PB012-1211
PB012-1211
    BOWMAN
    PROTECTIVE BARRIER - PASS THROUG
PB012-1211 数据手册
PB012-1211 Protective Barrier - Pass Through Opening - XLarge Care and Construction Polycarbonate Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications Polycarbonate plastic is a polymer comprised of Bisphenol A and phosgene, which makes it shatter resistant and provides an excellent combination of strength, rigidity, and toughness. This polycarbonate plastic is a clear, lightweight, tough, dimensionally stable thermoplastic. It is shatter resistant and will not soften over time. It is resistant to humidity and temperatures over 300°F. Polycarbonate is virtually unbreakable, making it safe to use in areas where it may be exposed to impact. The transparency allows the viewer to see content, read text, and see true colors through the material. Product Description: • • • • • Protective Barrier - Pass Through Opening - XLarge Support legs insert into barrier for portability and quick setup Pass through opening at bottom measuring 12.00"W x 5.00"H Disassembles for flat storage Clear Polycarbonate Plastic Primary Area for Product Usage: • Anywhere a protective barrier is needed Package Specifications: Care and Cleaning Resistant to stains, polycarbonate is easily cleaned with common cleaners or soap and water. Alcohol is recommended to remove grease or oil. Ammonia and acetone should not be used. • Package Quantity: 1 per case • 34”L x 5”W x 41”H (86.4 cm x 12.7 cm x 104.1 cm) • 12.0 lbs (5.4 kg) - approximated Product Specifications (overall external dimensions): • 36.00"W x 31.00"H x 11.50"D (91.4 cm x 78.7 cm x 29.2 cm) • 9.8 lbs (4.4 kg) - approximated Mounting Instructions: • Fit legs to barrier by matching slot cutouts and sliding together. • Disassemble for flat storage. Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2020 BOWMAN® Dispensers, LLC. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. PB0121211TDSb
PB012-1211 价格&库存
很抱歉,暂时无法提供与“PB012-1211”相匹配的价格&库存,您可以联系我们找货
