PS022-0512
PS022-0512
    BOWMAN
    PROTECTIVE WEAR ORGANIZER
PS022-0512 数据手册
PS022-0512 Protection System - Double Glove Product Description: • Protection System • Holds gowns, aprons, or overalls/jumpsuits, two boxes of gloves, one box of earloop masks, and one box of shield masks • Keyholes for wall mounting, or cutout for use with BOWMAN® hanger • Quartz Beige Powder-Coated Aluminum Primary Area for Product Usage: • Anywhere protective equipment is needed Dispenses: • Top left: Box(es) of isolation gowns, up to 15 flat-pack gowns, or up to 20 launderable gowns • Top right: Box(es) no larger than 8.13"W x 9.63"H x 4.25"D (20.7 cm x 24.5 cm x 10.8 cm) • Middle right: Box(es) no larger than 8.13"W x 5.00"H x 4.25"D (20.7 cm x 12.7 cm x 10.8 cm) • Bottom: Boxes no larger than 11.31"W x 5.38"H x 4.00"D (28.7 cm x 13.7 cm x 10.2 cm) Package Specifications: • 24"L x 8"W x 24"H (61.0 cm x 20.3 cm x 61.0 cm) • 9.0 lbs (4.1 kg) - approximated Product Specifications (overall external dimensions): • 22.75"W x 20.23"H x 4.58"D (57.8 cm x 51.4 cm x 11.6 cm) • 6.1 lbs (2.7 kg) - approximated Mounting Specifications: Related Products (each sold separately): 16.00 6.13 15.02 1.50 .75 • PS021-0512: Protection System (shown below) R.13 (2x) R.25 (2x) �.25 (2x) 13.00 Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com PS022-0512 Protection System - Double Glove Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Compact design holds the most crucial PPE in a small space. Care and Construction Powder-Coated Aluminum Material Characteristics Designed for Long-Term, Heavy-Duty Applications Our powder-coated aluminum dispensers resist corrosion, chips and flaking. This material will provide longlasting products that hold up well in tough environments. Powder-coated aluminum is ideal for dispensers used in a healthcare or an industrial setting. It is impact resistant and is not effected by extremes in temperature. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. • Dispenser can be mounted onto a BOWMAN® door or wall hanger through the cutout in the back. (Please see chosen hanger’s datasheet for details.) Care and Cleaning The semi-gloss powder-coated finish resists mild chemicals and cleaning agents, such as Windex or glass cleaners. It should be cleaned with a damp cloth or mild soap and water. Scotch-Brite, steel wool or any abrasive products should not be used. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser PS022-0512 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. PS0220512TDSa
PS022-0512 价格&库存
很抱歉,暂时无法提供与“PS022-0512”相匹配的价格&库存,您可以联系我们找货
