BXRE-57S0801-E-74
BXRE-57S0801-E-74
    BRIDGELUX(普瑞)
    LED 照明 COB、引擎、模块 板上芯片(COB) V8 Thrive™ Array 白色,冷色 方形
BXRE-57S0801-E-74 数据手册
PR EL ® IM INA Bridgelux V8 Thrive™ Array Product Data Sheet DS323 RY | | | | | | 1 BXRE-27S 30S 35S 40S 50S 57S 65S V8 Thrive Introduction PR Bridgelux Thrive™ combines unique chip, phosphor and packaging technology to closely match the spectra of natural EL light over the visible wavelength range. Thrive can be used in constant color point luminaires to bring full spectrum natural light indoors or in tunable white luminaires to incorporate circadian elements that may impact human well-being. The high fidelity spectral output of Thrive creates stunning environments with excellent color rendering and outstanding TM30 metrics. Thrive is available in both SMD components and LED arrays to enable a broad range of lighting applications including retail, hospitality, office, education, architectural, museums, healthcare and residential lighting. Features IM Benefits • Engineered spectrum to closely match natural light • CRI >95, R1-R15 >90, high Rf and Rg values • High efficacy full spectrum solution • No violet chip augmentation • Hot color targeted • Form factor consistent with existing Bridgelux COB arrays • Full consistent spectrum with fewer spectral spikes INA • Broad product platform availability (SMDs and COBs) • Natural and vivid color rendering • Greater energy savings, lower utility costs • Economical, high efficiency solution • Uniform and consistent white light at application conditions • Ease of design and rapid go-to-market • Enables greater design flexibility and platform color consistency RY PR Contents EL Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Spectrum Characteristics 6 Electrical Characteristics 9 Absolute Maximum Ratings Eye Safety Product Bin Definitions Performance Curves Typical Radiation Pattern Mechanical Dimensions Packaging and Labeling Design Resources Precautions Disclaimers About Bridgelux IM 10 11 12 13 INA 15 16 17 19 19 19 RY 20 1 Product Feature Map PR Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V Series arrays are the most compact chip-on-board devices across all of Bridgelux’s LED Array products. The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the V Series family of products. EL Polarity symbols Solder pads Case Temperature (Tc) Measurement Point Yellow phosphor Light Emitting Surface (LES) IM White ring around LES Fully engineered substrate for consistent thermal, mechanical and optical properties INA Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux COB arrays is explained as follows: 1 2 3 4 – 5 6 7 8 9 10 11 – 12 – 13 14 BXRE – 30 S 0801 – D – 7 3 Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Gen 7 RY Array Configuration Flux Indicator 0801 = 800 lm Minimum CRI S = Thrive CCT Bin Options 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM 2 Product Selection Guide PR The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tc= 25°C) Part Number1,6 Nominal CCT1 (K) CRI 2 EL Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6,7 Tc = 25ºC (lm) Typical Vf (V) Minimum Pulsed Flux6,7,8 Tc = 25ºC (lm) Typical Power (W) Typical Efficacy (lm/W) Typical Photosynthetic Photon Flux (PPF) Typical Photon Efficiency (µmol/J) BXRE-27S0801-D-7X 2700 98 