KS102-0029
KS102-0029
    BOWMAN
    HAND SANITIZER FLOOR STAND
KS102-0029 数据手册
KS102-0029* Hand Sanitizer Floor Stand Plus Product Description: • Hand Sanitizer Floor Stand • Standard back plate for use with hand sanitizer, hand lotion, or foam dispensers • No tools required to assemble • Self-righting base, up to 40 degrees past center without dispenser • Bay Gray Powder-Coated Metal back plate, column, and base • Quartz Beige ABS Plastic drip tray • Back plate and drip tray made in the USA • Column and base made in China Primary Area for Product Usage: • Anywhere hand sanitizing products are needed Package Specifications: • 20”L x 4”W x 20”H (50.8 cm x 10.2 cm x 50.8 cm) • 18.0 lbs (8.2 kg) - approximated Product Specifications (overall external dimensions) : • 18.00”W x 54.73”H x 18.00”D (45.7 cm x 139.0 cm x 45.7 cm) • 16.3 lbs (7.4 kg) - approximated Mounting Specifications: * Imported 9.00 7.35 Companion Products (each sold separately): 36.75 Ø18.00 Product Videos: BowmanDispensers.com/Product-Videos 18.00 • KS123-0529: Infection Prevention Station • SN003-0212: Sign Holder (shown below) BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com KS102-0029* Hand Sanitizer Floor Stand Plus Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • To secure base to column, place base on floor, line up threaded stud on base with threaded hole in pole. Turn pole clockwise until tight. • Screw the threaded hole of second pole section onto the stud in the top of the first section. Turn clockwise until tight. Bottom pole Base 1 Care and Construction Powder-Coated Steel Material Characteristics Designed for Long-Term, Heavy-Duty Applications Dispensers and stands made of powder coated steel are both attractive and functional, providing years of service. Our powder coated steel dispensers and stands provide long-lasting products that hold up well in tough environments. Powder coated steel is ideal for dispensers used in a healthcare or an industrial setting. It is impact resistant and is not effected by extremes in temperature. • Place hole in drip tray over stud from second pole section. • Holding back plate upright, screw onto threaded stud. • When attaching back plate, double check that drip tray is aligned with front of back plate as shown. • Turn drip tray and back plate together for last few turns to tighten. Care and Cleaning The powder coated finish resists common chemicals and cleaning agents and can be easily wiped clean with soap and water. 2 Parts included: • Base, Column and Back Plate Tools Required: • No tools required to assemble dispenser KS102-0029 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. KS1020029TDSb
KS102-0029 价格&库存
很抱歉,暂时无法提供与“KS102-0029”相匹配的价格&库存,您可以联系我们找货
