BXRH-30S0601-A-73
BXRH-30S0601-A-73
    BRIDGELUX(普瑞)
    LED 照明 COB、引擎、模块 板上芯片(COB) V4 HD Thrive™ Array 白色,暖色 方形
BXRH-30S0601-A-73 数据手册
PR EL ® IM INA Bridgelux V4 HD Thrive™ Array Product Data Sheet DS405 RY | | | | | | 1 BXRH-27S 30S 35S 40S 50S 57S 65S V4 HD Thrive Introduction PR Bridgelux Thrive™ combines unique chip, phosphor and packaging technology to closely match the spectra of natural EL light over the visible wavelength range. Thrive can be used in constant color point luminaires to bring full spectrum natural light indoors or in tunable white luminaires to incorporate circadian elements that may impact human well-being. The high fidelity spectral output of Thrive creates stunning environments with excellent color rendering and outstanding TM30 metrics. Thrive is available in both SMD components and LED arrays to enable a broad range of lighting applications including retail, hospitality, office, education, architectural, museums, healthcare and residential lighting. Features IM Benefits • Engineered spectrum to closely match natural light • CRI >95, R1-R15 >90, high Rf and Rg values • High efficacy full spectrum solution • No violet chip augmentation • Hot color targeted • Full consistent spectrum with fewer spectral spikes INA • Form factor consistent with existing Bridgelux COB arrays • Broad product platform availability (SMDs and COBs) • Natural and vivid color rendering • Greater energy savings, lower utility costs • Economical, high efficiency solution • Uniform and consistent white light at application conditions • Ease of design and rapid go-to-market • Enables greater design flexibility and platform color consistency RY PR Contents EL Product Feature Map 2 Product Nomenclature 2 Product Selection Guide Spectrum Characteristics Electrical Characteristics Absolute Maximum Ratings Eye Safety Product Bin Definitions Performance Curves Typical Radiation Pattern Mechanical Dimensions Packaging and Labeling Design Resources Precautions Disclaimers About Bridgelux IM 3 5 8 9 INA 10 11 12 13 14 15 17 RY 17 17 18 1 PR Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V Series HD arrays are the most compact chip-on-board devices across all of EL Bridgelux’s LED Array products. The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the V Series HD family of products. Designed to comply with global safety standards for creepage and clearance distances Solder Pads IM Fully engineered substrate for consistent thermal, mechanical and optical properties Yellow phosphor Light Emitting Surface (LES) Case Temperature (Tc) Measurement Point White ring around LES INA Polarity symbols Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux COB arrays is explained as follows: 1 2 3 4 – 5 6 7 8 9 10 11 – 12 – 13 14 BXRH – 30 S 0601 – A – 7 3 Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Gen 7 RY Array Configuration Flux Indicator 0601 = 600 lm Minimum CRI S = Thrive CCT Bin Options 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM 2 PR Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tc= 25°C) EL Typical Pulsed Flux4,5,6,7 Tc = 25ºC (lm) Minimum Pulsed Flux6,7,8 Tc = 25ºC (lm) Typical Power (W) Typical Efficacy (lm/W) 36.4 548 482 6.4 86 36.4 586 516 6.4 92 Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Vf (V) BXRH-27S0601-A-7X 2700 98 175 BXRH-30S0601-A-7X 3000 98 175 Part Number1,6 BXRH-35S0601-A-7X 3500 98 175 36.4 618 544 6.4 97 BXRH-40S0601-A-7X 4000 98 175 36.4 650 572 6.4 102 BXRH-50S0601-A-7X 5000 98 175 36.4 675 594 6.4 106 98 175 36.4 675 594 6.4 106 98 175 36.4 682 600 6.4 107 BXRH-57S0601-A-7X 5700 BXRH-65S0601-A-7X 6500 IM Table 2: Selection Guide, Stabilized DC Test Performance (Tc= 85°C)4,5,6 Part Number1,6 Nominal CCT1 (K) BXRH-27S0601-A-7X 2700 BXRH-30S0601-A-7X 3000 BXRH-35S0601-A-7X 3500 BXRH-40S0601-A-7X 4000 BXRH-50S0601-A-7X 5000 BXRH-57S0601-A-7X 5700 BXRH-65S0601-A-7X 6500 CRI2 Nominal Drive Current3 (mA) Typical Vf (V) Typical DC Flux4,5,6,7 Tc = 85ºC (lm) Minimum DC Flux6,7,8,9 Tc = 85ºC (lm) Typical Power (W) Typical Efficacy (lm/W) 98 175 35.4 493 434 6.2 80 98 175 98 175 98 175 98 175 98 175 98 175 INA 35.4 527 464 6.2 85 35.4 556 489 6.2 90 35.4 585 515 6.2 94 35.4 608 535 6.2 98 35.4 608 535 6.2 98 35.4 613 540 6.2 99 RY Notes for Table 1 & 2: 1. Product CCT is hot targeted at Tj= 85°C. Nominal CCT as defined by ANSI C78.377-2011. