BT817Q-R
BT817Q-R
    BRIDGETEK
    VFQFN64_EP
    IC EVE4 CAP TOUCH 64VQFN
BT817Q-R 数据手册
BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 Bridgetek Pte Ltd BT817/8 Advanced Embedded Video Engine Datasheet The BT817/8 are easy to use graphic controllers targeted at embedded applications to generate high-quality Human Machine Interfaces (HMIs). They have the following features:  Video RGB parallel output; configurable to support PCLK up to 96MHz with separate PLL(PLL2), and R/G/B output of 1 to 8 bits (including RGB565, RGB666 and RGB888)  Programmable timing to adjust HSYNC and VSYNC timing, enabling interfacing to numerous displays  Support for LCD displays with up to 1 Mega pixels in total, and up to 2048 pixels per line  Supported LCD resolutions: 1920x480, 1440x540, 1280x800, 1024x600, 800x600, 800x480, 480x272, 320x240 and many others  Supports landscape and portrait orientations  High-quality cubic filter to output pixels to correct for panels with non-square pixels  Adaptive framerate and Adaptive HSYNC modes Supports Adaptive Scalable Texture Compression (ASTC) format to save considerable memory space for larger fonts and graphics images  Integrated 1MByte graphics RAM, no frame buffer RAM required  Supports playback of motion-JPEG encoded AVI videos  Mono audio channel output with Sigma-delta Supports external QSPI NOR flash up to 2Gbit to store and fetch graphic elements (image, font, widget etc.)  Built-in sound synthesizer  PWM output for display backlight dimming control  Supports 4-wire resistive touch screen (BT818)  Advanced object oriented architecture enables MPU/MCU as system host using SPI interfaces  Supports capacitive touch screen with up to 5 touch point detection (BT817)  Supports SPI data lines in single, dual or quad mode; SPI clock up to 30MHz  Hardware engine can recognize touch tags and track touch movement. Provides notification for up to 255 touch tags  Power mode control allows the chip to be put in power down, sleep and standby states  Supports I/O voltage from 1.8V to 3.3V (5V tolerant)  Internal voltage regulator supplies 1.2V to the digital core  Built-in Power-on-reset circuit  -40°C to 85°C extended operating temperature range  Available in a compact Pb-free, VQFN-64 package, RoHS compliant  Advanced Embedded Video Engine (EVE) with high resolution graphics and video playback  Graphic control, audio control, and touch control interface  Supports multiple widgets for simplified design implementation  Built-in graphics operations allow users with little expertise to create highquality displays    Enhanced sketch processing  Built-in 12MHz crystal oscillator with PLL providing programmable system clock up to 72MHz  Supports crystal-less operation with internal relaxation clock source Neither the whole nor any part of the information contained in, or the product described in this manual, may be adapted or reproduced in any material or electronic form without the prior written consent of the copyright holder. This product and its documentation are supplied on an as-is basis and no warranty as to their suitability for any particular purpose is either made or implied. Bridgetek Pte Ltd will not accept any claim for damages howsoever arising as a result of use or failure of this product. Your statutory rights are not affected. This product or any variant of it is not intended for use in any medical appliance, device or system in which the failure of the product might reasonably be expected to result in personal injury. This document provides preliminary information that may be subject to change without notice. No freedom to use patents or other intellectual property rights is implied by the publication of this document. Bridgetek Pte Ltd, 178 Paya Lebar Road, #07-03, Singapore 409030. Singapore Registered Company Number: 201542387H Copyright © Bridgetek Pte Ltd 1 low cost BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 1 Typical Applications  Point of Sales Machines  Breathalyzers  Multi-function Printers  Gas chromatographs  Instrumentation  Power meter  Home Security Systems  Home appliance devices  Graphic touch pad – remote, dial pad  Set-top box  Tele / Video Conference Systems  Thermostats  Phones and Switchboards  Sprinkler system displays  Medical Appliances  GPS / Satnav  Blood Pressure displays  Vending Machine Control Panels  Heart monitors  Elevator Controls  Glucose level displays  ……and many more 1.1 Part Numbers Part Number BT817Q-x BT818Q-x Description Package EVE4 with ASTC and external NOR flash, 64 Pin VQFN, body 9 x 9 mm, pitch 0.5mm capacitive touch EVE4 with ASTC and external NOR flash, 64 Pin VQFN, body 9 x 9 mm, pitch 0.5mm resistive touch Table 1- BT817/8 Embedded Video Engine Part Numbers Note: Packaging codes for x is: -R: Taped and Reel (3000 pcs per reel) -T: Tray packing (260 pcs per tray) For example: BT817Q-R is 3000 VQFN pieces in taped and