GS-060
GS-060
    BOWMAN
    GLOVE BOX DISPENSER - QUAD
GS-060 数据手册
GS-060 Glove Box Dispenser - Quad Product Description: • • • • Glove Box Dispenser - Quad Holds four boxes of gloves Three-way keyholes for vertical or horizontal wall mounting Stainless Steel Primary Area for Product Usage: • Anywhere gloves are needed Dispenses: • Boxes no larger than 5.25"W x 11.00"H x 3.75"D (13.3 cm x 27.9 cm x 9.5 cm) • Boxes no smaller than 4.25"W x 8.00"H x 2.80"D (10.8 cm x 10.8 cm x 7.1 cm) Package Specifications: • Package Quantity: 4 per case • 26"W x 11"H x 8"D (66.0 cm x 27.9 cm x 20.3 cm) • 14.0 lbs (6.4 kg) - approximated Product Specifications (overall external dimensions): • 22.32"W x 9.99"H x 3.81"D (56.7 cm x 25.4 cm x 9.7 cm) • 2.4 lbs (1.1 kg) - approximated Mounting Specifications: 1.72 18.82 .75 (TYP.) 6.49 • GS-004: Glove Box Dispenser - Single (shown below) • GS-005: Glove Box Dispenser - Double • GS-006: Glove Box Dispenser - Triple 2.35 Related Products (each sold separately): R.25 (4x) R.13 (TYP.) Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com GS-060 Glove Box Dispenser - Quad Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Open design will accommodate four same-size boxes or differing widths. Care and Construction Stainless Steel Material Characteristics Designed for Long-Term, Heavy-Duty Applications By its nature, stainless steel is resistant to corrosion and oxidation, yet the bright, easily maintained surface provides a modern and attractive appearance. Stainless steel is used overwhelmingly for its corrosion resistance characteristics. Along with being sturdy, stainless steel is also fire and heat resistant. Stainless steel has work-hardening properties, giving the material a great strength-to-weight advantage over other materials. It also provides impact resistance and high toughness in extreme temperatures. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning Stainless steel resists a variety of common chemicals and cleaning agents. Clean using warm water, a gentle detergent, and soft cloth. Dry thoroughly to avoid spotting. Do not use steel wool. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser GS-060 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. GS060TDSa
GS-060 价格&库存
很抱歉,暂时无法提供与“GS-060”相匹配的价格&库存,您可以联系我们找货