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical values. Minimum CRI for Thrive products is 95. Bridgelux maintains a ± 3 tolerance on CRI values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Bridgelux maintains a ±7% tolerance on flux measurements. 8. Minimum flux values at the nominal test current are guaranteed by 100% test. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 3 PR Performance at Commonly Used Drive Currents V Series HD Thrive LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series HD Thrive LED Arrays may also be driven at other drive currents dependent on specific application design requirements. EL The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 10 & 11 and the flux vs. current characteristics shown in Figures 12 & 13. The performance at commonly used drive currents is summarized in Table 3. Table 3: Product Performance at Commonly Used Drive Currents Part Number BXRH-27S0601-A-7x BXRH-30S0601-A-7x BXRH-35S0601-A-7x BXRH-40S0601-A-7x BXRH-50S0601-A-7x BXRH-57S0601-A-7x BXRH-65S0601-A-7x CRI 95 95 95 95 95 95 95 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) IM Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 99 85 34.1 2.9 286 258 130 35.3 4.6 422 380 92 175 36.4 6.4 548 493 86 220 37.3 8.2 666 599 81 240 37.8 9.1 716 644 79 2.9 306 85 34.1 276 106 130 35.3 4.6 451 406 98 175 36.4 6.4 586 527 92 220 37.3 8.2 712 641 87 240 37.8 9.1 765 689 84 INA 85 34.1 2.9 323 291 111 130 35.3 4.6 476 428 104 97 175 36.4 6.4 618 556 220 37.3 8.2 751 676 91 240 37.8 9.1 807 726 89 85 34.1 2.9 340 306 117 130 35.3 4.6 500 450 109 585 102 175 36.4 6.4 650 220 37.3 8.2 790 240 37.8 9.1 849 85 34.1 2.9 353 130 35.3 4.6 520 175 36.4 6.4 675 220 37.3 8.2 820 240 37.8 9.1 881 85 34.1 2.9 353 130 35.3 4.6 520 175 36.4 6.4 675 220 37.3 8.2 820 240 37.8 9.1 881 85 34.1 2.9 356 130 35.3 4.6 525 175 36.4 6.4 682 220 37.3 8.2 828 240 37.8 9.1 890 RY 711 96 764 94 318 122 468 113 608 106 738 100 793 97 318 122 468 113 608 106 738 100 793 97 321 123 473 114 614 107 746 101 801 98 Notes for Table 3: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 4 PR Spectrum Characteristics Table 4: Typical Color Rendering Index and TM-30 Values at, Tc=85°C Nominal CCT1 2700K 3000K 3500K 4000K 5000K 5700K 6500K EL Note for Table 4: Rf Rg R1 R2 R3 R4 R5 R6 R7 R8 R9 R10 R11 R12 R13 R14 R15 95 103 97 99 94 94 97 98 97 98 99 97 91 98 98 95 98 95 104 98 99 93 94 97 98 96 96 97 96 92 95 98 95 97 95 98 98 98 97 98 98 98 98 97 93 97 97 95 98 97 98 97 100 99 99 97 99 99 99 99 98 94 97 99 96 99 98 98 97 100 98 99 98 98 98 98 99 98 95 98 98 98 98 98 97 94 98 98 98 97 95 98 97 96 95 92 97 96 96 98 98 97 95 98 98 98 97 96 98 98 96 96 93 97 96 97 98 98 97 IM 1. Bridgelux maintains a tolerance of ± 3 on Color Rendering Index R1-R15 measurements and TM-30 measurements. Figure 1: 2700K Thrive TM-30 Graphs Figure 2: 3000K Thrive TM-30 Graphs Figure 3: 3500K Thrive TM-30 Graphs INA RY 5 PR Spectrum Characteristics Figure 4: 4000K Thrive TM-30 Graphs EL IM Figure 5: 5000K Thrive TM-30 Graphs Figure 6: 5700K Thrive TM30 Graphs Figure 7: 6500K Thrive TM-30 Graphs INA RY 6 PR Spectrum Characteristics Figure 8: Typical Color Spectrum 100% 80% 60% 40% 20% 0% 380 EL Note for Figure 8: 430 480 530 580 100% 2700K 3000K 3500K 4000K IM Relative Radiant Power(%) Relative Radiant Power (%) 120% 630 680 Wavelength (nm) 1. Color spectra measured at nominal current for Tc = 85°C. Spectral Matching to Natural Light 730 5000K 5700K 6500K 80% 60% 40% 20% 0% 780 350 400 450 500 550 600 650 700 750 800 Wavelength(nm) INA The lighting market is in the early stages of adoption of human-centric lighting (HCL). HCL encompasses the effects of lighting on the physical and emotional health and well-being of people. Throughout evolution, the human visual system has evolved under the natural light of sun and fire. These light sources have standardized industry spectral power definitions that describe the state of natural light. However, conventional metrics such as CCT, CRI, and TM-30 fail