PS415-0212
PS415-0212
    BOWMAN
    PROTECTIVE WEAR ORGANIZER - 4 -
PS415-0212 数据手册
PS415-0212 Protection System - Double Gown - 4" Product Description: • Protection System - Double Gown - 4" • Holds disposable or reusable gowns, aprons, or coveralls/ jumpsuits, three boxes of gloves, earloop masks, and miscellaneous supplies • ADA and CMS Wall Protrusion Compliant • Keyholes for wall mounting, or cutout for use with BOWMAN® hanger • Quartz Beige ABS Plastic Primary Area for Product Usage: • Anywhere protective equipment products are needed Dispenses: • Left: Gowns, aprons, or coveralls/jumpsuits no larger than 15.00"W x 15.25"H x 3.80"D (38.1 cm x 38.8 cm x 9.7 cm) • Top right: Item(s) no larger than 4.88"W x 8.00"H x 3.80"D (12.4 cm x 20.3 cm x 9.7 cm) • Middle right: Box(es) no larger than 10.01"W x 5.38"H x 3.80"D (25.4 cm x 13.7 cm x 9.7 cm) • Bottom right: Item(s) no larger than 10.01"W x 6.03"H x 3.80"D (25.4 cm x 15.3 cm x 9.7 cm) Package Specifications: • Package Quantity: 1 per case • 26"L x 6"W x 32"H (66.0 cm x 15.2 cm x 81.3 cm) • 10.0 lbs (4.5 kg) - approximated Product Specifications (overall external dimensions): PATENT PENDING • 25.11"W x 30.75"H x 4.00"D (63.8 cm x 78.1 cm x 10.2 cm) • 7.2 lbs (3.2 kg) - approximated Mounting Specifications: 12.00 6.53 R.13 (TYP.) R.25 (TYP.) 24.25 0.75 • MP-047: Sign Holder - Clip-On (below left) • BOWMAN® Door and Wall Hangers: MB-450, MB-500, MB-510, and MB-600 (below right) 3.00 Accessories (each sold separately): R.13 (2x) Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc.patents: www.bowmandispensers.com/patents PS415-0212 Protection System - Double Gown - 4" Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Construction ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. The fauxwood finish is ARVINYL laminate created from a semi-rigid film. ABS is chemical and stress-crack resistant. It is tough, dimensionally stable, and will hold up to long-term use. To ensure product longevity, fauxwood products should not be mounted in very hot or cold areas. 1 • Dispenser can be mounted onto a BOWMAN® door or wall hanger through the cutout in the back. Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser PS415-0212 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. PS4150212TDSc
PS415-0212 价格&库存
很抱歉,暂时无法提供与“PS415-0212”相匹配的价格&库存,您可以联系我们找货
