GL045-0212
GL045-0212
    BOWMAN
    GLOVE BOX DISPENSER - QUAD - VIS
GL045-0212 数据手册
GL045-0212 Glove Box Dispenser - Quad - Visual Size Indicators Product Description: • • • • • Glove Box Dispenser - Quad - Visual Size Indicators Holds four boxes of gloves Incremental cutouts to easily identify different sized gloves Two-way keyholes for vertical or horizontal wall mounting Quartz Beige ABS Plastic Primary Area for Product Usage: • Anywhere gloves are needed Dispenses: • Box(es) no larger than 5.50"W x 10.00"H x 3.75"D (14.0 cm x 25.4 cm x 9.5 cm) • Box(es) no smaller than 4.50"W x 9.00"H x 3.00"D (11.4 cm x 22.9 cm x 7.6 cm) Package Specifications: • Package Quantity: 4 per case • 26"L x 11"W x 8"H (66.0 cm x 27.9 cm x 20.3 cm) • 8.0 lbs (3.6 kg) - approximated Product Specifications (overall external dimensions): • 22.50"W x 10.10"H x 3.95"D (57.2 cm x 25.7 cm x 10.0 cm) • 1.4 lbs (0.6 kg) - approximated Mounting Specifications: Related Products (each sold separately): • GL035-0212: Glove Box Dispenser - Triple - Visual Size Indicators (shown below) 20.50 7.00 1.31 .50 (TYP.) 1.00 R.13 (TYP.) R.25 (4x) Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com GL045-0212 Glove Box Dispenser - Quad - Visual Opening Size Indicators Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Distinct size cutout variations help users identify glove sizes quickly. Care and Construction ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. ABS is chemical, stress-crack resistant, dimensionally stable, and will hold up to long-term use. It possesses high strength and performance characteristics at a reasonable cost. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser GL045-0212 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2020 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. GL0450212TDSa
GL045-0212 价格&库存
很抱歉,暂时无法提供与“GL045-0212”相匹配的价格&库存,您可以联系我们找货
