PS016-0520
PS016-0520
    BOWMAN
    PROTECTIVE WEAR ORGANIZER
PS016-0520 数据手册
PS016-0520 Protective Wear Organizer Product Description: • Protective Wear Organizer • Holds disposable or reuseable gowns, aprons, or coveralls/ jumpsuits, three - four boxes of gloves, one box of earloop masks, one box of face shields, and miscellaneous items • Keyholes for wall mounting, or door hanger cut out for use with BOWMAN® wall or door hanger • Black Powder-Coated Aluminum Primary Area for Product Usage: • Anywhere personal protection equipment is needed Dispenses: • Top left: Gowns, aprons, or coveralls/jumpsuits no larger than 14.40"W x 4.50"D (36.6 cm x 11.4 cm) • Top right: Box(es) no larger than 8.10"W x 9.60"H x 4.50"D (20.6 cm x 24.4 cm x 11.4 cm) • Middle right: Box(es) no larger than 8.20"W x 5.00"H x 4.50"D (20.8 cm x 12.7 cm x 11.4 cm) • Bottom: Box(es) no larger than 11.30"W x 5.40"H x 4.00"D (28.7 cm x 13.7 cm x 10.2 cm) and/or miscellaneous items Product Specifications (overall external dimensions): • 22.75"W x 25.63"H x 4.58"D (57.8 cm x 65.1 cm x 11.6 cm) • 7.6 lbs (3.4 kg) - approximated Mounting Specifications: 16.50 2.25 Accessories (each sold separately): 25.63 • Clip-On Caddy Dispensers: MP-015 and MP-085 • Sign Holder MP-047 Package Specifications: MP0-015 Product Videos: MP0-085 BowmanDispensers.com/Product-Videos MP-047 • Package Quantity: 1 per case • 26"L x 6"W x 32"H (66.0 cm x 15.2 cm x 81.3 cm) • 10.0 lbs (5.0 kg) - approximated BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com PS016-0520 Protective Wear Organizer Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Sleek design holds all PPE necessary for proper isolation protection. Care and Construction Powder-Coated Aluminum Material Characteristics Designed for Long-Term, Heavy-Duty Applications Our powder-coated aluminum dispensers resist corrosion, chips and flaking. This material will provide longlasting products that hold up well in tough environments. Powder-coated aluminum is ideal for dispensers used in a healthcare or an industrial setting. It is impact resistant and is not effected by extremes in temperature. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. • Dispenser can be mounted onto a BOWMAN® door or wall hanger through the cutout in the back. (Please see datasheet of chosen hanger for details.) Care and Cleaning The semi-gloss powder-coated finish resists mild chemicals and cleaning agents, such as Windex or glass cleaners. It should be cleaned with a damp cloth or mild soap and water. Scotch-Brite, steel wool or any abrasive products should not be used. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser PS016-0520 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2021 BOWMAN® Dispensers, LLC. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. PS0160520TDSa
PS016-0520 价格&库存
很抱歉,暂时无法提供与“PS016-0520”相匹配的价格&库存,您可以联系我们找货
