LD-070
LD-070
    BOWMAN
    PROTECTIVE WEAR ORGANIZER
LD-070 数据手册
LD-070 Protection System Product Description: • Protection System • Holds gowns, aprons, or coveralls/jumpsuits, three boxes of gloves, one box of earloop masks, and one box of shield masks • Keyholes for wall mounting or cutout for use with a BOWMAN® hanger • Quartz Beige ABS Plastic Primary Area for Product Usage: • Anywhere protective equipment products are needed Dispenses: • Top: Box(es) no larger than 5.00"W x 10.00"H x 4.30"D (12.7 cm x 25.4 cm x 10.9 cm) • Bottom left: Gowns, aprons or coveralls/jumpsuits no larger than 11.38"W x 15.30"H x 4.30"D (12.7 cm x 25.4 cm x 10.9 cm) • Middle right: Box(es) no larger than 8.39"W x 5.24"H x 4.50"D (21.3 cm x 13.3 cm x 11.4 cm) • Bottom right: Box(es) no larger than 8.39"W x 9.80"H x 4.50"D (21.3 cm x 24.9 cm x 11.4 cm) Package Specifications: • Package Quantity: 1 per case • 29"W x 6"H x 23"D (73.7 cm x 15.2 cm x 58.4 cm) • 10.0 lbs (4.5 kg) - approximated Product Specifications (overall external dimensions): • 20.05"W x 25.25"H x 4.75"D (50.9 cm x 64.1 cm x 12.1 cm) • 4.6 lbs (2.1 kg) - approximated Mounting Specifications: Accessories (each sold separately): 16.00 2.03 2.50 R.13 (2x) R.25 (2x) 11.25 .75 • Caddies MP-015 and MP-085 • Bowman Hangers HH004-0412, MB-450, MB-500, MB-510 and MB-600 (shown below) Ø.25 (2x) Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com LD-070 Protection System Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Construction ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. The fauxwood finish is ARVINYL laminate created from a semi-rigid film. ABS is chemical and stress-crack resistant. It is tough, dimensionally stable, and will hold up to long-term use. To ensure product longevity, fauxwood products should not be mounted in very hot or cold areas. 1 • Or hang on BOWMAN® hanger. (See chosen hanger’s datasheet for details.) Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser LD-070 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. LD070TDSb
LD-070 价格&库存
很抱歉,暂时无法提供与“LD-070”相匹配的价格&库存,您可以联系我们找货
