PD007-0300
PD007-0300
    BOWMAN
    PROTECTIVE WEAR DISPENSER - CAP/
PD007-0300 数据手册
PD007-0300 Protective Wear Dispenser - Cap/Shoe Cover Product Description: • • • • Protective Wear Dispenser - Cap/Shoe Cover Holds one box of bouffant caps or shoe covers Keyholes for wall mounting Stainless Steel Primary Area for Product Usage: • Anywhere protection equipment products are needed Dispenses: • Box(es) no larger than 11.19"W x 11.13"H x 5.06"D (28.4 cm x 28.3 cm x 12.9 cm) • Box(es) no smaller than 10.25"W x 9.11"H x 4.25"D (26.0 cm x 23.1 cm x 10.8 cm) Package Specifications: • Package Quantity: 6 per case • 20"W x 16"H x 12"D (50.8 cm x 40.6 cm x 30.5 cm) • 14.0 lbs (6.4 kg) - approximated Product Specifications (overall external dimensions): • 11.25"W x 11.23"H x 5.12"D (28.6 cm x 28.5 cm x 13.0 cm) • 1.9 lbs (0.8 kg) - approximated • BP-007: Protective Wear Dispenser - Cap/Shoe Cover (shown below) • PD033-0300: Protective Wear Dispenser - Shoe Cover R.13 (TYP.) .78 8.69 R.25 (TYP.) 9.69 .50 (TYP.) Related Products (each sold separately): 1.00 Mounting Specifications: Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com PD007-0300 Protective Wear Dispenser - Caps/Shoe Covers Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Open front design accommodates a wide variety of box perforations. Care and Construction Stainless Steel Material Characteristics Designed for Long-Term, Heavy-Duty Applications Stainless steel is used overwhelmingly for its corrosion and oxidation resistance characteristics. Along with being sturdy, stainless steel is also fire and heat resistant. The work-hardening properties of stainless steel gives the material a great strength-to-weight advantage over other materials. It also provides impact resistance and high toughness in extreme temperatures. 1 Stainless steel has a bright, stain resistant surface and pleasing aesthetic appearance. • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning Stainless steel resists a variety of common chemicals and cleaning agents. Clean using warm water, a gentle detergent, and soft cloth. Standard hospital cleaning supplies are approved for use on our stainless steel products. Dry thoroughly to avoid spotting. Do not use steel wool. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser PD007-0300 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. PD0070300TDSa
PD007-0300 价格&库存
很抱歉,暂时无法提供与“PD007-0300”相匹配的价格&库存,您可以联系我们找货
