GS-004
GS-004
    BOWMAN
    GLOVE BOX DISPENSER - SINGLE
GS-004 数据手册
GS-004 Glove Box Dispenser - Single with Flexible Spring Product Description: • • • • Glove Box Dispenser - Single with Flexible Spring Holds one box of gloves Two-way keyholes for vertical or horizontal wall mounting Stainless Steel Primary Area for Product Usage: • Anywhere glove boxes are needed Dispenses: • Box(es) no larger than 5.51"W x 11.00"H x 3.74"D (14.0 cm x 25.4 cm x 9.5 cm) • Box(es) no smaller than 3.75"W x 8.00"H x 2.80"D (14.0 cm x 25.4 cm x 9.5 cm)   Package Specifications: • Package Quantity: 12 per case • 18"W x 16"H x 10"D (45.7 cm x 40.6 cm x 25.4 cm) • 23.0 lbs (10.4 kg) - approximated Product Specifications (overall external dimensions): • 5.60"W x 9.96"H x 3.80"D (14.2 cm x 25.3 cm x 9.7 cm)   • 1.4 lbs (0.6 kg) - approximated  1.38 Mounting Specifications: 2.80 .50 (TYP.) Related Products (each sold separately): 7.00 • GS-005: Glove Box Dispenser - Double(shown below) • GS-006: Glove Box Dispenser - Triple • GS-060: Glove Box Dispenser - Quad R.13 (TYP.) R.25 (2x) Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com GS-004 Glove Box Dispenser - Single with Flexible Spring Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Built-in, flexible spring in back pushes boxes forward for a secure fit. Care and Construction Stainless Steel Material Characteristics Designed for Long-Term, Heavy-Duty Applications By its nature, stainless steel is resistant to corrosion and oxidation, yet the bright, easily maintained surface provides a modern and attractive appearance. Stainless steel is used overwhelmingly for its corrosion resistance characteristics. Along with being sturdy, stainless steel is also fire and heat resistant. Stainless steel has work-hardening properties, giving the material a great strength-to-weight advantage over other materials. It also provides impact resistance and high toughness in extreme temperatures. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning Stainless steel resists a variety of common chemicals and cleaning agents. Clean using warm water, a gentle detergent, and soft cloth. Dry thoroughly to avoid spotting. Do not use steel wool. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser GS-004 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2020 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included.GS004TDSa GS004TDSb
GS-004 价格&库存
很抱歉,暂时无法提供与“GS-004”相匹配的价格&库存,您可以联系我们找货
