PS001-0212
PS001-0212
    BOWMAN
    PROTECTIVE WEAR ORGANIZER
PS001-0212 数据手册
PS001-0212 Protection System with Door Product Description: • Protection System with Door • Holds disposable or reusable gowns, aprons, or coveralls/ jumpsuits, two boxes of gloves, one box of earloop masks, and one box of face shields • Hinged door over face mask section • Keyholes for wall mounting, or cutout for use with BOWMAN® hanger • Quartz Beige ABS Plastic Primary Area for Product Usage: • Anywhere personal protection equipment is needed Dispenses: • Left: Gowns, aprons, or coveralls/jumpsuits no larger than 14.90”W x 14.87”H x 4.50”D (13.3 cm x 37.8 cm x 9.5 cm) • Top right: Box(es) no larger than 4.75"W x 8.00"H x 4.45"D (12.0 cm x 20.3 cm x 11.3 cm) • Middle right: Box(es) no larger than 4.75"W x 8.00"H x 4.45"D (12.0 cm x 20.3 cm x 11.3 cm) • Bottom: Box(es) no larger than 10.00”W x 5.50”H x 3.88"D (25.4 cm x 14.0 cm x 9.9 cm) Package Specifications: • Package Quantity: 1 per case • 24”W x 8”H x 24”D (61.0 cm x 20.3 cm x 61.0 cm) • 9.0 lbs (4.1 kg) - approximated Accessories (each sold separately): • MP-047: Sign Holder - Clip On (shown below) • Clip-On Caddy: MP-015 and MP-085 • Door/Wall Hangers: HH004-0412, MB-450, MB-510, MB-600, MB-601 Product Specifications (overall external dimensions): • 23.00”W x 20.63”H x 5.08”D (58.4 cm x 52.4 cm x 12.9 cm) • 5.2 lbs (2.3 kg) - approximated Mounting Specifications: 16.00 R.13 (2x) R. 25 (2x) 16.88 1.75 .75 3.38 .25 (2x) Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com PS001-0212 Protection System with Door Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Hinged door with magnetic closure covers face mask area. Care and Construction ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. ABS is chemical and stress-crack resistant. It is tough, dimensionally stable, and will hold up to long-term use. It possesses high strength and performance characteristics at a reasonable cost. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser PS001-0212 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. PS0010212TDSa
PS001-0212
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外遥控接收器。
2. 器件简介:EL817是一款用于红外遥控系统的接收器,具有高灵敏度和低功耗特性。
3. 引脚分配:EL817共有3个引脚,分别为VCC、GND和OUT。
4. 参数特性:工作电压范围为2.5V至5.5V,工作电流为0.8mA,接收频率范围为30kHz至60kHz。
5. 功能详解:EL817能够接收红外信号并输出相应的电信号,用于控制各种电子设备。
6. 应用信息:广泛应用于电视、空调、音响等家用电器的遥控系统中。
7. 封装信息:EL817采用SOP-8封装。
PS001-0212 价格&库存
很抱歉,暂时无法提供与“PS001-0212”相匹配的价格&库存,您可以联系我们找货
