PS012-0512
PS012-0512
    BOWMAN
    PROTECTIVE WEAR ORGANIZER - QUAD
PS012-0512 数据手册
PS012-0512 Protection System - Quad Glove Product Description: • Protection System - Quad Glove • Holds disposable or reuseable gowns, aprons, or coveralls/ jumpsuits, four boxes of gloves, one box of earloop masks, and one box of face shields • Keyholes for wall mounting, or door hanger cut out for use with wall or door hanger • Quartz Beige Powder-Coated Aluminum Primary Area for Product Usage: • Anywhere personal protection equipment is needed Dispenses: • Top left: Gowns, aprons, or coveralls/jumpsuits no larger than 14.45"W x 14.73"H x 4.48"D (36.7 cm x 37.4 cm x 11.4 cm) • Top right: Box(es) no larger than 8.20"W x 9.65"H x 4.48"D (20.8 cm x 24.5 cm x 11.4 cm) • Middle right: Box(es) no larger than 8.20"W x 4.98"H x 4.48"D (20.8 cm x 12.6 cm x 11.4 cm) • Bottom: Box(es) no larger than 10.00"W x 5.38"H x 4.00"D (25.4 cm x 13.7 cm x 10.2 cm) Package Specifications: • Package Quantity: 1 per case • 25"W x 6"H x 33"D (63.5 cm x 15.2 cm x 83.8 cm) • 10.0 lbs (4.5 kg) - approximated Product Specifications (overall external dimensions): • 22.75"W x 25.63"H x 4.58"D (57.8 cm x 65.1 cm x 11.6 cm) • 7.35 lbs (3.31 kg) - approximated Related Products (each sold separately): Mounting Specifications: • PS014-0212: Protection System - Gloveless (shown below) • PS015-0212: Protection System - Gown • PS015-0512: Protection System - Double Gown 16.00 R.13 (2x) R.25 (2x) 22.08 .75 2.25 3.38 Ø.25 (2x) Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com PS012-0512 Protection System - Quad Glove Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Construction Powder-Coated Aluminum Material Characteristics Designed for Long-Term, Heavy-Duty Applications Our powder-coated aluminum dispensers resist corrosion, chips and flaking. This material will provide longlasting products that hold up well in tough environments. Powder-coated aluminum is ideal for dispensers used in a healthcare or an industrial setting. It is impact resistant and is not effected by extremes in temperature. 1 • Dispenser can be mounted onto a BOWMAN® door or wall hanger through the cutout in the back. Care and Cleaning The semi-gloss powder-coated finish resists mild chemicals and cleaning agents, such as Windex or glass cleaners. It should be cleaned with a damp cloth or mild soap and water. Scotch-Brite, steel wool or any abrasive products should not be used. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser PS012-0512 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. PS0120512TDSa
PS012-0512 价格&库存
很抱歉,暂时无法提供与“PS012-0512”相匹配的价格&库存,您可以联系我们找货
