PS016-0111
PS016-0111
    BOWMAN
    PROTECTIVE WEAR ORGANIZER
PS016-0111 数据手册
PS016-0111 Protection System Product Description: • Protection System • Holds disposable or reuseable gowns, aprons, or coveralls/ jumpsuits, three - four boxes of gloves, one box of earloop masks, one box of face shields, and miscellaneous items • Keyholes for wall mounting, or door hanger cut out for use with wall or door hanger • Clear PETG Plastic Primary Area for Product Usage: • Anywhere personal protection equipment is needed Dispenses: • Top left: Gowns, aprons, or coveralls/jumpsuits no larger than 14.90"W x 4.50"D (37.8 cm x 11.4 cm) • Top right: Box(es) no larger than 8.10"W x 9.90"H x 4.50"D (20.6 cm x 25.1 cm x 11.4 cm) • Middle right: Box(es) no larger than 8.00"W x 5.30"H x 4.50"D (20.3 cm x 13.5 cm x 11.4 cm) • Bottom: Box(es) up to 11.50"W x 5.50"H x 4.50"D (29.2 cm x 14.0 cm x 11.4 cm), and/or miscellaneous items Package Specifications: • 26"L x 6"W x 32"H (66.0 cm x 15.2 cm x 81.3 cm) • 12.0 lbs (5.4 kg) - approximated Product Specifications (overall external dimensions): • 23.38"W x 26.63"H x 4.75"D (59.4 cm x 67.6 cm x 12.1 cm) • 3.1 lbs (1.4 kg) - approximated .75 Mounting Specifications: Accessories (each sold separately): 12.00 R.13 (2x) • Clip-On Caddy Dispensers: MP-015 and MP-085 • Sign Holder MP-047 20.00 R.25 (2x) Ø.26 (2x) MP0-015 Product Videos: MP0-085 BowmanDispensers.com/Product-Videos MP-047 BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com PS016-0111 Protection System Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Clear material allows full view of all contents and supply levels. Care and Construction PETG Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications Copolyester resin is designed for heavy-duty applications, and is used by BOWMAN® Dispensers. We never use acrylic in our products. Copolyester (PETG) is typically 15-20 times tougher than general purpose acrylic. PETG is made to withstand handling and reduce losses due to breakage. PETG resists a variety of chemicals and commonly used cleaning agents. It is tough and durable (not brittle), providing years of trouble-free functionality and long life. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. • Dispenser can be mounted onto a BOWMAN® door or wall hanger through the cutout in the back. (Please see datasheet of chosen hanger for details.) Clear optical characteristics mean the viewer can see the content, read text, and see true colors through the material. It complies with FDA regulations for food contact. Care and Cleaning Most cleaning chemicals do not weaken the surface or cause damage to the material. Suggested cleaning method is to use a soft cloth, warm water, and mild soap. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser PS016-0111- Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. PS0160111TDSa
PS016-0111 价格&库存
很抱歉,暂时无法提供与“PS016-0111”相匹配的价格&库存,您可以联系我们找货
