PB004-0811
PB004-0811
    BOWMAN
    PHYSICAL BARRIER - SHORT
PB004-0811 数据手册
PB004-0811 Plastic Barrier - Short Care and Construction Acrylic Material Characteristics Designed for Durable, Transparent Applications Acrylic is a clear, impact and weatherresistant material consisting of methyl methacrylate polymers (PMMA). It is often used as a glass replacement due to its strength and transparency. Clear optical characteristics mean the viewer can see the content, read text, and see true colors through the material. Product Description: • • • • Plastic Barrier - Short Wide base provides stability Attached rubber feet protect surfaces Clear Acrylic Primary Area for Product Usage: • Anywhere a barrier is needed Package Specifications: • Package Quantity: 1 per case • 20”L x 6”W x 20”H (50.8 cm x 15.2 cm x 50.8 cm) • 3.0 lbs (1.4 kg) - approximated Care and Cleaning Most cleaning chemicals do not weaken the surface or cause damage to the material. Suggested cleaning method is to use a soft cloth, warm water, and mild soap. Do not place in direct sun. Product Specifications (overall external dimensions): • 4.50"W x 16.00"H x 15.75"D (11.4 cm x 40.6 cm x 40.0 cm) • 2.5 lbs (1.1 kg) - approximated Mounting Instructions: • Place on flat surface making sure all four rubber feet make contact. Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2020 BOWMAN® Dispensers, LLC. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. PB0040811TDSb
PB004-0811 价格&库存
很抱歉,暂时无法提供与“PB004-0811”相匹配的价格&库存,您可以联系我们找货