350 17.2 630 554 6.0 105 11.51 1.91 BXRE-27S0801-E-7X 2700 98 175 34.4 630 554 6.0 105 11.51 1.91 BXRE-30S0801-D-7X 3000 98 350 17.2 677 596 6.0 112 11.77 1.96 BXRE-30S0801-E-7X 3000 98 175 34.4 677 596 6.0 112 11.77 1.96 BXRE-35S0801-D-7X 3500 98 350 17.2 728 641 6.0 121 11.90 1.98 BXRE-35S0801-E-7X 3500 98 BXRE-40S0801-D-7X 4000 98 BXRE-40S0801-E-7X 4000 98 BXRE-50S0801-D-7X 5000 98 BXRE-50S0801-E-7X 5000 98 BXRE-57S0801-D-7X 5700 98 BXRE-57S0801-E-7X 5700 98 BXRE-65S0801-D-7X 6500 98 BXRE-65S0801-E-7X 6500 98 175 34.4 728 641 6.0 121 11.90 1.98 350 17.2 740 652 6.0 123 12.33 2.05 175 34.4 740 652 6.0 123 12.33 2.05 350 17.2 777 683 6.0 129 12.35 2.05 175 34.4 777 683 6.0 129 12.35 2.05 IM 350 17.2 789 694 6.0 131 13.20 2.19 175 34.4 789 694 6.0 131 13.20 2.19 350 17.2 771 678 6.0 128 12.60 2.09 175 34.4 771 678 6.0 128 12.60 2.09 INA Table 2: Selection Guide, Stabilized DC Test Performance (Tc= 85°C)4,5,6 Typical Vf (V) Typical DC Flux4,5,6,7 Tc = 85ºC (lm) Minimum DC Flux6,7,8,9 Tc = 85ºC (lm) Typical Power (W) Typical Efficacy (lm/W) Typical Photosynthetic Photon Flux (PPF) Typical Photon Efficiency (µmol/J) 350 16.7 567 499 5.8 97 10.79 1.83 175 33.4 567 499 5.8 97 10.79 1.83 609 536 5.8 104 10.97 1.86 609 536 5.8 104 10.97 1.86 656 577 5.8 112 11.62 1.97 Part Number1,6 Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) BXRE-27S0801-D-7X 2700 98 BXRE-27S0801-E-7X 2700 98 BXRE-30S0801-D-7X 3000 98 BXRE-30S0801-E-7X 3000 98 BXRE-35S0801-D-7X 3500 98 350 16.7 175 33.4 350 16.7 BXRE-35S0801-E-7X 3500 98 175 33.4 BXRE-40S0801-D-7X 4000 98 350 16.7 BXRE-40S0801-E-7X 4000 98 175 33.4 BXRE-50S0801-D-7X 5000 98 350 16.7 BXRE-50S0801-E-7X 5000 98 175 33.4 BXRE-57S0801-D-7X 5700 98 350 16.7 BXRE-57S0801-E-7X 5700 98 175 33.4 BXRE-65S0801-D-7X 6500 98 350 16.7 BXRE-65S0801-E-7X 6500 98 175 33.4 RY 656 577 5.8 112 11.62 1.97 666 586 5.8 114 11.79 2.00 666 586 5.8 114 11.79 2.00 699 615 5.8 120 11.85 2.01 699 615 5.8 120 11.85 2.01 710 625 5.8 121 12.30 2.09 710 625 5.8 121 12.30 2.09 694 610 5.8 119 12.11 2.05 694 610 5.8 119 12.11 2.05 Notes for Table 1 & 2: 1. Product CCT is hot targeted at Tj= 85°C. Nominal CCT as defined by ANSI C78.377-2011. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical values. Minimum CRI for Thrive products is 95. Bridgelux maintains a ± 3 tolerance on CRI values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Bridgelux maintains a ±7% tolerance on flux measurements. 8. Minimum flux values at the nominal test current are guaranteed by 100% test. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 3 Performance at Commonly Used Drive Currents PR V Series Thrive LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series Thrive LED Arrays may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 10 & 11 and the flux vs. current characteristics shown in Figures 12 & 13. The performance at commonly used drive currents is summarized in Table 3. EL Table 3: Product Performance at Commonly Used Drive Currents Part Number BXRE-27S0801-D-7x BXRE-27S0801-E-7x BXRE-30S0801-D-7x BXRE-30S0801-E-7x BXRE-35S0801-D-7x BXRE-35S0801-E-7x BXRE-40S0801-D-7x BXRE-40S0801-E-7x CRI 98 98 98 98 98 98 98 98 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 175 16.6 2.9 325 293 112 250 16.9 4.2 458 412 108 IM 350 17.3 6.1 630 567 