BXRH-30G300C-D-83
BXRH-30G300C-D-83
    BRIDGELUX(普瑞)
    LED 照明 COB、引擎、模块 板上芯片(COB) Gen 8 V9 HD LED Array 白色,暖色 方形
BXRH-30G300C-D-83 数据手册
Bridgelux Gen 8 V9 HD LED Array ® Product Data Sheet DS408 1 V Series HD Introduction V Series™ HD LED array product, an ultra-high lumen density COB product line, is designed for high intensity spotlights used in commercial and retail settings. V Series HD arrays offer industry leading color over angle uniformity, and replace ceramic metal halide lamps by providing equal or greater center beam candle power at lower power and at greater lifetimes. Their tight beam control and exceptional quality of light is well suited for demanding directional spot applications. The V9 HD LED array is available in a variety of CCT and CRI combinations providing substantial design flexibility and energy efficiencies. Lighting system designs incorporating these LED arrays deliver increased system level efficacy and longer service life. Typical applications include, but are not limited to, commercial and residential down lights, accent, spot and track lights. Bridgelux Décor Series™ is our state of the art color line designed specifically for premium applications, producing unmatched LED light quality with brilliant color-rendering options and offer pleasing and inspiring lighting palettes. Bridgelux Décor Series color points are available on Vero® SE Series, Vero® Series, V Series™ and V Series™ HD. Décor Series™ Ultra products provide a high CRI of 97 and a minimum R9 value of 91, which emphasizes the reds and color tones to which the human eye is most receptive - perfect for the most luxurious retail shops and world renowned museums. Décor Series Ultra is designed as a replacement for halogen. Décor Series™ Showcase is the optimal solution for replacing ceramic metal halide lamps, incorporating the same pure white light with enhanced spectrum coverage and higher efficacy. Features Benefits • Efficacy of 142 lm/W typical • Enhanced optical control • Compact high flux density light source • Clean white light without pixelation • Uniform high quality illumination • High quality true color reproduction • Minimum 80, 90 and 95 CRI options • Significantly reduced thermal resistance and increased operating temperatures • Streamlined thermal path • ENERGY STAR® / ANSI compliant color binning structure with 3 SDCM options • Uniform consistent white light • Lower operating costs • More energy efficient than incandescent, halogen and fluorescent lamps • Easy to use with daylight and motion detectors to enable increased energy savings • Low voltage DC operation • Reduced maintenance costs • Instant light with unlimited dimming • Environmentally friendly, no disposal issue • Vf bin code backside marking Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 European Product Registry for Energy Labeling 5 Performance at Commonly Used Drive Currents 6 Electrical Characteristics 8 Eye Safety 9 Absolute Maximum Ratings 10 Performance Curves 11 Typical Radiation Pattern 13 Typical Color Spectrum 14 Mechanical Dimensions 15 Color Binning Information 16 Packaging and Labeling 17 Design Resources 18 Precautions 18 Disclaimers 18 About Bridgelux 19 1 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V Series HD arrays are the most compact chip-on-board devices across all of Bridgelux’s LED Array products. Designed to comply with global safety standards for creepage and clearance distances The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the V Series HD family of products. Polarity symbols Fully engineered substrate for consistent thermal, mechanical and optical properties White ring around LES Yellow phosphor Light Emitting Surface (LES) Case Temperature (Tc) Measurement Point Solder Pads Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux V Series HD LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRH – 30 E 300 0 – D – 8 3 CCT Bin Options Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K Gen. 8 3 = 3 SDCM Array Configuration CRI E = 80 CRI min. G = 90 CRI min. H = 97 CRI typ. Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted C = Décor Series Showcase Target Flux Indicator 3000x = 3000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRH-27E3000-D-8x 2700 80 700 3416 3075 36.6 25.6 133 BXRH-27G3000-D-8x 2700 90 700 2819 2537 36.6 25.6 110 BXRH-27H3000-D-8x 2700 97 700 2498 2248 36.6 25.6 98 BXRH-30E3000-D-8x 3000 80 700 3630 3267 36.6 25.6 142 BXRH-30G3000-D-8x 3000 90 700 2947 2652 36.6 25.6 115 BXRH-30G300C-D-8x 3000 90 700 2891 2602 36.6 25.6 113 BXRH-30H3000-D-8x 3000 97 700 2669 2402 36.6 25.6 104 145 BXRH-35E3000-D-8x 3500 80 700 3715 3344 36.6 25.6 BXRH-35G3000-D-8x 3500 90 700 3053 2748 36.6 25.6 119 BXRH-35H3000-D-8x 3500 97 700 2744 2469 36.6 25.6 107 BXRH-40E3000-D-8x 4000 80 700 3737 3363 36.6 25.6 146 BXRH-40G3000-D-8x 4000 90 700 3118 2806 36.6 25.6 122 BXRH-40H3000-D-8x 4000 97 700 2819 2537 36.6 25.6 110 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. CRI values are typical for Decor Series Ultra and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, Minimum R9 value is 60 for 90 CRI products on 2700K/3000K/3500K and 4000K, it is 50 on 5000K/5700K and 6500K. But for the CRI90 H0 products (higher efficiency CRI90 version), minimum R9 value is 55 on 2700K/3000K/3500K and 4000K. Minimum R9 value for 97 CRI products is 91 on 2700K and 3000K,and it is 85 on 3500K /4000K/5000K and 5700K. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 3 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6,7 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) BXRH-27E3000-D-8x 2700 80 700 3075 2767 35.4 24.8 124 BXRH-27G3000-D-8x 2700 90 700 2537 2283 35.4 24.8 102 Typical Efficacy (lm/W) BXRH-27H3000-D-8x 2700 97 700 2248 2024 35.4 24.8 91 BXRH-30E3000-D-8x 3000 80 700 3267 2940 35.4 24.8 132 BXRH-30G3000-D-8x 3000 90 700 2652 2387 35.4 24.8 107 BXRH-30G300C-D-8x 3000 90 700 2602 2342 35.4 24.8 105 BXRH-30H3000-D-8x 3000 97 700 2402 2162 35.4 24.8 97 BXRH-35E3000-D-8x 3500 80 700 3344 3009 35.4 24.8 135 BXRH-35G3000-D-8x 3500 90 700 2748 2473 35.4 24.8 111 BXRH-35H3000-D-8x 3500 97 700 2469 2223 35.4 24.8 100 BXRH-40E3000-D-8x 4000 80 700 3363 3027 35.4 24.8 136 BXRH-40G3000-D-8x 4000 90 700 2806 2525 35.4 24.8 113 BXRH-40H3000-D-8x 4000 97 700 2537 2283 35.4 24.8 102 Notes for Table 2: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. CRI values are typical for Decor Series Ultra and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, Minimum R9 value is 60 for 90 CRI products on 2700K/3000K/3500K and 4000K, it is 50 on 5000K/5700K and 6500K. But for the CRI90 H0 products (higher efficiency CRI90 version), minimum R9 value is 55 on 2700K/3000K/3500K and 4000K. Minimum R9 value for 97 CRI products is 91 on 2700K and 3000K,and it is 85 on 3500K /4000K/5000K and 5700K. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 4 European Product Registry for Energy Labeling The European Product Registry for Energy Labeling (EPREL) is defined in the EU Regulation 2017/1369 to provide important energy efficiency information to consumers. Together with Energy Labeling Regulation ELR (EU) 2019/2015 which was amended by regulation (EU) 2021/340 for energy labelling of light sources, manufacturers are required to declare an energy class based on key technical specifications from each of their product and register it in an open data base managed by EPREL It is now a legal requirement for a vendor of light sources to upload information about their products into the EPREL database before placing these products on the market in the EU. Table 3 below provides a list of part numbers that are in compliance with ELR and are currently listed in the EPREL database. At Bridgelux, we are fully committed to supplying products that are compliant with pertinent