reel packaging Copyright © Bridgetek Pte Ltd 2 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 2 Block Diagram Figure 2-1 BT817/8 Block Diagram For a description of each function please refer to Section 4. Figure 2-2 BT817/8 System Design Diagram BT817/8 with EVE (Embedded Video Engine) technology simplifies the system architecture for advanced human machine interfaces (HMIs) by providing support for display, audio, and touch as well as an object oriented architecture approach that extends from display creation to the rendering of the graphics. Copyright © Bridgetek Pte Ltd 3 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 Table of Contents 1 Typical Applications....................................................... 2 1.1 Part Numbers ............................................................................. 2 2 Block Diagram ............................................................... 3 3 Device Pin Out and Signal Description ........................... 7 3.1 BT817 VQFN-64 Package Pin Out ............................................... 7 3.2 BT818 VQFN-64 Package Pin Out ............................................... 7 3.3 Pin Description .......................................................................... 8 4 Functional Description ................................................. 11 4.1 Quad SPI Host Interface .......................................................... 11 4.1.1 QSPI Interface .......................................................................................... 11 4.1.2 Serial Data Protocol ................................................................................... 13 4.1.3 Host Memory Read .................................................................................... 13 4.1.4 Host Memory Write.................................................................................... 14 4.1.5 Host Command ......................................................................................... 14 4.1.6 Interrupts ................................................................................................ 17 4.2 System Clock ........................................................................... 18 4.2.1 Clock Source ............................................................................................ 18 4.2.2 Phase Locked Loop .................................................................................... 19 4.2.3 Clock Enable ............................................................................................. 19 4.2.4 Clock Frequency ........................................................................................ 19 4.3 Graphics Engine ....................................................................... 20 4.3.1 Introduction ............................................................................................. 20 4.3.2 ASTC ....................................................................................................... 20 4.3.3 ROM and RAM Fonts .................................................................................. 21 4.4 SPI NOR Flash Interface .......................................................... 24 4.5 Parallel RGB Interface ............................................................. 25 4.6 Miscellaneous Control .............................................................. 29 4.6.1 Backlight Control Pin ................................................................................. 29 4.6.2 DISP Control Pin ....................................................................................... 29 4.6.3 General Purpose IO pins ............................................................................ 29 4.6.4 Pins Drive Current Control .......................................................................... 29 4.7 Audio Engine ............................................................................ 30 4.7.1 Sound Synthesizer .................................................................................... 30 4.7.2 Audio Playback ......................................................................................... 32 Copyright © Bridgetek Pte Ltd 4 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 4.8 Clearance No.: BRT#154 Touch-Screen Engine ............................................................... 32 4.8.1 Resistive Touch Control .............................................................................. 32 4.8.2 Capacitive Touch Control ............................................................................ 33 4.8.3 Compatibility Mode .................................................................................... 34 4.8.4 Extended Mode ......................................................................................... 35 4.8.5 Short-Circuit Protection .............................................................................. 