to adequately quantify the naturalness, or closeness of these light sources to the standardized natural spectra. Due to a lack of an industry standard metric to quantitatively measure the naturalness of a light source, Bridgelux has pioneered a new metric that takes the guesswork out of comparing LED light sources to natural light. Average Spectral Difference, or ASD, is calculated by measuring the absolute difference between two spectra at discrete wavelengths. These values are averaged across a wavelength range derived from the photopic response curve, or V(λ); a luminous efficiency function describing the average spectral sensitivity of human perception of brightness. The range of 425nm to 690nm was selected to remove the tails of the V(λ) gaussian distribution below 1% of the peak value at 555nm, covering 99.9% of the area under the photopic response curve. Natural light is defined following the approach of IES TM-30; black body curves for light sources of ≤4000K and the CIE standard illuminant D for light sources of ≥ 5000K. RY Natural light has an ASD of 0%; lower ASD values indicate a closer match to natural light. Thrive is engineered to provide the closest match to natural light available using proprietary chip, phosphor and packaging technology, resulting in an ASD between 8% to 10% for all CCTs. By comparison, standard 80, 90, and 98 CRI light sources have ASD values that are 100% to 300% larger than Thrive. To learn more about the ASD metric, please review the Bridgelux whitepaper: Average Spectral Difference, a new method to make objective comparisons of naturalness between light sources; or contact your Bridgelux sales representative. 7 PR Electrical Characteristics Table 5: Electrical Characteristics EL Part Number BXRH-xxx060x-A-73 Notes for Table 5: Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Drive Current (mA) 175 240 Minimum Typical IM Maximum Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 34.1 36.4 39.1 -15.5 0.72 32.9 40.1 35.2 37.8 40.4 -15.5 0.77 34.0 41.4 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. INA 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 500 V. The working voltage designated for the insulation is 50V d.c. The maximum allowable voltage across the array must be determined in the end product application. RY 8 PR Absolute Maximum Ratings Table 6: Maximum Ratings EL Parameter Maximum Rating LED Junction Temperature (Tj) 125°C Storage Temperature -40°C to +105°C IM Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds Maximum Drive Current3 240mA Maximum Peak Pulsed Drive Current4 Maximum Reverse Voltage5 Notes for Table 6: INA 340mA -60V 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN101: Handling and Assembly of Bridgelux V Series LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced, and product warranty will be void. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. RY 9 PR Eye Safety Table 7: Eye Safety Risk Group (RG) Classifications EL Part Number BXRH-xxx060x-A-73 CCT1,3 Drive Current3 (mA) 2700K/3000K 4000K2 175 RG1 RG2 240 RG1 RG2 Notes for Table 5: 1. Eye safety classification for the use of Bridgelux V Series HD LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1760 lx. 3. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. IM INA RY 10 PR Product Bin Definitions Table 8: 2-, 3- and 4-step MacAdam Ellipse Color Bin Definitions CCT 2700K 3000K 4000K 5000K 5700K 6500K EL Center Point Degree 2-step 3-step 4-step x y Φ(°) a b a b a b 0.4578 0.4101 53.700 0.00540 0.00280 0.0081 0.0042 N/A N/A 0.4338 0.403 53.217 0.00556 0.00272 0.0083 0.0041 N/A N/A 0.3818 0.3797 53.717 0.00626 0.00268 0.0094 0.0040 N/A N/A 0.3447 0.3553 59.617 N/A N/A 0.0082 0.0035 0.0110 0.0047 0.3287 0.3417 59.060 N/A N/A 0.0074 0.0032 0.0099 0.0042 0.3123 0.3282 58.567 N/A N/A 0.0066 0.0028 0.0090 0.0038 IM Notes for Table 8: 1. Color binning at Tc=85°C INA 2. Bridgelux maintains a tolerance of ± 0.007 on x and y color coordinates in the CIE 1931 color space. Figure 9: C.I.E. 1931 Chromaticity Diagram (Color targeted at Tc=85°C) 0.44 0.39 3 SDCM 4 SDCM 2 SDCM 0.38 2700K 3 SDCM 0.42 3000K 0.37 3500K 0.36 0.4 0.35 Y Y 4000K 0.38 6500K 0.34 0.33 0.36 0.32 0.34 0.36 