PS023-0512
PS023-0512
    BOWMAN
    PROTECTIVE WEAR ORGANIZER - SURG
PS023-0512 数据手册
PS023-0512 Protection System - Surgical Product Description: • Protection System - Surgical • Holds protective apparel in two bulk compartments, three boxes of gloves, and one box of face masks • Hinged lid over bulk compartments • Keyholes for wall mounting, or door hanger cutout for use with wall or door hanger • Quartz Beige Powder-Coated Aluminum Primary Area for Product Usage: • Anywhere personal protection equipment is needed Dispenses: • Top left: Bulk bins hold miscellaneous item(s) no larger than 6.06"W x 10.50"H x 4.75"D (15.4 cm x 25.9 cm x 12.1 cm) • Bottom left: Box(es) no larger than 10.00"W x 4.88"H x 4.75"D (25.4 cm x 12.4 cm x 12.1 cm) • Right: Box(es) no larger than 9.75"W x 5.38"H x 4.00"D (12.3 cm x 21.6 cm x 11.4 cm) Package Specifications: • Package Quantity: 1 per case • 18"L x 6"W x 29"H (45.7 cm x 15.2 cm x 73.7 cm) • 9.0 lbs (4.1 kg) - approximated Product Specifications (overall external dimensions): Related Products (each sold separately): Mounting Specifications: 16.00 6.00 R.13 (2x) R. 25 (2x) 11.05 1.75 .75 1.50 • PS017-0212, Protection System - Surgical • PD100-0212, Protection Dispenser - Universal Boxed - Shoe Cover/ Cap/Other • PD200-0212, Protection Dispenser - Universal Boxed - Shoe Cover/ Cap/Other - Large • PD300-0212, Protection Dispenser - Universal Boxed - Shoe Cover/ Cap/Other • BOWMAN® Door and Wall Hangers: MB-450, MB-500, MB-510, and MB-600 • 22.10"W x 16.53"H x 4.76"D (56.1 cm x 42.0 cm x 12.1 cm) • 6.6 lbs (3.0 kg) - approximated R.13 (2x) PD100-0212 Product Videos: PD200-0212 BowmanDispensers.com/Product-Videos PD300-0212 BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com PS023-0512 Protection System - Surgical Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Face mask area can also accommodate N95 masks. Care and Construction Powder-Coated Aluminum Material Characteristics Designed for Long-Term Use Our powder-coated aluminum dispensers resist corrosion, chipping, and flaking. It is lightweight, yet high in strength. This material will provide long-lasting products that hold up well, even in tough environments. Powder-coated aluminum is ideal for dispensers used in a healthcare or industrial settings. It is impact resistant and is not affected by extremes in temperature. 1 Powder-coated aluminum is clean, bright, and attractive; it creates a professional appearance. • Mount securely to a wall with screws approved and supplied by building maintenance. • Dispenser can be mounted onto a BOWMAN® door or wall hanger through the cutout in the back. (Please see chosen hanger’s datasheet for details.) Care and Cleaning For best results, clean by washing the surface with a diluted solution of a mild, non-abrasive detergent in cold or warm water and a non-abrasive cloth. Standard hospital cleaning supplies can be used. Dry with a soft cloth. Do not use any solvent-based materials, abrasives (e.g. Scotch-brite, steel wool), or apply excessive force during cleaning. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser PS023-0512 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. PS0230512TDSc
PS023-0512 价格&库存
很抱歉,暂时无法提供与“PS023-0512”相匹配的价格&库存,您可以联系我们找货