35 4.8.6 Capacitive Touch Configuration ................................................................... 35 4.8.7 Host Driven Multi-Touch ............................................................................. 36 4.8.8 Touch Detection in none-ACTIVE State ........................................................ 37 4.9 Power Management ................................................................. 37 4.9.1 Power Supply ........................................................................................... 37 4.9.2 Internal Regulator and POR ........................................................................ 38 4.9.3 Power Modes ............................................................................................ 38 4.9.4 Reset and Boot-up Sequence ...................................................................... 39 4.9.5 Pin Status at Different Power States ............................................................ 40 5 Memory Map ................................................................ 41 5.1 Registers.................................................................................. 41 5.2 Chip ID..................................................................................... 45 6 Devices Characteristics and Ratings ............................ 46 6.1 Absolute Maximum Ratings ...................................................... 46 6.2 ESD and Latch-up Specifications .............................................. 46 6.3 DC Characteristics .................................................................... 46 6.4 AC Characteristics .................................................................... 48 6.4.1 System Clock and Reset ............................................................................. 48 6.4.2 SPI Interface Timing .................................................................................. 49 6.4.3 RGB Interface Timing ................................................................................ 49 7 Application Examples .................................................. 51 8 Package Parameters .................................................... 53 8.1 Part Markings .......................................................................... 53 8.1.1 Top Side .................................................................................................. 53 8.1.2 Bottom Side ............................................................................................. 53 8.2 VQFN-64 Package Dimensions ................................................. 54 8.3 Solder Reflow Profile ............................................................... 55 9 Contact Information .................................................... 56 Appendix A – References ................................................... 57 Copyright © Bridgetek Pte Ltd 5 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 Document References ...................................................................... 57 Acronyms and Abbreviations............................................................ 57 Appendix B - List of Figures and Tables ............................. 59 List of Figures .................................................................................. 59 List of Tables.................................................................................... 59 Appendix C - Revision History ............................................ 61 Copyright © Bridgetek Pte Ltd 6 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 3 Device Pin Out and Signal Description 3.1 BT817 VQFN-64 Package Pin Out Figure 3-1 Pin Configuration BT817 VQFN-64(Top View) 3.2 BT818 VQFN-64 Package Pin Out Figure 3-2 Pin Configuration BT818 VQFN-64 (Top View) Copyright © Bridgetek Pte Ltd 7 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 3.3 Pin Description Pin Number Pin Name Type BT817 BT818 1 1 R0 O 2 2 VCC1V2 P 3 3 SCK I 4 4 MISO I/O 5 5 MOSI I/O 6 6 CS_N I 7 7 GPIO0/IO2 I/O 8 8 GPIO1/IO3 I/O 9 9 VCCIO1 P 10 10 GPIO2 I/O 11 11 INT_N OD/ O 12 12 PD_N I 13 13 GPIO3 I/O 14 14 SPIM_SCLK O 15 15 SPIM_SS_N O 16 16 SPIM_MOSI I/O 17 17 VCCIO3 P 18 18 SPIM_MISO I/O 19 19 SPIM_IO2 I/O 20 20 SPIM_IO3 I/O 21 21 X1/CLK I Copyright © Bridgetek Pte Ltd Description Bit 0 of Red RGB signals Powered from pin VCCIO2 1.2V digital core supply. Connect to VOUT1V2 pin on PCB. A 0.1uF + 1uF decoupling capacitors are recommended SPI clock input Powered from pin VCCIO1 SPI Single mode: SPI MISO output SPI Dual/Quad mode: SPI data line 1 Powered from pin VCCIO1 SPI Single mode: SPI MOSI input SPI Dual/Quad mode: SPI data line 0 Powered from pin VCCIO1 SPI slave select input Powered from pin VCCIO1 SPI Single/Dual mode: General purpose IO 0 SPI Quad mode: SPI data line 2 Powered from pin VCCIO1 SPI Single/Dual mode: General purpose IO 1 SPI Quad mode: SPI data line 3 Powered from pin VCCIO1 I/O power supply for host