104 500 17.8 8.9 875 787 98 700 18.4 12.9 1179 1061 91 88 33.0 2.9 326 294 112 125 33.9 4.2 459 413 108 175 34.7 6.1 630 567 104 98 250 35.5 8.9 874 787 350 36.8 12.9 1179 1061 92 175 16.6 2.9 349 314 120 250 16.9 350 17.3 500 17.8 700 18.4 88 33.0 125 33.9 175 34.7 250 35.5 350 36.8 175 16.6 250 16.9 350 17.3 500 17.8 700 18.4 88 33.0 125 33.9 175 34.7 250 35.5 350 36.8 175 16.6 250 16.9 350 17.3 500 17.8 700 18.4 88 33.0 125 33.9 INA 4.2 492 443 116 6.1 677 609 112 105 8.9 940 846 12.9 1266 1140 98 2.9 351 316 121 4.2 493 444 116 6.1 677 609 111 106 8.9 939 845 12.9 1267 1141 98 2.9 376 338 129 4.2 529 6.1 728 8.9 1011 12.9 1362 2.9 377 4.2 531 6.1 728 8.9 1010 12.9 1363 2.9 382 4.2 538 6.1 740 8.9 1027 12.9 1384 2.9 383 4.2 539 175 34.7 6.1 740 250 35.5 8.9 1027 350 36.8 12.9 1385 476 125 655 120 RY 910 113 1226 105 339 130 477 125 655 120 909 114 1227 106 344 131 484 127 666 122 925 115 1246 107 345 132 485 127 666 122 924 116 1247 108 Notes for Table 3: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 4 Performance at Commonly Used Drive Currents PR Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI EL BXRE-50S0801-D-7x BXRE-50S0801-E-7x BXRE-57S0801-D-7x BXRE-57S0801-E-7x BXRE-65S0801-D-7x BXRE-65S0801-E-7x 98 98 98 98 98 98 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 138 175 16.6 2.9 401 361 250 16.9 4.2 565 508 134 350 17.3 6.1 777 699 128 500 17.8 8.9 1079 971 121 700 18.4 12.9 1454 1308 113 139 88 33.0 2.9 402 362 125 33.9 4.2 566 510 134 175 34.7 6.1 777 699 128 IM 250 35.5 8.9 1078 970 121 350 36.8 12.9 1455 1309 113 140 175 16.6 2.9 407 366 250 16.9 4.2 574 516 136 350 17.3 6.1 789 710 130 500 17.8 8.9 1095 986 123 700 18.4 12.9 1476 1328 114 88 33.0 125 33.9 INA 2.9 409 368 141 4.2 575 517 136 175 34.7 6.1 789 710 130 250 35.5 8.9 1095 985 123 350 36.8 12.9 1477 1329 115 175 16.6 2.9 398 358 137 250 16.9 350 17.3 500 17.8 700 18.4 88 33.0 125 33.9 175 34.7 250 35.5 350 36.8 4.2 560 504 132 6.1 771 694 127 120 8.9 1070 963 12.9 1442 1298 112 2.9 399 359 137 4.2 562 6.1 771 8.9 1070 12.9 1443 506 133 RY 694 127 963 121 1299 112 Notes for Table 3: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5 Spectrum Characteristics PR Table 4: Typical Color Rendering Index and TM-30 Values at, Tc=85°C Nominal CCT1 Rf Rg R1 R2 R3 R4 R5 R6 R7 R8 R9 R10 R11 R12 R13 R14 R15 2700K 95 103 97 99 94 94 97 98 97 98 99 97 91 98 98 95 98 3000K 95 104 98 99 93 94 97 98 96 96 97 96 92 95 98 95 97 95 98 98 98 97 98 98 98 98 97 93 97 97 95 98 97 98 97 100 99 99 97 99 99 99 99 98 94 97 99 96 99 98 98 97 100 98 99 98 98 98 98 99 98 95 98 98 98 98 98 97 94 98 98 98 97 95 98 97 96 95 92 97 96 96 98 98 97 95 98 98 98 97 96 98 98 96 96 93 97 96 97 98 98 97 3500K 4000K 5000K 5700K 6500K Note for Table 4: EL IM 1. Bridgelux maintains a tolerance of ± 3 on Color Rendering Index R1-R15 measurements and TM-30 measurements. Figure 1: 2700K Thrive TM-30 Graphs Figure 2: 3000K Thrive TM-30 Graphs Figure 3: 3500K Thrive TM-30 Graphs INA RY 6 Spectrum Characteristics PR Figure 4: 4000K Thrive TM-30 Graphs EL Figure 5: 5000K Thrive TM-30 Graphs IM Figure 6: 5700K Thrive TM30 Graphs Figure 7: 6500K Thrive TM-30 Graphs INA RY 7 Spectrum Characteristics PR Figure 8: Typical Color Spectrum 100% 80% 60% 40% 20% 0% 380 EL Note for Figure 8: 430 480 530 100% 