KS201-0029
KS201-0029
    BOWMAN
    FLOOR STAND
KS201-0029 数据手册
KS201-0029 Floor Stand Product Description: • • • • • • • Floor Stand Holds a variety of BOWMAN® Respiratory Hygiene Stations sold separately No tools required to assemble Self-righting base, up to 40 degrees past center without respiratory hygiene station Bay Gray powder-coated steel mounting plate, column, and base Mounting plate made in the USA Column and base made in China Primary Area for Product Usage: • Ports of entry, waiting rooms, lobbies, elevators • Medical offices or clinics Package Specifications: • 20”L x 6”W x 20”H (50.8 cm x 15.2 cm x 50.8 cm) • 18.0 lbs (8.2 kg) - approximated Product Specifications (overall external dimensions): • 18.00”W x 36.73”H x 18.00”D (45.7 cm x 93.3 cm x 45.7 cm) • 15.3 lbs (6.9 kg) - approximated Mounting Specifications: * Imported Related Products (each sold separately): • KS101-0029: Hand Sanitizer Floor Stand • KS102-0029: Hand Sanitizer Floor Stand with Drip Tray (shown below) 36 3/4" 18" Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com KS201-0029 Floor Stand Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • To secure base to column, place base on floor, line up threaded stud on base with threaded hole in pole. Turn pole clockwise until tight. • Screw the threaded hole of second pole section onto the stud in the top of the first section. Turn clockwise until tight. Bottom pole Base 1 Care and Construction Powder-Coated Steel Material Characteristics Designed for Long-Term, Heavy-Duty Applications Dispensers and stands made of powder coated steel are both attractive and functional, providing years of service. Our powder coated steel dispensers and stands provide long-lasting products that hold up well in tough environments. Powder coated steel is ideal for dispensers used in a healthcare or an industrial setting. It is impact resistant and is not effected by extremes in temperature. • Holding mounting plate level, screw the plate onto the threaded stud of the pole. Care and Cleaning The powder coated finish resists common chemicals and cleaning agents and can be easily wiped clean with soap and water. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser KS201-0029 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. KS2010029TDSa
KS201-0029 价格&库存
很抱歉,暂时无法提供与“KS201-0029”相匹配的价格&库存,您可以联系我们找货