interface pins. Support 1.8V, 2.5V or 3.3V. General purpose IO 2 Powered from pin VCCIO1 Interrupt to host, open drain output (default) or push-pull output, active low Chip power down mode control input, active low. Connect to MCU GPIO for power management or hardware reset function, or pulled up to VCCIO1 if not used. Powered from pin VCCIO1 General purpose IO 3 Powered from pin VCCIO1 SPI flash clock output line. Leave floating if not used. Powered from pin VCCIO3 SPI flash chip select output line. Leave floating if not used. Powered from pin VCCIO3 SPI flash MOSI line. Leave floating if not used. Powered from pin VCCIO3 I/O power supply for SPIM pins. Support 1.8V, 2.5V or 3.3V. VCCIO3 can be connected to different voltage with VCCIO1 or VCCIO2. SPI flash MISO line. Connect to GND if not used. Powered from pin VCCIO3 SPI flash IO2 line. Leave floating if not used. Powered from pin VCCIO3 SPI flash IO3 line. Leave floating if not used. Powered from pin VCCIO3 Crystal oscillator or clock input 8 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Pin Number BT817 BT818 Pin Name Type Description 3.3V peak input allowed. Powered from pin VCC. Crystal oscillator output Powered from pin VCC. 22 22 X2 O 23 23 GND P Ground 24 24 VCC P 3.3V power supply input. 25 25 VOUT1V2 P 26 26 AUDIO_L O 27 27 VCCA P 28 28 VCCIO2 P - 29 XP AI/O - 30 YP AI/O - 31 XM AI/O - 32 YM AI/O 29 - CTP_RST_N O 30 - CTP_INT_N I/O 31 - CTP_SCL I/OD 32 - CTP_SDA I/OD 33 33 GND P 34 34 BACKLIGHT O 35 35 DE O 36 36 VSYNC O 37 37 HSYNC O 38 38 DISP O 39 39 PCLK O 40 40 B7 O 41 41 B6 O 42 42 B5 O 43 43 B4 O Copyright © Bridgetek Pte Ltd Clearance No.: BRT#154 1.2V regulator output pin. Connect a minimum 3.3uF decoupling capacitor to GND. Audio Sigma-delta output Powered from pin VCCA 3.3V power supply input. I/O power supply for RGB and touch pins. Supports 1.8V, 2.5V or 3.3V. VCCIO2 can be connected to different voltage with VCCIO1 or VCCIO3. Connect to X right electrode of 4-wire resistive touch-screen panel. Powered from pin VCCIO2. Connect to Y top electrode of 4-wire resistive touch-screen panel. Powered from pin VCCIO2. Connect to X left electrode of 4-wire resistive touch-screen panel. Powered from pin VCCIO2. Connect to Y bottom electrode of 4-wire resistive touch-screen panel. Powered from pin VCCIO2. Connect to reset pin of the CTPM. Powered from pin VCCIO2. Connect to interrupt pin of the CTPM. Powered from pin VCCIO2. Connect to I2C SCL pin of the CTPM. Powered from pin VCCIO2. Connect to I2C SDA pin of the CTPM. Powered from pin VCCIO2. Ground LED Backlight brightness PWM control signal. Powered from pin VCCIO2. LCD Data Enable. Powered from pin VCCIO2. LCD Vertical Sync. Powered from pin VCCIO2. LCD Horizontal Sync. Powered from pin VCCIO2. LCD Display Enable. Powered from pin VCCIO2. LCD Pixel Clock. Powered from pin VCCIO2. Bit 7 of Blue RGB signals. Powered from pin VCCIO2. Bit 6 of Blue RGB signals. Powered from pin VCCIO2. Bit 5 of Blue RGB signals. Powered from pin VCCIO2. Bit 4 of Blue RGB signals. Powered from pin VCCIO2. 9 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Pin Number Pin Name Type BT817 BT818 44 44 B3 O 45 45 B2 O 46 46 B1 O 47 47 B0 O 48 48 GND P 49 49 G7 O 50 50 G6 O 51 51 G5 O 52 52 G4 O 53 53 G3 O 54 54 G2 O 55 55 G1 O 56 56 G0 O 57 57 VCC1V2 P 58 58 R7 O 59 59 R6 O 60 60 R5 O 61 61 R4 O 62 62 R3 O 63 63 R2 O 64 64 R1 O EP EP GND P Table 3-1 Clearance No.: BRT#154 Description Bit 3 of Blue RGB signals. Powered from pin VCCIO2. Bit 2 of Blue RGB signals. Powered from pin VCCIO2. Bit 1 of Blue RGB signals. Powered from pin VCCIO2. Bit 0 of Blue RGB signals. Powered from pin VCCIO2. Ground Bit 7 of Green RGB signals. Powered from pin VCCIO2. Bit 6 of Green RGB signals. Powered from pin VCCIO2. Bit 5 of Green RGB signals. Powered from pin VCCIO2. Bit 4 of Green RGB signals. Powered from pin VCCIO2. Bit 3 of Green RGB signals. Powered from pin VCCIO2. Bit 2 of Green RGB signals. Powered from pin VCCIO2. Bit 1 of Green RGB signals. Powered from pin VCCIO2. Bit 0 of Green RGB signals. Powered from pin VCCIO2. 1.2V digital core supply. Connect to VOUT1V2 pin on PCB. A 0.1uF decoupling capacitor is recommended. Bit 7 of Red RGB signals. Powered from pin VCCIO2. Bit 6 of Red RGB signals. Powered from pin VCCIO2. Bit 5 of Red RGB signals. Powered from pin VCCIO2. Bit 4 of Red RGB signals. Powered from pin VCCIO2. Bit 3 of Red RGB signals. Powered from pin VCCIO2. Bit 2 of Red RGB signals. Powered from pin VCCIO2. Bit 1 of Red RGB signals Powered from pin VCCIO2 Ground. Exposed thermal pad. Connect to ground plane on PCB. BT817/8 Pin Description Note: P : Power or ground I : Input O : Output OD : Open drain output I/O : Bi-direction Input and Output AI/O: Analog Input and Output Copyright © Bridgetek Pte Ltd 10 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 4 Functional Description The BT817/8 is a single chip, embedded video controller with the following functional blocks:         Quad SPI Host Interface Quad SPI Flash Interface System Clock Graphics Engine Parallel RGB video interface Audio Engine Touch-screen support and interface (Capacitive – BT817 / Resistive – BT818) Power Management The functions for each block are briefly described in the following subsections. 