2700K 3000K 3500K 4000K Relative Radiant Power(%) Relative Radiant Power (%) 120% 5000K 5700K 6500K 80% 60% 40% 20% 0% 580 630 680 Wavelength (nm) 730 350 780 400 450 500 550 600 650 700 750 800 IM Wavelength(nm) 1. Color spectra measured at nominal current for Tc = 85°C. Spectral Matching to Natural Light The lighting market is in the early stages of adoption of human-centric lighting (HCL). HCL encompasses the effects of lighting on the physical and emotional health and well-being of people. Throughout evolution, the human visual system has evolved under the natural light of sun and fire. These light sources have standardized industry spectral power definitions that describe the state of natural light. However, conventional metrics such as CCT, CRI, and TM-30 fail to adequately quantify the naturalness, or closeness of these light sources to the standardized natural spectra. Due to a lack of an industry standard metric to quantitatively measure the naturalness of a light source, Bridgelux has pioneered a new metric that takes the guesswork out of comparing LED light sources to natural light. INA Average Spectral Difference, or ASD, is calculated by measuring the absolute difference between two spectra at discrete wavelengths. These values are averaged across a wavelength range derived from the photopic response curve, or V(λ); a luminous efficiency function describing the average spectral sensitivity of human perception of brightness. The range of 425nm to 690nm was selected to remove the tails of the V(λ) gaussian distribution below 1% of the peak value at 555nm, covering 99.9% of the area under the photopic response curve. Natural light is defined following the approach of IES TM-30; black body curves for light sources of ≤4000K and the CIE standard illuminant D for light sources of ≥ 5000K. Natural light has an ASD of 0%; lower ASD values indicate a closer match to natural light. Thrive is engineered to provide the closest match to natural light available using proprietary chip, phosphor and packaging technology, resulting in an ASD between 8% to 10% for all CCTs. By comparison, standard 80, 90, and 98 CRI light sources have ASD values that are 100% to 300% larger than Thrive. To learn more about the ASD metric, please review the Bridgelux whitepaper: Average Spectral Difference, a new method to make objective comparisons of naturalness between light sources; or contact your Bridgelux sales representative. RY 8 Electrical Characteristics PR Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.75 15.4 19.1 -7.38 0.88 16.4 20.3 37.2 -14.76 0.75 33.2 37.7 39.7 -14.76 0.88 35.3 40.1 Minimum Typical Maximum 350 16.0 17.3 18.6 -7.38 700 17.0 18.5 19.8 175 32.0 34.7 350 34.1 36.9 EL Driver Selection Voltages7 (V) BXRE-xxx080x-D-7x BXRE-xxx080x-E-7x Notes for Table 5: IM 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. INA 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. RY 9 Absolute Maximum Ratings PR Table 6: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds EL IM BXRE-xxx080x-D-7x BXRE-xxx080x-E-7x Maximum Drive Current3 700mA 350mA Maximum Peak Pulsed Drive Current4 1000mA INA 500mA -35V -60V Maximum Reverse Voltage5 Notes for Table 6: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN101: Handling and Assembly of Bridgelux