GS-124
GS-124
    BOWMAN
    GLOVE BOX DISPENSER - QUAD - DIV
GS-124 数据手册
GS-124 Glove Dispenser - Quad with Dividers Product Description: • • • • Glove Box Dispenser - Quad with Dividers Holds four boxes of gloves Two-way keyholes for vertical or horizontal wall mounting Stainless steel Primary Area for Product Usage: • Anywhere gloves are needed Dispenses: • Box(es) no larger than 5.25"W x 10.00"H x 3.75"D (13.3 cm x 25.4 cm x 9.5 cm) • Box(es) no smaller than 4.50"W x 9.00"H x 2.75"D (11.4 cm x 22.9 cm x 7.0 cm) Package Specifications: • Package Quantity: 4 per case • 26"W x 11"H x 8"D (66.0 cm x 27.9 cm x 20.3 cm) • 13 lbs (5.9 kg) - approximated Product Specifications (overall external dimensions): • 21.16"W x 10.03"H x 3.81"D (53.7 cm x 25.5 cm x 9.7 cm) • 2.4 lbs (1.1 kg) - approximated Mounting Specifications: 19.16 .63 1.53 7.00 • GS-122 - Glove Dispenser - Double with Dividers • GS-123 - Glove Dispenser - Triple with Dividers (shown below) .75 (2x) .75 Related Products (each sold separately): R.25 (4x) R.13 (TYP.) Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com GS-124 Glove Dispenser - Quad with Dividers Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Dividers hold boxes separately for ease of loading and removing. Care and Construction Stainless Steel Material Characteristics Designed for Long-Term, Heavy-Duty Applications By its nature, stainless steel is resistant to corrosion and oxidation, yet the bright, easily maintained surface provides a modern and attractive appearance. Stainless steel is used overwhelmingly for its corrosion resistance characteristics. Along with being sturdy, stainless steel is also fire and heat resistant. Stainless steel has work-hardening properties, giving the material a great strength-to-weight advantage over other materials. It also provides impact resistance and high toughness in extreme temperatures 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning Stainless steel resists a variety of common chemicals and cleaning agents. Clean using warm water, a gentle detergent, and soft cloth. Dry thoroughly to avoid spotting. Do not use steel wool. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser GS-124 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included9 GS124TDSa
GS-124 价格&库存
很抱歉,暂时无法提供与“GS-124”相匹配的价格&库存,您可以联系我们找货