laws, rules, and obligation imposed by relevant government bodies including the European Energy Labeling regulation. Customers can use these products with full confidence for any projects that fall under the ELR. Table 3: Part numbers registered in European Product Registry for Energy Labeling Current2 (mA) Vf (V) Useful flux3 (Φuse) at 85C (lm) 80 920 34.9 3745 32.1 117 F 875791 https://eprel.ec.europa.eu/qr/875791 90 600 34.4 2177 20.6 106 F 875825 https://eprel.ec.europa.eu/qr/875825 https://eprel.ec.europa.eu/qr/875849 PART NUMBER CCT (K) CRI BXRH-27E3000-D-8x 2700 BXRH-27G3000-D-8x 2700 1 Power (W) Efficacy (lm/W) Energy efficiency class4 Registration No URL to Product Information Sheet in EPREL Database BXRH-27H3000-D-8x 2700 95 440 31.3 1381 13.8 100 F 875849 BXRH-30E3000-D-8x 3000 80 1090 37.9 4784 41.3 116 F 875877 https://eprel.ec.europa.eu/qr/875877 BXRH-30G3000-D-8x 3000 90 690 36.5 2676 25.2 106 F 875929 https://eprel.ec.europa.eu/qr/875929 BXRH-30G300C-D-8x 3000 90 650 35.3 2432 22.9 106 F 875933 https://eprel.ec.europa.eu/qr/875933 BXRH-30H3000-D-8x 3000 95 550 33.3 1872 18.3 102 F 875958 https://eprel.ec.europa.eu/qr/875958 BXRH-35E3000-D-8x 3500 80 1150 37.9 5083 43.6 117 F 875992 https://eprel.ec.europa.eu/qr/875992 BXRH-35G3000-D-8x 3500 90 780 35.3 2971 27.5 108 F 876016 https://eprel.ec.europa.eu/qr/876016 BXRH-40E3000-D-8x 4000 80 1170 37.2 5112 43.6 117 F 876056 https://eprel.ec.europa.eu/qr/876056 BXRH-40G3000-D-8x 4000 90 840 35.5 3228 29.8 108 F 876080 https://eprel.ec.europa.eu/qr/876080 Notes for Table 3: 1. All device listed here must be disposed as e-waste upon its end of life according to local country guideline in each country. 2. For information on performance values at alternative drive conditions. please refer to the Product Selection Guide, Absolute Maximum Rating Table and Performance Curves in this data sheet. 3. For a definition of useful luminous flux (ΦΦuse), please see the ELR regulations at https://tinyurl.com/4b6zvt4m. 4. EPREL requires an arrow symbol containing the letter of the energy efficiency class to be displayed. on technical promotional material. Refer to this energy efficiency class column for specific energy efficiency class on each part number. 5 Performance at Commonly Used Drive Currents V Series HD LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series HD LED arrays may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figure 1 and the flux vs. current characteristics shown in Figure 2. The performance at commonly used drive currents is summarized in Table 4. Table 4: Product Performance at Commonly Used Drive Currents Part Number CRI BXRH-27E3000-D-8x 80 BXRH-27G3000-D-8x 90 BXRH-27H3000-D-8x 97 BXRH-30E3000-D-8x 80 BXRH-30G3000-D-8x 90 BXRH-30G300C-D-8x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 350 500 700 875 960 1200 350 500 700 875 960 1200 350 500 700 875 960 1200 350 500 700 875 960 1200 350 500 700 875 960 1200 350 500 700 875 960 1200 34.2 35.3 36.6 37.7 38.2 39.5 34.2 35.3 36.6 37.7 38.2 39.5 34.2 35.3 36.6 37.7 38.2 39.5 34.2 35.3 36.6 37.7 38.2 39.5 34.2 35.3 36.6 37.7 38.2 39.5 34.2 35.3 36.6 37.7 38.2 39.5 12.0 17.7 25.6 33.0 36.7 47.4 12.0 17.7 25.6 33.0 36.7 47.4 12.0 17.7 25.6 33.0 36.7 47.4 12.0 17.7 25.6 33.0 36.7 47.4 12.0 17.7 25.6 33.0 36.7 47.4 12.0 17.7 25.6 33.0 36.7 47.4 1813 2525 3416 4149 4487 5379 1496 2083 2819 3423 3702 4438 1326 1846 2498 3034 3281 3933 1927 2683 3630 4408 4767 5715 1564 2178 2947 3579 3870 4639 1535 2136 2891 3511 3797 4552 1632 2272 3075 3734 4038 4841 1346 1875 2537 3081 3331 3994 1193 1662 2248 2731 2953 3540 1734 2414 3267 3968 4290 5143 1408 1960 2652 3221 3483 4175 1381 1923 2602 3160 3418 4097 151 143 133 126 122 114 125 118 110 104 101 94 111 105 98 92 89 83 161 152 142 133 130 121 131 123 115 108 105 98 128 121 113 106 103 96 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 6 