PS015-0212
PS015-0212
    BOWMAN
    PROTECTIVE WEAR ORGANIZER - DOUB
PS015-0212 数据手册
PS015-0212 Protection System - Double Gown Product Description: • Protection System - Double Gown • Holds disposable or reusable gowns, aprons, or coveralls/ jumpsuits, three boxes of gloves, two boxes of earloop masks, and miscellaneous items • Keyholes for wall mounting, or door hanger cut out for use with wall or door hanger • Quartz Beige ABS Plastic Primary Area for Product Usage: • Anywhere personal protection equipment is needed Dispenses: • Left: Gowns, aprons, or coveralls/jumpsuits no larger than 14.80”W x 15.25”H x 4.50”D (37.6 cm x 38.7 cm x 11.4 cm) • Top right: Box(es) no larger than 4.88"W x 7.99"H x 4.50"D (12.4 cm x 20.3 cm x 11.4 cm) • Middle right: Box(es) no larger than 10.00"W x 5.35"H x 4.50"D (25.4 cm x 13.6 cm x 11.4 cm) • Bottom right: Item(s) no larger than 9.85"W x 6.13"H x 4.50"D (25.0 cm x 15.6 cm x 11.4 cm) Package Specifications: • Package Quantity: 1 per case • 26"W x 32"H x 6"D (66 cm x 81.3 cm x 15.2 cm) • 13.0 lbs (5.9 kg) - approximated Product Specifications (overall external dimensions): • 25.15"W x 30.75"H x 4.75"D (63.9 cm x 78.1 cm x 12.1 cm) • 9.4 lbs (4.3 kg) - approximated Mounting Specifications: Related Products (each sold separately): 6.53 12.00 R.13 (2x) 3.00 • PS014-0212: Protection System - Gloveless (shown below) • PS015-0512: Protection System - Double Gown 25.00 .75 R.25 (2x) .26 (2x) Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com PS015-0212 Protection System - Double Gown Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Compartments are versatile and will accommodate many different products, such as small wipe canisters, rolled face shields, and folded laundered gowns. Care and Construction ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. The fauxwood finish is ARVINYL laminate created from a semi-rigid film. ABS is chemical and stress-crack resistant. It is tough, dimensionally stable, and will hold up to long-term use. To ensure product longevity, fauxwood products should not be mounted in very hot or cold areas. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. • Dispenser can be mounted onto a BOWMAN® door or wall hanger through the cutout in the back. (please see chosen hanger’s datasheet for details) Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser PS015-0212 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. PS0150212TDSa
PS015-0212 价格&库存
很抱歉,暂时无法提供与“PS015-0212”相匹配的价格&库存,您可以联系我们找货