V Series LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. RY 10 Eye Safety PR Table 7: Eye Safety Risk Group (RG) Classifications Part Number 2700K/3000K 4000K2 EL BXRE-xxx080x-D-7x BXRE-xxx080x-E-7x Notes for Table 7: CCT1,5 Drive Current 5 (mA) 5000K3 6500K4 350 RG1 RG1 RG1 RG1 500 RG1 RG1 RG2 RG2 700 RG1 RG1 RG2 RG2 175 RG1 RG1 RG1 RG2 250 RG1 RG1 RG2 RG2 RG1 RG2 RG2 IM 350 RG1 1. Eye safety classification for the use of Bridgelux V Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 5000K Ethr= 1315.8 lx. 3. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. INA RY 11 Product Bin Definitions PR Table 8: 2-, 3- and 4-step MacAdam Ellipse Color Bin Definitions Center Point Degree 2-step 3-step 4-step CCT 2700K 3000K 4000K 5000K 5700K 6500K x y Φ(°) a b a b a b 0.4578 0.4101 53.700 0.00540 0.00280 0.0081 0.0042 N/A N/A 0.4338 0.403 53.217 0.00556 0.00272 0.0083 0.0041 N/A N/A 0.3818 0.3797 53.717 0.00626 0.00268 0.0094 0.0040 N/A N/A 0.3447 0.3553 59.617 N/A N/A 0.0082 0.0035 0.0110 0.0047 0.3287 0.3417 59.060 N/A N/A 0.0074 0.0032 0.0099 0.0042 0.3123 0.3282 58.567 N/A N/A 0.0066 0.0028 0.0090 0.0038 EL IM Notes for Table 8: 1. Color binning at Tc=85°C INA 2. Bridgelux maintains a tolerance of ± 0.007 on x and y color coordinates in the CIE 1931 color space. Figure 9: C.I.E. 1931 Chromaticity Diagram (Color targeted at Tc=85°C) 0.44 3 SDCM 2 SDCM 2700K 0.42 3000K 3500K 4 SDCM 0.38 3 SDCM 0.37 0.36 0.4 4000K 0.35 Y Y 0.39 0.38 6500K 0.34 0.33 0.36 0.32 0.34 0.36 0.31 0.39 0.42 0.45 X 0.48 0.3 0.3 0.31 0.32 RY 5000K 5700K 0.33 0.34 0.35 0.36 0.37 X 12 Performance Curves PR 800 400 700 350 600 300 400 300 200 100 15.5 EL 16.0 16.5 17.0 Forward Current (mA) 500 0 18.0 18.5 200% 180% 160% 140% 120% 100% 80% 200 150 100 50 31.0 19.0 32.0 33.0 40% 20% 0% 100 200 300 400 500 Forward Current (mA) 600 700 800 34.0 35.0 36.0 37.0 38.0 Forward Voltage (V) Forward Voltage (V) 60% 0 250 0 IM 17.5 Figure 12: V8D Typical Relative Luminous Flux vs. Drive Current (Tj = Tc = 25°C)1 Relative Luminous Flux Figure 11: V8E Drive Current vs. Voltage (Tj = Tc = 25°C)1 Figure 13: V8E Typical Relative Luminous Flux vs. Drive Current (Tj = Tc = 25°C)1 200% INA 180% 160% Relative Luminous Flux Forward Current (mA) Figure 10: V8D Drive Current vs. Voltage (Tj = Tc = 25°C)1 140% 120% 100% 80% 60% 40% 20% 0% 0 50 100 150 200 250 300 350 400 Forward Current (mA) RY 13 Performance Curves PR Figure 15: Typical ccx Shift vs. Case Temperature Figure 14: Typical DC Flux vs. Case Temperature Relative Luminous Flux 100% 97% 94% 91% 88% 85% 82% 0 EL 25 50 Case Temperature (°C) 0 Warm White 0 20 40 25°C Pulsed 0.000 ccy shift -0.001 -0.002 -0.003 -0.004 -0.005 -0.006 60 40 60 80 100 120 25°C Pulsed Neutral White Cool White 25°C Pulsed -0.0005 IM 75 100 80 100 -0.0010 -0.0015 125 Figure 16: Typical ccy Shift vs. Case Temperature 0.001 20 0.0000 ccx shift 103% 120 -0.007 Case Temperature (°C) Notes for Figures 14-16: -0.0020 Case Temperature (°C) INA RY 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Characteristics shown for warm white based on 3000K Thrive 3. Characteristics shown for neutral white based on 4000K Thrive 4. Characteristics shown for cool white based on 5000K Thrive 5. