NC015-0212
NC015-0212
    BOWMAN
    BULK MASK ADAPTER
NC015-0212 数据手册
NC015-0212 Bulk Mask Adapter Product Description: • Bulk Mask Adapter • Converts the face mask section into two bulk or controlleddispensing sections • Inserts directly into face mask sections of metal BOWMAN® Respiratory Hygiene Stations • Quartz Beige ABS Plastic Primary Area for Product Usage: • Anywhere Respiratory Hygiene Stations are needed Dispenses: • Fits sections no smaller than 7.76"W x 8.50"H x 4.80"D (19.7 cm x 21.6 cm x 12.2 cm) Package Specifications: • Package Quantity: 6 per case • 16"L x 12"W x 12"H (40.6 cm x 30.5 cm x 30.5 cm) • 5.0 lbs (2.3 kg) - approximated Product Specifications (overall external dimensions): • 7.76"W x 8.50"H x 4.80"D (19.7 cm x 21.6 cm x 12.2 cm) • 0.4 lbs (0.2 kg) - approximated Compatible BOWMAN Products (each sold separately): • Cover Your Cough Compliance Kits: • BD101-0012 • BD102-0012 • BD105-0012 • BD106-0012 • BD201-0012 • BD202-0012 • BD205-0012 • BD206-0012 • Respiratory Hygiene Stations: • RS001-0412 • RS002-0412 • RS004-0412 • RS005-0412 Related Products (each sold separately): • BD206-0012: Cover Your Cough Compliance Kit (left) • RS005-0412: Respiratory Hygiene Station - Locking • MP-075: Sign Holder - Horizontal • NC015-0212 shown inside (sold separately) Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com NC015-0212 Bulk Mask Adapter Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Insert Bulk Mask Adapter into BOWMAN® Respiratory Hygiene Station (compatible products listed on page 1) • Front of RHS will flex slightly for insertion. Care and Construction ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. ABS is chemical and stress-crack resistant. It is tough, dimensionally stable, and will hold up to long-term use. It possesses high strength and performance characteristics at a reasonable cost. 1 • Add bulk or boxed face masks behind Adapter and dispense as usual. Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies can be used. 2 Parts included: • Adapter Tools Required: • No tools required to assemble adapter NC015-0212 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2020 BOWMAN® Dispensers, LLC. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. NC0150212TDSb
NC015-0212 价格&库存
很抱歉,暂时无法提供与“NC015-0212”相匹配的价格&库存,您可以联系我们找货
