MB-500
MB-500
    BOWMAN
    HANGER - GLASS DOOR
MB-500 数据手册
MB-500 Door Hanger - Glass Product Description: • • • • • Hanger - Glass Door Holds BOWMAN® protection systems Very high bond double-sided tape for mounting to glass Keyholes for wall mounting Quartz Beige Powder-Coated Steel Primary Area for Product Usage: • Hangs on any glass door where a BOWMAN® protection organizer is needed Package Specifications: • Package Quantity: 12 per case • 24”W x 6”H x 6”D (61.0 cm x 15.2 cm x 15.2 cm) • 14.00 lbs (6.4 kg) - approximated Product Specifications (overall external dimensions): • 22.00”W x 4.62”H x 0.56”D (55.9 cm x 11.7 cm x 1.4 cm) • 1.0 lb (0.4 kg) - approximated Mounting Specifications: 3.00 16.00 R.13 (2x) R.25 (2x) .75 Related Products (each sold separately): • PS016-0512: Protection System (shown below) Proper Hanging Procedure: 1) Clean mounting surface using a mixture of 50:50 isopropyl alcohol and water prior to mounting the hanger. 2) Allow surface to dry completely. Remove the backing from all tape strips and press firmly to adhere tape to surface. 3) Allow adhesive a *minimum of 24 hours to set prior to mounting BOWMAN® Dispenser to the hanger. (*Tape is fully cured after 72 hours.) 4) Hang empty BOWMAN® Protection System on hanger. 5) Load consumables. 6) The hanger is rated to hold a maximum of 25 lbs. when mounted to glass or laminated wood. Not recommended for use on other surfaces. 7) Removal of product is not advised as damage to surface could occur. Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com MB-500 Door Hanger - Glass Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Peel adhesive backing from all strips of tape. • Press firmly to glass surface. Care and Construction Powder Coated Steel Material Characteristics Designed for Long-Term, Heavy-Duty Applications Dispensers and stands made of powder coated steel are both attractive and functional, providing years of service. Our powder coated steel dispensers and stands provide long-lasting products that hold up well in tough environments. Powder coated steel is ideal for dispensers used in a healthcare or an industrial setting. It is impact resistant and is not effected by extremes in temperature. 1 • Hanger can also be mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning The powder coated finish resists common chemicals and cleaning agents and can be easily wiped clean with soap and water. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser MB-500 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. MB500TDSa
MB-500 价格&库存
很抱歉,暂时无法提供与“MB-500”相匹配的价格&库存,您可以联系我们找货
