HP-010
HP-010
    BOWMAN
    HAIRNET DISPENSER - BULK
HP-010 数据手册
HP-010 Hairnet Dispenser - Bulk Product Description: • • • • • • Hairnet Dispenser - Bulk Holds individually packaged hairnets in bulk quantity Top loading, bottom front dispensing Hingeless lid Keyholes for wall mounting, or sits on a counter Made of Clear PETG Plastic Primary Area for Product Usage: • Food service areas, such as kitchens, delis, food trucks, or anywhere hairnets are needed Dispenses: • Fits most brand name individually packaged hairnets, up to 4.25″W x 7.50″H x 3.50″D (10.8 cm x 19.1 cm x 8.9 cm) Package Specifications: • Package Quantity: 12 per case • 16″L x 12″W x 12″H (40.6 cm x 30.5 cm x 30.5 cm) • 10.0 lbs (4.5 kg) - approximated Product Specifications (overall external dimensions): • 4.46″W x 7.88″H x 3.68″D (11.3 cm x 20.0 cm x 9.3 cm) • 0.7 lbs (0.3 kg) - approximated Mounting Specifications: R.25 (2x) 4.06 • BP-011, Bulk Dispenser - Tall Single Bin (not pictured) • BP-012, Bulk Dispenser - Tall Double Bin • BP-090, Bulk Dispenser - Tall Triple Bin 2.23 2.39 R.13 (2x) .75 (2x) Alternative Products (each sold separately): BP-012 Product Videos: BowmanDispensers.com/Product-Videos BP-090 BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com HP-010 Hairnet Dispenser - Bulk Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Construction PETG Plastic Material Characteristics Designed for Long-Term Heavy-Duty Applications Copolyester resin is designed for heavy-duty applications, and is used by BOWMAN® Dispensers. We never use acrylic in our products. Copolyester (PETG) is typically 15-20 times tougher than general purpose acrylic. PETG is made to withstand handling and reduce losses due to breakage. PETG resists a variety of chemicals and commonly used cleaning agents. It is tough and durable (not brittle), providing years of trouble-free functionality and long life. 1 • To attach the lid, gently pry the front apart and insert as shown below. Clear optical characteristics mean the viewer can see the content, read text, and see true colors through the material. It complies with FDA regulations for food contact. Care and Cleaning Most cleaning chemicals do not weaken the surface or cause damage to the material. Suggested cleaning method is to use a soft cloth, warm water, and mild soap. 2 Parts included: • Dispenser & Lid Tools Required: • No tools required to assemble dispenser HP-010 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2018 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. HP010TDSc
HP-010 价格&库存
很抱歉,暂时无法提供与“HP-010”相匹配的价格&库存,您可以联系我们找货