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 14 Typical Radiation Pattern PR Figure 17: Typical Spatial Radiation Pattern EL Notes for Figure 17: 1. Typical viewing angle is 120⁰. IM INA 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 18: Typical Polar Radiation Pattern RY 15 Mechanical Dimensions PR Figure 19: V8 LED Array EL Notes for Figure 11: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. IM INA 3. Solder pads are labeled “+” and “-“ to denote positive and negative polarity, respectively. 4. Unless otherwise specified, tolerances are ±0.1mm. 5. Refer to Application Notes AN101 for product handling, mounting and heat sink recommendations. 6. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 7. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. RY 16 Packaging and Labeling PR Figure 20: V8 Packaging EL IM Notes for Figure 20: 1. Each tube holds 40 V8 COB arrays. INA RY 2. One tube is sealed in an anti-static bag. Four bags are placed in a shipping box. Depending on quantities ordered, a bigger shipping box, containing four boxes may be used to ship products. 3. Each bag and box is to be labeled as shown above. 4. Dimensions for each tube are 8.3mm (W) x 14.3mm (H) x 530mm (L). Dimensions for the anti-static bag are 75 (W) x 615 (L) x 3.1 (T) mm. Dimensions for the shipping box are 58.7 x 13.3 x 7.9 cm 17 Packaging and Labeling PR Figure 21: Gen. 7 Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, EL however these will not impact the form, function or performance of the COB array. Customer Use- Product part number Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. IM 30S0801D 73 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. INA RY 18 Design Resources PR Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the V Series product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux V Series LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. EL Precautions IM CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN101 for additional information. CAUTION: RISK OF BURN Do not touch the V Series LED array during operation. Allow the array to cool for a sufficient period of time before handling. The V Series LED array may reach elevated temperatures such that could burn skin when touched. Disclaimers MINOR PRODUCT CHANGE POLICY The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. CAUTION INA CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). RY STANDARD TEST CONDITIONS Unless otherwise stated, array testing is performed at the nominal drive current. 19 About Bridgelux: Bridging Light and Life™ PR At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. EL For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux linkedin.com/company/bridgelux-inc-_2 youtube.com/user/Bridgelux WeChat ID: BridgeluxInChina IM 46430 Fremont Boulevard Fremont, CA 94538 USA Tel (925) 583-8400 www.bridgelux.com INA RY © 2020 Bridgelux, Inc. Product specifications are subject to change without notice. Bridgelux and the Bridgelux stylized logo design are registered trademarks of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux V8 Thrive Array Product Data Sheet DS323 Rev. A (06/2020) 20
BXRE-57S0801-E-74 价格&库存
很抱歉,暂时无法提供与“BXRE-57S0801-E-74”相匹配的价格&库存,您可以联系我们找货
BXRE-57S0801-E-74
  • 600+18.90769600+2.44571
BXRE-57S0801-E-74
    • 1+40.74840
    • 200+16.26480
    • 480+15.71400
    • 1000+15.45480
