GL500-0212
GL500-0212
    BOWMAN
    GLOVE BOX DISPENSER - QUINT
GL500-0212 数据手册
GL500-0212 Glove Box Dispenser - Quint Dispensers Product Description: • Glove Box Dispenser - Quint • Holds five boxes of gloves • Keyholes for wall mounting or cut out for use with BOWMAN door or wall hanger • Quartz Beige ABS Plastic Primary Area for Product Usage: • Anywhere personal protection equipment is needed Dispenses: • Left: Box(es) no larger than 5.50"W x 10.00"H x 4.55"D (14.0 cm x 25.4 cm x 11.6 cm) • Right: Box(es) no larger than 5.63"W x 10.00"H x 4.55"D (14.3 cm x 25.4 cm x 11.6 cm) Package Specifications: • Package Quantity: 1 per case • 24"L x 16"W x 6"H (53.3 cm x 35.6 cm x 25.4 cm) • 5.0 lbs (3.2 kg) - approximated Product Specifications (overall external dimensions): • 15.81"W x 20.30"H x 4.00"D (43.1 cm x 25.9 cm x 12.1 cm) • 2.9 lbs (1.0 kg) - approximated Mounting Specifications: 1.68 12.00 R.13 (2x) R.25 (2x) 15.00 .50 • Door/Wall Hangers: HH004-0412, MB-500, MB-510, MB-600 (below left), MB-601 • FM014-0212: Face Mask Dispenser - Quint (below right) 3.25 Companion Products (each sold separately): Ø.26 (2x) Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com GL500-0212 Glove Box Dispenser - Quint Installation Instructions/Characteristics & Care Dispensers Installation Always mount dispensers securely prior to loading with product. • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Construction ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. ABS is chemical and stress-crack resistant. It is tough, dimensionally stable, and will hold up to long-term use. It possesses high strength and performance characteristics at a reasonable cost. 1 • Dispenser may be mounted on a BOWMAN door or wall hanger through a cutout in the back. • Mount the hanger first (MB-600 Door Hanger illustrated below), then hang the empty dispenser through the cutout in the back. • Load product. Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 2 Parts included: • Dispenser • 4x Rubber Bumpers Tools Required: • No tools required to assemble dispenser GL500-0212 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2020 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. GL5000212TDSa
GL500-0212 价格&库存
很抱歉,暂时无法提供与“GL500-0212”相匹配的价格&库存,您可以联系我们找货
