RS004-0412
RS004-0412
    BOWMAN
    RESPIRATORY HYGIENE STATION
RS004-0412 数据手册
RS004-0412 Respiratory Hygiene Station Product Description: • Respiratory Hygiene Station • Holds two boxes of face masks, one or two boxes of facial tissues or one box of gloves, and one hand sanitizer dispenser • Keyholes and screw holes for wall mounting or can be mounted to a floor stand • Quartz Beige Powder-Coated Steel Primary Area for Product Usage: • All ports of entry • Anywhere respiratory hygiene products are needed Dispenses: • Left: One hand sanitizing gel or foam dispenser no larger than 8.35"W x 14.75"H x 5.00"D (21.2 cm x 37.5 cm x 12.7 cm) • [Note: Refer to automatic dispensing specifications on detection distance requirements.] • Middle: Box(es) no larger than 8.00"W x 9.50"H x 4.75"D (20.3 cm x 24.1 cm x 12.1 cm) • Right: Box(es) no larger than 5.50"W x 9.50"H x 4.75"D (13.7 cm x 24.1 cm x 12.1 cm) Package Specifications: • Package Quantity: 1 per case • 24"L x 16"W x 6"H (61.0 cm x 40.6 cm x 15.2 cm) • 8.0 lbs (3.6 kg) - approximated Product Specifications (overall external dimensions) : KS010-0412, Floor Stand - All Steel KS201-0029, Floor Stand MP-070, Sign Holder - Vertical (shown below) MP-075, Sign Holder - Horizontal (shown below) Mounting Specifications: 3.71 1.33 Ø.19 (2x) 10.50 1.65 Ø.13 (2x) Ø.25 (2x) 1.25 6.75 5.75 • • • • • 22.31"W x 14.78"H x 5.06"D (56.7 cm x 37.5 cm x 12.9 cm) • 5.8 lbs (2.6 kg) - approximated 0.75 Related Products (each sold separately): MP-070 Product Videos: BowmanDispensers.com/Product-Videos MP-075 BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com RS004-0412 Respiratory Hygiene Station Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Attach the empty hand sanitizer dispenser first. • Do NOT load sanitizer until after dispenser is mounted to a wall or stand. Mounting holes for hand sanitizer Care and Construction Powder-Coated Steel Material Characteristics Designed for Long-Term Use Our steel dispensers and stands are coated with polyester powders which makes them highly resistant to corrosion. Powder-coated steel is ideal for dispensers used in a healthcare or an industrial setting because it is impact resistant and is not effected by extremes in temperature. Dispensers and stands made of powder-coated steel are both attractive and functional, providing years of service. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. • It can also be mounted to a BOWMAN® Floor Stand (sold separately). Care and Cleaning The powder coated finish resists common chemicals and cleaning agents and can be easily wiped clean with soap and water. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser RS004-0412 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2018 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. RS0040412TDSa
RS004-0412 价格&库存
很抱歉,暂时无法提供与“RS004-0412”相匹配的价格&库存,您可以联系我们找货
