109156
109156
    BRADY
    B681 WHT/GRN STYLE IHV FOOD IND.
109156 数据手册
Technical Data Sheet BRADY B­681 HIGH PERFORMANCE PRESSURE SENSITIVE PIPE MARKER TDS No. B­681 Effective Date: 11/15/2010 Description: Brady B­681 High Performance PSA Pipemarker is a surface printed polyester label with a polyester overlaminate. Details: Use: Brady B­681 is designed for use on stainless steel, B­120 Fiberglass, and any other surfaces for pipemarkers. B­681 is designed for use in Pulp and Paper and Petrochemical environments where excellent chemical and abrasion resistance is required. It can be used indoors and outdoors. Special Properties: Excellent chemical resistance. Can be applied down to 0°F (­18°C). Adhesive Type: Acrylic pressure sensitive Substrate Type: Polyester film with a polyester overlaminate Standard Material Colors: Blue, green, red and yellow Standard Legend Colors: White and black Thickness (PSTC­33): Total: 0.005 in. (0.13mm) Adhesive Properties: Adhesion to Steel (PSTC­1) 15 Minute Dwell (Avg.) ­­ 70 oz/in. (76 N/100mm) Ultimate Dwell (72 Hrs.) (Avg.) ­­ 108 oz/in. (118 N/100mm) Tack (ASTM D 2979) (Avg.) ­­ 1170 g (11 N) Drop Shear (PSTC­7) (Avg.) ­­ 20 Hrs. Abrasion Resistance (Method 5306 of U.S. Federal Test Method Std. No. 191A): CS­17 wheels, 1000 g wts. Polyester laminate withstands up to 1000 cycles. Gloss: 120 Gardner Units Minimum Application Temperature: 0°F (­18°C) Service Temperature: ­40°F to 230°F (­40°C to 110°C) Average Outdoor Durability:   5­8 years (Average expected outdoor life of product will depend on user definition of failure and climatic conditions.)   Chemical Resistance: REAGENT 30% Sulfuric Acid 10% Sulfuric Acid 30% HCI 10% HCI 50% NaOH 10% NaOH Methyl Ethyl Ketone Acetone 1,1,1­Trichloroethane Methanol IPA (Isopropanol) ASTM #3 Oil SAE 20 Oil Alconox® Toluene Mineral Spirits Glacial Acetic Acid 5% Acetic Acid Diesel Fuel Heptane 10% Ammonia Kerosene Water 20% Sodium Carbonate 2% Sodium Carbonate 10% NaCl Bleach 7 DAY IMMERSION NE NE NE NE F F F F F F F NE NE NE F F NE NE F F NE F NE NE NE NE NE DIP TEST NE NE NE NE NE NE F F F NE NE NE NE NE F NE NE NE NE F NE NE NE NE NE NE NE RUB TEST NE NE NE NE NE NE NE NE NE NE NE NE NE NE NE NE NE NE NE NE NE NE NE NE NE NE NE NE = No Effect NT = Not Tested F = Failed (affected Sample) 7 Day Immersion: Immersed in reagent for 7 days. Dip Test: Five 10 minute dips in reagent with 30 minute recovery. Rub Test: Rubbed sample for 1 minute with swab soaked in reagent.   Product testing, customer feedback, and history of similar products, support a customer performance expectation of at least two years from the date of receipt for this product as long as this product is stored in its original packaging in an environment below 80°F (27°C) and 60% RH . We are confident that our product will perform well beyond this time frame. However, it remains the responsibility of the user to assess the risk of using such product. We encourage customers to develop functional testing protocols that will qualify a product's fitness for use in their actual applications. Trademarks: Alconox® is a registered trademark of Alconox Co. Signmark® is a registered trademark of Brady Worldwide, Inc. ASTM: American Society for Testing and Materials (U.S.A.) PSTC: Pressure Sensitive Tape Council (U.S.A.) SAE: Society of Automotive Engineers (U.S.A.) All S.I. Units (metric) are mathematically derived from the U.S. Conventional Units. Note: All values shown are averages and should not be used for specification purposes.  Test data and test results contained in this document are for general information only and shall not be relied upon by Brady customers for designs and specifications, or be relied on as meeting specified performance criteria. Customers desiring to develop specifications or performance criteria for specific product applications should contact Brady for further information. Product compliance information is based upon information provided by suppliers of the raw materials used by Brady to manufacture this product or based on results of testing using recognized analytical methods performed by a third party, independent laboratory. As such, Brady makes no independent representations or warranties, express or implied, and assumes no liability in connection with the use of this information. WARRANTY Brady products are sold with the understanding that the buyers will test them in actual use and determine for themselves their adaptability to their intended uses. Brady warrants to the buyers that its products are free from defects in material and workmanship, but limits its obligation under this warranty to replacement of the product shown to Brady's satisfaction to have been defective at the time Brady sold it. This warranty does not extend to any persons obtaining the product from the buyers. This warranty is in lieu of any other warranty, express or implied, including, but not limited to, any implied warranty of merchantability or fitness for a particular purpose, and of any other obligations or liability on Brady's part. Under no circumstances will Brady be liable for any loss, damage, expense, or consequential damages of any kind arising in connection with the use, or inability to use, Brady's products. Copyright 2016 Brady Worldwide, Inc. | All Rights Reserved Material may not be reproduced or distributed in any form without written permission. Brady North America | 6555 W. Good Hope Rd | Milwaukee, WI 53223 | USA | Tel: 414­358­6600 | Fax: 800­292­2289
109156
物料型号:Brady B-681
器件简介:Brady B-681是一种表面印刷的聚酯标签,带有聚酯覆膜,设计用于不锈钢、B-120玻璃纤维和其他管道标记器表面。适用于需要极好化学和耐磨损性能的纸浆和造纸以及石化环境,可在室内外使用。
引脚分配:文档中未提及引脚分配
参数特性: - 极好的化学抗性,可在0°F(-18°C)下应用。 - 胶粘剂类型:丙烯酸压敏。 - 基材类型:聚酯薄膜,带聚酯覆膜。 - 标准材料颜色:蓝色、绿色、红色和黄色。 - 标准图例颜色:白色和黑色。 - 总厚度:0.005英寸(0.13毫米)。 - 胶粘剂性能:对钢的粘附力(PSTC-1)15分钟平均70盎司/英寸(76牛顿/100毫米),72小时平均108盎司/英寸(118牛顿/100毫米),初始粘附力(ASTM D 2979)平均1170克(11牛顿),剥离剪切(PSTC-7)平均20小时。 - 耐磨损性:CS-17轮,1000克重。聚酯覆膜可承受高达1000次循环。 - 光泽度:120 Gardner单位。 - 最低应用温度:0°F(-18°C)。 - 服务温度:-40°F至230°F(-40°C至110°C)。 - 平均户外耐久性:5-8年。
功能详解:文档中未提供详细的功能解释。
应用信息:Brady B-681设计用于管道标记,适用于纸浆和造纸以及石化环境,这些环境需要出色的化学和耐磨损性能。
封装信息:文档中未提及封装信息
109156 价格&库存
很抱歉,暂时无法提供与“109156”相匹配的价格&库存,您可以联系我们找货