0.31 0.39 0.42 0.45 X 0.48 0.3 0.3 0.31 0.32 RY 5000K 5700K 0.33 0.34 0.35 0.36 0.37 X 11 PR Performance Curves Figure 10: Drive Current vs. Voltage2 EL 200 150 100 50 0 32 33 34 120% IM 35 36 Forward Voltage (Vf) 37 38 Relative Luminous Flux 100% 97% 94% 91% 88% 85% 82% 0 25 50 Warm White Neutral White Cool White 25°C Pulsed 75 100 125 100% 80% 60% 40% 20% 0% 0 39 Figure 12: Typical DC Flux vs. Case Temperature3 103% Relative Luminous Flux 250 140% 50 20 40 60 300 INA 0 20 40 60 80 100 120 -0.0010 -0.0020 -0.0030 -0.0040 -0.0050 -0.0060 -0.0070 -0.0080 -0.0090 80 100 120 RY 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Characteristics shown for warm white based on 3000K Thrive 0.0000 3. Characteristics shown for neutral white based on 4000K Thrive -0.0010 ccy shift 250 0.0000 Notes for Figures 12-14: 0 200 Case Temperature (Tc) Figure 14: Typical DC ccy Shift vs. Case Temperature4 0.0010 150 Figure 13: Typical DC ccx Shift vs. Case Temperature4 -0.0100 Case Temperature (°C) 100 Drive Current (mA) ccx shift 300 Forward Current (mA) Figure 11: Typical Relative Flux vs. Current1,2 4. Characteristics shown for cool white based on 5000K Thrive -0.0020 5. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. -0.0030 -0.0040 -0.0050 -0.0060 Case Temperature (Tc) 12 PR Typical Radiation Pattern Figure 15: Typical Spatial Radiation Pattern EL Notes for Figure 15: 1. Typical viewing angle is 120⁰. IM INA 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 16: Typical Polar Radiation Pattern RY 13 PR Mechanical Dimensions Figure 17: Drawing for V4 HD LED Array EL Notes for Figure 17: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. IM 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Solder pad labeled “+” denotes positive contact. INA 5. Refer to Application Notes AN101 for product handling, mounting and heat sink recommendations. RY 6. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 7. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 14 PR Packaging and Labeling Figure 18: V4 HD Packaging Tube EL IM Notes for Figure 18: 1. Each tube holds 40 V4 HD COB arrays. INA RY 2. One tube is sealed in an anti-static bag. Four bags are placed in a shipping box. Depending on quantities ordered, a bigger shipping box, containing four boxes may be used to ship products. 3. Each bag and box is to be labeled as shown above. 4. Dimensions for each tube are 14.3 (W) x 8.3(H) x 530 (L) mm. Dimensions for the anti-static bag are 75 (W) x 615 (L) x 0.075 (T) mm. Dimensions for the shipping box are 58.7 x 13.3 x 7.9 cm 15 PR Packaging and Labeling Figure 21: V Series HD Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In EL addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. IM Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30S0601A 73 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. INA RY 16 PR Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the V Series HD product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux V Series HD LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. EL Precautions IM CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN101 for additional information. CAUTION: RISK OF BURN Do not touch the V Series HD LED array during operation. Allow the array to cool for a sufficient period of time before handling. The V Series HD LED array may reach elevated temperatures such that could burn skin when touched. Disclaimers INA CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). RY MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 17 PR About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. EL IM For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux linkedin.com/company/bridgelux-inc-_2 youtube.com/user/Bridgelux WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 USA Tel (925) 583-8400 www.bridgelux.com INA RY © 2020 Bridgelux, Inc. Product specifications are subject to change without notice. Bridgelux and the Bridgelux stylized logo design are registered trademarks of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux V4 HD Thrive Array Product Data Sheet DS405 Rev. A (06/2020) 18
BXRH-30S0601-A-73 价格&库存
很抱歉,暂时无法提供与“BXRH-30S0601-A-73”相匹配的价格&库存,您可以联系我们找货
