PB014-1211
PB014-1211
    BOWMAN
    PROTECTIVE BARRIER - HINGED - ME
PB014-1211 数据手册
PB014-1211 Protective Barrier - Hinged - Medium Care and Construction Polycarbonate Plastic/PVC Material Characteristics Designed for Long-Term, Heavy-Duty Applications Polycarbonate plastic is a polymer comprised of Bisphenol A and phosgene, which makes it shatter resistant and provides an excellent combination of strength, rigidity, and toughness. This polycarbonate plastic is a clear, lightweight, tough, dimensionally stable thermoplastic. It is shatter resistant and will not soften over time. It is resistant to humidity and temperatures over 300°F. Polycarbonate is virtually unbreakable, making it safe to use in areas where it may be exposed to impact. The transparency allows the viewer to see content, read text, and see true colors through the material. Product Description: • • • • Protective Barrier - Hinged - Medium Flexible hinge bends to create protective barrier between seated personnel Folds flat for convenient storage Clear Polycarbonate Plastic & PVC hinge Primary Area for Product Usage: • Anywhere a protective barrier is needed Package Specifications: • Package Quantity: 1 per case • 24”L x 7”W x 29”H (61.0 cm x 17.8 cm x 73.7 cm) • 10.0 lbs (4.5 kg) - approximated Product Specifications (overall external dimensions): • 40.31"W x 23.75"H x 0.18"D (102.4 cm x 60.3 cm x 0.4 cm) • 7.6 lbs (3.4 kg) - approximated Mounting Instructions: • Bend sections to create an angle to stand. • Multiple barriers can be used to section off areas of a table. Product Videos: BowmanDispensers.com/Product-Videos The clear hinge is constructed of a rigid PVC (vinyl chloride and polyvinyl chloride) connecting to the polycarbonate panes, with a flexible Hytrel® (thermoplastic polyester elastomer) connective material to create a standing corner and to allow flat storage. Notice for the State of California on PVC: Warning: Cancer and Reproductive Harm www.P65Warnings.ca.gov Care and Cleaning Resistant to stains, polycarbonate is easily cleaned with common cleaners or soap and water. Alcohol is recommended to remove grease or oil. Ammonia and acetone should not be used. BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2020 BOWMAN® Dispensers, LLC. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. PB0141211TDSb
PB014-1211 价格&库存
很抱歉,暂时无法提供与“PB014-1211”相匹配的价格&库存,您可以联系我们找货
