PS023-0212
PS023-0212
    BOWMAN
    PROTECTIVE WEAR ORGANIZER - SURG
PS023-0212 数据手册
PS023-0212 Protection System - Surgical Product Description: • Protection System - Surgical • Holds protective apparel in two bulk compartments, three boxes of gloves, and one box of face masks • Pivot hinge lid over bulk compartments • Keyholes for wall mounting, or door hanger cutout for use with wall or door hanger • Quartz Beige ABS Plastic Primary Area for Product Usage: • Anywhere personal protection equipment is needed Dispenses: • Top left: Bulk bins hold miscellaneous item(s) no larger than 6.00″W x 10.50″H x 4.70″D (15.2 cm x 26.7 cm x 11.9 cm) • Bottom left: Box(es) no larger than 10.00″W x 4.83″H x 4.54″D (25.4 cm x 12.3 cm x 11.5 cm) • Right: Box(es) no larger than 9.75″W x 5.40″H x 4.54″D (24.8 cm x 13.7 cm x 11.5 cm) Package Specifications: • Package Quantity: 1 per case • 18″L x 6″W x 29″H (45.7 cm x 15.2 cm x 73.7 cm) • 7.0 lbs (3.2 kg) - approximated Product Specifications (overall external dimensions): Related Products (each sold separately): Mounting Specifications: 16.00 6.00 R.13 (2x) R. 25 (2x) 11.05 1.75 .75 1.50 • PS017-0212, Protection System - Surgical • PD100-0212, Protection Dispenser - Universal Boxed - Shoe Cover/ Cap/Other • PD200-0212, Protection Dispenser - Universal Boxed - Shoe Cover/ Cap/Other - Large • PD300-0212, Protection Dispenser - Universal Boxed - Shoe Cover/ Cap/Other • BOWMAN® Door and Wall Hangers: MB-450, MB-500, MB-510, and MB-600 • 22.30″W x 16.63″H x 5.10″D (56.6 cm x 42.2 cm x 13.0 cm) • 4.6 lbs (2.1 kg) - approximated R.13 (2x) PD100-0212 Product Videos: PD200-0212 BowmanDispensers.com/Product-Videos PD300-0212 BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com PS023-0212 Protection System - Surgical Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Face mask area can also accommodate N95 masks. Care and Construction ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. The fauxwood finish is ARVINYL laminate created from a semi-rigid film. ABS is chemical and stress-crack resistant. It is tough, dimensionally stable, and will hold up to long-term use. To ensure product longevity, fauxwood products should not be mounted in very hot or cold areas. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. • Dispenser can be mounted onto a BOWMAN® door or wall hanger through the cutout in the back. (Please see chosen hanger’s datasheet for details.) Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser PS023-0212 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. PS0230212TDSa
PS023-0212 价格&库存
很抱歉,暂时无法提供与“PS023-0212”相匹配的价格&库存,您可以联系我们找货
