PS016-0212
PS016-0212
    BOWMAN
    PROTECTIVE WEAR ORGANIZER
PS016-0212 数据手册
PS016-0212 Protection System Product Description: • Protection System • Holds disposable or reuseable gowns, aprons, or coveralls/ jumpsuits, three - four boxes of gloves, one box of earloop masks, one box of face shields, and miscellaneous items • Keyholes for wall mounting, or door hanger cut out for use with wall or door hanger • Quartz Beige ABS Plastic Primary Area for Product Usage: • Anywhere personal protection equipment is needed Dispenses: • Top left: Gowns, aprons, or coveralls/jumpsuits no larger than 14.90"W x 4.50"D (37.8 cm x 11.4 cm) • Top right: Box(es) no larger than 8.10"W x 9.90"H x 4.50"D (20.6 cm x 25.1 cm x 11.4 cm) • Middle right: Box(es) no larger than 8.00"W x 5.30"H x 4.50"D (20.3 cm x 13.5 cm x 11.4 cm) • Bottom: Box(es) up to 11.50"W x 5.50"H x 4.50"D (29.2 cm x 14.0 cm x 11.4 cm), and/or miscellaneous items Package Specifications: • 26"L x 6"W x 32"H (66.0 cm x 15.2 cm x 81.3 cm) • 12.0 lbs (5.4 kg) - approximated Product Specifications (overall external dimensions): • 23.38"W x 26.63"H x 4.75"D (59.4 cm x 67.6 cm x 12.1 cm) • 7.7 lbs (3.5 kg) - approximated .75 Mounting Specifications: Accessories (each sold separately): 12.00 R.13 (2x) • Clip-On Caddy Dispensers: MP-015 and MP-085 • Sign Holder MP-047 20.00 R.25 (2x) Ø.26 (2x) MP0-015 Product Videos: MP0-085 BowmanDispensers.com/Product-Videos MP-047 BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com PS016-0212 Protection System Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Built-in tabs hold boxes securely. Care and Construction ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. The fauxwood finish is ARVINYL laminate created from a semi-rigid film. ABS is chemical and stress-crack resistant. It is tough, dimensionally stable, and will hold up to long-term use. To ensure product longevity, fauxwood products should not be mounted in very hot or cold areas. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. • Dispenser can be mounted onto a BOWMAN® door or wall hanger through the cutout in the back. (Please see datasheet of chosen hanger for details.) Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser PS016-0212 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. PS0160212TDSa
PS016-0212 价格&库存
很抱歉,暂时无法提供与“PS016-0212”相匹配的价格&库存,您可以联系我们找货
