MD-100
MD-100
    BOWMAN
    PROTECTIVE WEAR ORGANIZER - DENT
MD-100 数据手册
MD-100 Dental Organizer Product Description: • Dental Organizer • Holds three boxes of gloves, two boxes of face masks, quarter fold towels, and patient bibs • Tabs on both sides of unit to hang patient bib clips • Keyholes for wall mounting • Quartz Beige ABS Plastic and Clear PETG Plastic Primary Area for Product Usage: • Anywhere personal protective equipment is needed Dispense • Top: Box(es) no larger than 5.00"W x 8.00"H x 4.00"D (12.7 cm x 25.4 cm x 10.2 cm) • Middle: Box(es) no larger than 5.00"W x 8.00"H x 4.50"D (12.7 cm x 25.4 cm x 11.4 cm) • Bottom left: Bulk mulit-fold towels • Bottom right: Patient bibs • Tabs on sides: Patient bib clips Package Specifications: • Package Quantity: 1 per case • 18"L x 6"W x 29"H (45.7 cm x 15.2 cm x 73.7 cm) • 7.0 lbs (3.2 kg) - approximated Product Specifications (overall external dimensions): Related Products (each sold separately): • 17.61"W x 23.50"H x 5.08"D (44.7 cm x 59.7 cm x 12.9 cm) • 4.4 lbs (2.0 kg) - approximated Mounting Specifications: • BD601-0012 - Protection System Isolation Kit (shown below) 2.31 (4x) R.13 (2x) R.25 (2x) 15.25 .75 12.00 6.25 .25 (2x) Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com MD-100 Dental Organizer Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Towels dispense through a cutout in the bottom for quick, one-handed access. • Patient bib clips are kept handy by hanging on the sides of the organizer. Care and Construction ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. ABS is chemical, stress-crack resistant, dimensionally stable, and will hold up to long-term use. It possesses high strength and performance characteristics at a reasonable cost. Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. 1 Standard hospital cleaning supplies are approved for use on our ABS plastic products. • Mount securely to a wall with screws approved and supplied by building maintenance. PETG Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications Copolyester resin is designed for heavy-duty applications, and is used by BOWMAN® Dispensers. We never use acrylic in our products. Copolyester (PETG) is typically 15-20 times tougher than general purpose acrylic. PETG is made to withstand handling and reduce losses due to breakage. PETG resists a variety of chemicals and commonly used cleaning agents. It is tough and durable (not brittle), providing years of trouble-free functionality and long life. 2 Clear optical characteristics mean the viewer can see the content, read text, and see true colors through the material. It complies with FDA regulations for food contact. Parts included: Care and Cleaning • Dispenser Most cleaning chemicals do not weaken the surface or cause damage to the material. Suggested cleaning method is to use a soft cloth, warm water, and mild soap. Tools Required: • No tools required to assemble dispenser MD-100 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. MD100TDSa
MD-100 价格&库存
很抱歉,暂时无法提供与“MD-100”相匹配的价格&库存,您可以联系我们找货
