloves Three-way keyholes for vertical or horizontal wall mounting Quartz Beige ABS Plastic Primary Area for Product Usage: • Anywhere gloves are needed Dispenses: • Box(es) no larger than 5.50"W x 10.00"H x 3.75"D (14.0 cm x 25.4 cm x 9.5 cm) • Box(es) no smaller than 4.50"W x 9.00"H x 3.00"D (11.4 cm x 22.9 cm x 7.6 cm) Package Specifications: • Package Quantity: 6 per case • 16"L x 12"W x 12"H (40.6 cm x 30.5 cm x 30.5 cm) • 9.0 lbs (4.1 kg) - approximated Product Specifications (overall external dimensions): • 11.38"W x 10.13"H x 4.00"D (28.9 cm x 25.7 cm x 10.2 cm) • 1.2 lbs (0.5 kg) - approximated Mounting Specifications: Related Products (each sold separately): .50 (TYP.) .13 (TYP.) .25 (TYP.) 7.50 .50 (TYP.) • GL020-0111: Glove Box Dispenser - Double, PETG Plastic (shown below) 9.38 Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com GL020-0212 Glove Box Dispenser - Double with Divider Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Divider holds boxes separately and enables easy reloading even when mounted vertically. Care and Construction ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. ABS is chemical, stress-crack resistant, dimensionally stable, and will hold up to long-term use. It possesses high strength and performance characteristics at a reasonable cost. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser GL020-0212 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. GL0200212TDSb
GL020-0212 价格&库存
很抱歉,暂时无法提供与“GL020-0212”相匹配的价格&库存,您可以联系我们找货
