KS010-0412
KS010-0412
    BOWMAN
    FLOOR STAND
KS010-0412 数据手册
KS010-0412 Floor Stand Product Description: • Floor Stand • Accommodates a variety of BOWMAN® Respiratory Hygiene Stations • Column with square base and mounting top plate for companion product • Assembly hardware is included • Quartz Beige Powder-Coated Steel Primary Area for Product Usage: • Ports of entry: waiting rooms, lobbies, elevators • Medical offices or clinics Dispenses: • Accommodates a variety of BOWMAN® Hygiene Stations Package Specifications: • Package Quantity: 1 per case • 36″L x 20″W x 6″H (91.4 cm x 50.8 cm x 15.2 cm) • 20.0 lbs (9.1 kg) - approximated Product Specifications (overall external dimensions): • 17.00″W x 36.06″H x 17.00″D (43.2 cm x 91.6 cm x 43.2 cm) • 14.6 lbs (6.6 kg) - approximated Mounting Specifications: 17.00" 1.00" 36.06" • ED-097: Infection Prevention System • FD-068: Infection Prevention System • Any BOWMAN® Respiratory Hygiene Station 17.00" Companion Products (each sold separately): RS001-0512 and MP-075 on KS010-0412 Product Videos: BowmanDispensers.com/Product-Videos RS005-0512 and MP-075 on KS010-0412 BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com KS010-0412 Floor Stand Installation Instructions/Material Care & Construction Installation Always mount dispensers securely prior to loading with product. • To secure base to column, turn column upside down (with top plate down). • Place base inverted, as shown, on column. Care and Construction Powder-Coated Steel Material Characteristics Designed for Long-Term Use Our steel dispensers and stands are coated with polyester powders which makes them highly resistant to corrosion. Powder-coated steel is ideal for dispensers used in a healthcare or an industrial setting because it is impact resistant and is not effected by extremes in temperature. Dispensers and stands made of powder-coated steel are both attractive and functional, providing years of service. 1 • Use Phillips screwdriver to secure base to column with (4x) screws (10-32 x 5/16”). • Turn stand right side up, so the base is on the floor. Care and Cleaning For best results, clean by washing the surface with a diluted solution of a mild, non-abrasive detergent in cold or warm water and a non-abrasive cloth. Standard hospital cleaning supplies can be used. Dry with a soft cloth. Do not use any solvent-based materials, abrasives (e.g. Scotch-brite, steel wool), or apply excessive force during cleaning. 2 Parts included: • Column • Base • Hardware • (8x) Screws: (4x) for stand, (4x) included to attach companion product (Phillips type 10-32 x 5/16”) Tools Required: • Phillips screwdriver KS010-0412 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. KS0100412TDSd
KS010-0412 价格&库存
很抱歉,暂时无法提供与“KS010-0412”相匹配的价格&库存,您可以联系我们找货
