GP-107
GP-107
    BOWMAN
    GLOVE BOX DISPENSER - TRIPLE - S
GP-107 数据手册
GP-107 Glove Box Dispenser - Triple - Space Saver Product Description: • • • • Glove Box Dispenser - Triple - Space Saver Holds three boxes of gloves that fit end-to-end Two-way keyholes for vertical or horizontal wall mounting Clear PETG Plastic Primary Area for Product Usage: • Anywhere gloves are needed Dispenses: • Box(es) no larger than 5.25"W x 10.00"H x 3.75"D (13.4 cm x 25.4 cm x 9.5 cm) • Box(es) no smaller than 4.50"W x 9.00"H x 3.00"D (11.4 cm x 22.9 cm x 7.6 cm) Package Specifications: • Package Quantity: 4 per case • 30"W x 14"H x 5"D (76.2 cm x 35.6 cm x 12.7 cm) • 11.0 lbs (5.0 kg) - approximated Product Specifications (overall external dimensions) : • 5.50"W x 30.11"H x 3.94"D (14.0 cm x 76.5 cm x 10.0 cm) • 1.95 lbs (0.9 kg) - approximated Mounting Specifications: .90 3.70 .50 (2x) Related Products (each sold separately): Product Videos: BowmanDispensers.com/Product-Videos .50 (TYP.) 13.50 13.50 1.61 • GP-106: Glove Box Dispenser - Double - Space Saver (shown below) R.13 (TYP.) R.25(6x) BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com GP-107 Glove Box Dispenser - Triple - Space Saver Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Vertical build and top load accommodate narrow space availability. Care and Construction PETG Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications Copolyester resin is designed for heavy-duty applications, and is used by BOWMAN® Dispensers. We never use acrylic in our products. Copolyester (PETG) is typically 15-20 times tougher than general purpose acrylic. PETG is made to withstand handling and reduce losses due to breakage. PETG resists a variety of chemicals and commonly used cleaning agents. It is tough and durable (not brittle), providing years of trouble-free functionality and long life. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Clear optical characteristics mean the viewer can see the content, read text, and see true colors through the material. It complies with FDA regulations for food contact. Care and Cleaning Most cleaning chemicals do not weaken the surface or cause damage to the material. Suggested cleaning method is to use a soft cloth, warm water, and mild soap. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser GP-107 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. PartNumberTDSa
GP-107 价格&库存
很抱歉,暂时无法提供与“GP-107”相匹配的价格&库存,您可以联系我们找货