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (continued) Part Number CRI BXRH-30H3000-D-8x 97 BXRH-35E3000-D-8x 80 BXRH-35G3000-D-8x 90 BXRH-35H3000-D-8x 97 BXRH-40E3000-D-8x 80 BXRH-40G3000-D-8x 90 BXRH-40H3000-D-8x 97 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 350 500 700 875 960 1200 350 500 700 875 960 1200 350 500 700 875 960 1200 350 500 700 875 960 1200 350 500 700 875 960 1200 350 500 700 875 960 1200 350 500 700 875 960 1200 34.2 35.3 36.6 37.7 38.2 39.5 34.2 35.3 36.6 37.7 38.2 39.5 34.2 35.3 36.6 37.7 38.2 39.5 34.2 35.3 36.6 37.7 38.2 39.5 34.2 35.3 36.6 37.7 38.2 39.5 34.2 35.3 36.6 37.7 38.2 39.5 34.2 35.3 36.6 37.7 38.2 39.5 12.0 17.7 25.6 33.0 36.7 47.4 12.0 17.7 25.6 33.0 36.7 47.4 12.0 17.7 25.6 33.0 36.7 47.4 12.0 17.7 25.6 33.0 36.7 47.4 12.0 17.7 25.6 33.0 36.7 47.4 12.0 17.7 25.6 33.0 36.7 47.4 12.0 17.7 25.6 33.0 36.7 47.4 1417 1972 2669 3241 3505 4202 1972 2746 3715 4512 4879 5849 1621 2257 3053 3708 4010 4807 1456 2028 2744 3332 3603 4320 1983 2761 3737 4538 4907 5883 1655 2304 3118 3786 4094 4908 1496 2083 2819 3423 3702 4438 1275 1775 2402 2917 3155 3782 1775 2471 3344 4061 4391 5265 1459 2031 2748 3337 3609 4327 1311 1825 2469 2999 3243 3888 1785 2485 3363 4084 4417 5295 1489 2073 2806 3407 3685 4417 1346 1875 2537 3081 3331 3994 118 112 104 98 96 89 165 156 145 137 133 123 135 128 119 112 109 101 122 115 107 101 98 91 166 156 146 137 134 124 138 130 122 115 112 104 125 118 110 104 101 94 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 7 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Minimum Typical Maximum 700 33.9 36.6 39.3 -20.00 1200 36.5 39.5 42.5 -21.58 Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.55 32.3 40.6 0.66 34.8 43.9 BXRH-xxx300x-D-8x Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2018. This product has passed dielectric withstand voltage testing at 500 V. The working voltage designated for the insulation is 50V d.c. The maximum allowable voltage across the array must be determined in the end product application. 8 Eye Safety Table 6: Eye Safety Risk Group (RG) Classifications Part Number CCT1,4 Drive Current (mA) 2700K/3000K2 4000K3 700 RG1 RG2 1200 RG2 RG2 BXRH-xxx300x-D-8x Notes for Table 6: 1. Eye safety classification for the use of Bridgelux V Series HD LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 3000K, Ethr= 2670 lx. 3. For products classified as RG2 at 4000K, Ethr= 1760 lx. 4. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 9 Absolute Maximum Ratings Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 125°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds BXRH-xxx300x-D-8x Maximum Drive Current3 1200 mA Maximum Peak Pulsed Drive Current4 1360 mA Maximum Reverse Voltage5 -60V Notes for Table 7: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN101: Handling and Assembly of Bridgelux V Series LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced and warranty will not apply. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 10 Performance Curves Figure 1: V9D HD Drive Current vs. Voltage (Tj = Tc = 25°C)1 Figure 2: V9D HD Typical Relative Luminous Flux vs. Drive Current (Tj = Tc = 25°C)1 40.0 180% Relative Luminous Flux (%) 39.0 Voltage (V) 38.0 37.0 36.0 35.0 34.0 160% 140% 120% 100% 80% 60% 40% 20% 33.0 0 300 600 900 1200 0% 1500 0 300 Drive Current (mA) 600 900 1200 1500 Drive Current (mA) Figure 4: Typical DC ccx Shift vs. Case Temperature Figure 3: Typical DC Flux vs. Case Temperature 102% 0.0010 25℃ Pulsed 0.0008 98% 0.0006 96% 0.0004 94% ccx shift Relative Luminous Flux 100% 92% 90% 0.0002 0.0000 -0.0002 88% -0.0004 86% -0.0006 -0.0008 84% 0 20 40 60 80 100 0 120 20 Figure 5: Typical DC ccy Shift vs. Case Temperature 60 80 100 120 Figure 6: Derating Curve 0.0010 1,400 0.0000 Drive Current (mA) 1,200 -0.0010 ccy shift 40 Case Temperature (Tc) Case Temperature (Tc) -0.0020 -0.0030 -0.0040 1,000 800 600 400 BXRH-xxx300x-D-8x 200 -0.0050 0 -0.0060 0 20 40 60 80 Case Temperature (Tc) 100 120 0 20 40 60 80 100 120 Case Temperature (Tc) Notes for Figures 1 - 4: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Characteristics shown for 3000K and 90 CRI. 11 Typical Radiation Pattern Figure 7: Typical Spatial Radiation Pattern Notes for Figure 7: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 8: Typical Polar Radiation Pattern 12 Typical Color Spectrum Figure 9: Typical Color Spectrum 100% 27E 30E 90% 40E Relative Spectral Power Distribution 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Notes for Figure 9: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 2700K and 80 CRI. 3. Color spectra shown is 3000K and 80 CRI. 4. Color spectra shown is 4000K and 80 CRI. Figure 10: Typical Color Spectrum for Décor Series 100% 27H 90% 30H 30G (Décor Series Showcase) Relative Spectral Power Distribution 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Note for Figure 10: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 13 Mechanical Dimensions Figure 11: Drawing for V9 HD LED Array Notes for Figure 11: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Solder pads are labeled “+” and “-“ to denote positive and negative polarity, respectively. 4. Unless otherwise specified, tolerances are ±0.1mm. 5. Refer to Application Notes AN101 for product handling, mounting and heat sink recommendations. 6. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 7. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 14 Color Binning Information Figure 12: Warm and Neutral White Test Bins in xy Color Space Note: Pulsed Test Conditions, Tc = 25°C Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K 3500K 4000K ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 83 (3 SDCM) (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 82 (2 SDCM) (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) (0.4465, 0.4024)2 (0.4073, 0.3917) (0.3818, 0.3797) Note for Table 8: 1. Bridgelux maintains a tolerance of +/- 0.007 on x and y color coordinates in the CIE 1931 color Space. 2. Center Point for Decor Series Showcase. 15 Packaging and Labeling Figure 13: V9 HD Packaging Tube BXRH-30E3000-D-83 25 960 Notes for Figure 13: 1. Each tube holds 25 V9 HD COB arrays. 2. One tube is sealed in an anti-static bag. Four bags are placed in a shipping box. Depending on quantities ordered, a bigger shipping box, containing four boxes may be used to ship products. 3. Each bag and box is to be labeled as shown above. 4. Dimensions for each tube are 21.3 (W) x 9.5 (H) x 505 (L) mm. Dimensions for the anti-static bag are 100 (W) x 625 (L) x 0.075 (T) mm. Dimensions for the shipping box are 58.7 x 13.3 x 7.9 cm 16 Packaging and Labeling Figure 14: V Series HD Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E3000D 83 Internal Bin Code 17 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the V Series product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux V Series HD LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representatives for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN101 for additional information. CAUTION: RISK OF BURN Do not touch the V Series HD LED array during operation. Allow the array to cool for a sufficient period of time before handling. The V Series HD LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 18 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46410 Fremont Boulevard Fremont, CA 94538 USA Tel (925) 583-8400 www.bridgelux.com © 2021 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design, Vero, V Series and V Series HD are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Gen 8 V9 HD Array Series Product Data Sheet DS408 Rev. C (03/2022) 19
BXRH-30G300C-D-83 价格&库存
很抱歉,暂时无法提供与“BXRH-30G300C-D-83”相匹配的价格&库存,您可以联系我们找货
BXRH-30G300C-D-83
  • 1+48.665961+6.29263
  • 10+36.3771910+4.70366
  • 100+29.13540100+3.76728
  • 500+26.38524500+3.41168
库存:595
