RS001-0412
RS001-0412
    BOWMAN
    RESPIRATORY HYGIENE STATION
RS001-0412 数据手册
RS001-0412 Respiratory Hygiene Station Product Description: • Respiratory Hygiene Station • Holds two boxes of face masks, one - two boxes of facial tissue, and one hand sanitizer bottle or hand sanitizing wipe canister • Keyholes for wall mounting, can sit on a counter, or mount to a floor stand • Quartz Beige Powder-Coated Steel Primary Area for Product Usage: • All ports of entry • Anywhere respiratory hygiene products are needed Dispenses: • Left: Bottles no larger than 4.25"W x 4.00"D or 4.00" diameter (10.8 cm x 10.2 cm) • Middle: Box(es) no larger than 8.00”W x 9.50”H x 4.75”D (20.3 cm x 24.1 cm x 12.1 cm) • Right: Box(es) no larger than 5.50”W x 9.50”H x 4.75”D (13.7 cm x 24.1 cm x 12.1 cm) Package Specifications: • Package Quantity: 3 per case • 20"L x 16"W x 12"H (50.8 cm x 40.6 cm x 30.5 cm) • 17.0 lbs (7.7 kg) - approximated Product Specifications (overall external dimensions): • 17.97"W x 11.78"H x 5.06"D (45.6 cm x 29.9 cm x 12.9 cm) • 4.7 lbs (2.1 kg) - approximated Companion Products (each sold separately): Mounting Specifications: • MP-070: Sign Holder - Vertical (shown below) • MP-075: Sign Holder - Horizontal R.13 (2x) R.25 (2x) 1 .25 8.00 .75 8.75 Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com RS001-0412 Respiratory Hygiene Station Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Versatile design suited for a counter, wall, or stand to encourage use of personal protection and prevent spreading of illnesses. Care and Construction Powder-Coated Steel Material Characteristics Designed for Long-Term Use Our steel dispensers and stands are coated with polyester powders which makes them highly resistant to corrosion. Powder-coated steel is ideal for dispensers used in a healthcare or an industrial setting because it is impact resistant and is not effected by extremes in temperature. Dispensers and stands made of powder-coated steel are both attractive and functional, providing years of service. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning For best results, clean by washing the surface with a diluted solution of a mild, non-abrasive detergent in cold or warm water and a non-abrasive cloth. Standard hospital cleaning supplies can be used. 2 Dry with a soft cloth. Do not use any solvent-based materials, abrasives (e.g. Scotch-brite, steel wool), or apply excessive force during cleaning. Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser RS001-0412 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. RS0010412TDSa
RS001-0412 价格&库存
很抱歉,暂时无法提供与“RS001-0412”相匹配的价格&库存,您可以联系我们找货
