PD200-0212
PD200-0212
    BOWMAN
    PROTECTIVE WEAR DISPENSER - UNIV
PD200-0212 数据手册
PD200-0212 Protection Dispenser - Universal Boxed - Large Product Description: • Protection Dispenser - Universal Boxed - Large • Dispenses Shoe Covers/Caps/Other • Holds a variety of oversized boxes of bouffant caps, surgeons’ caps, and shoe-covers from most major manufacturers • Keyholes for wall mounting • Made of Quartz Beige ABS Plastic Primary Area for Product Usage: • Patient care areas: OR dressing rooms, surgery centers, labs, interventional radiology, ICU, clinics Dispenses: Most oversized boxes of protection apparel: • Boxes no larger than 12.25”W x 20.00”H x 9.63”D (31.1 cm x 50.8 cm x 24.5 cm) • Boxes no smaller than 9.00”W x 8.00”H x 7.50”D (22.9 cm x 20.3 cm x 19.1 cm) Package Specifications: • Package Quantity: 2 per case • 16”L x 12”W x 12”H (40.6 cm x 30.5 cm x 30.5 cm) • 5.0 lbs (2.3 kg) - approximated Product Specifications (overall external dimensions): PATENT PENDING • 12.50”W x 10.13”H x 9.88”D (31.8 cm x 25.7 cm x 25.1 cm) • 1.9 lbs (0.8 kg) - approximated Mounting Specifications: Alternative Products (each sold separately): • PD100-0212, Protection Dispenser - Universal Boxed • PD300-0212, Protection Dispenser - Universal Boxed R.13 (TYP) R. 25 (TYP) PD100-0212 Product Videos: BowmanDispensers.com/Product-Videos PD300-0212 .75 (TYP) 7.38 8.00 BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com PD200-0212 Protection Dispenser - Universal Boxed - Large Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Spring design provides secure fit for a wide assortment of boxed products. • Open configuration allows dispensing of product through top or front. Care and Construction ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. ABS is chemical, stress-crack resistant, dimensionally stable, and will hold up to long-term use. It possesses high strength and performance characteristics at a reasonable cost. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser PD200-0212 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2018 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. PD2000212TDSc
PD200-0212 价格&库存
很抱歉,暂时无法提供与“PD200-0212”相匹配的价格&库存,您可以联系我们找货