4.1 Quad SPI Host Interface The BT817/8 uses a quad serial peripheral interface (QSPI) to communicate with host microcontrollers and microprocessors. 4.1.1 QSPI Interface The QSPI slave interface operates up to 30MHz. Only SPI mode 0 is supported. Refer to section 6.4.2 for detailed timing specification. The QSPI can be configured as a SPI slave in SINGLE, DUAL or QUAD channel modes. By default the SPI slave operates in the SINGLE channel mode with MOSI as input from the master and MISO as output to the master. DUAL and QUAD channel modes can be configured through the SPI slave itself. To change the channel modes, write to register REG_SPI_WIDTH. The table below depicts the setting. REG_SPI_WI DTH [1:0] 00 01 Channel Mode Data pins SINGLE – default mode DUAL MISO, MOSI MOSI, MISO Max bus speed 30 MHz 30 MHz (not exceeding system clock frequency) 10 QUAD MOSI, MISO, 30 MHz (not exceeding half of the IO2, IO3 system clock frequency) 11 Reserved Table 4-1 QSPI Channel Selection With DUAL/QUAD channel modes, the SPI data ports are now unidirectional. In these modes, each SPI transaction (signified by CS_N going active low) will begin with the data ports set as inputs. Hence, for writing to the BT817/8, the protocol will operate as in previous EVE revisions such as the FT800, with “WR-Command/Addr2, Addr1, Addr0, DataX, DataY, DataZ …” The write operation is considered complete when CS_N goes inactive high. For reading from the BT817/8, the protocol will still operate as in FT800, with “RD-Command/Addr2, Addr1, Addr0, Dummy-Byte, DataX, DataY, DataZ”. However as the data ports are now unidirectional, a change of port direction will occur before DataX is clocked out of the BT817/8. Therefore it is important that the firmware controlling the SPI master changes the SPI master data port direction to “input” after transmitting Addr0. The BT817/8 will not change the port direction till it starts to clock out DataX. Hence, the Dummy-Byte cycles will be used as a change-over period when neither the SPI master nor slave will be driving the bus; the data paths thus must have pull-ups/pull-downs. The SPI slave from the BT817/8 will reset all its data ports’ direction to input once CS_N goes inactive high (i.e. at the end of the current SPI master transaction). Figure 4-1 depicts the behaviour of both the SPI master and slave in the master read case. Copyright © Bridgetek Pte Ltd 11 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 SS WR/Addr rr2 Addr 1 Addr 2 Dumm y Data X Data 0 SPI Slave drives the data bus SPI Slave resets data ports into inputs SPI Master drives the data bus Bus not driven SPI Master changes data ports into inputs Data Y SPI Slave changes data ports into outputs Figure 4-1 SPI Master and Slave in the Master Read Case In the DUAL channel mode, MISO (MSB) and MOSI are used while in the QUAD channel mode. IO3 (MSB), IO2, MISO and MOSI are used. Figure 4-2 illustrates a direct connection to a 1.8-3.3V IO MPU/MCU with single or dual SPI interface. Figure 4-3 illustrates a direct connection to a 1.8-3.3V IO MPU/MCU with Quad SPI interface. 1.8-3.3V 3.3V VCCIO1 MPU/MCU 4.7k BT817/8 SCLK SCK MISO MISO MOSI MOSI SS# CS_N PD# PD_N INT# INT_N GND VCC GND Figure 4-2 Single/Dual SPI Interface connection Copyright © Bridgetek Pte Ltd 12 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 1.8-3.3V Clearance No.: BRT#154 3.3V VCCIO1 VCC MPU/MCU 4.7k BT817/8 SCLK SCK MISO MISO MOSI MOSI IO2 SS# IO2 IO3 CS_N PD# PD_N INT# INT_N IO3 GND GND Figure 4-3 Quad SPI Interface connection 4.1.2 Serial Data Protocol The BT817/8 appears to the host MPU/MCU as with the BT817/8 using reads and writes to a space are dedicated areas for graphics, audio memory map. The host reads and writes the transactions are memory read, memory write significant bit first. a memory-mapped SPI device. The host communicates large (4 megabyte) address space. Within this address and touch control. Refer to section 5 for the detailed BT817/8 address space using SPI transactions. These and command write. Serial data is sent by the most Each transaction starts with CS_N goes low, and ends when CS_N goes high. There’s no limit on data length within one transaction, as long as the memory address is continuous. 4.1.3 Host Memory Read For SPI memory read transactions, the host sends two zero bits, followed by the 22-bit address. This is followed by a dummy byte. After the dummy byte, the BT817/8 responds to each host byte with read data bytes. 7 6 0 0 5 4 3 2 1 0 Address [21:16] Address [15:8] Write Address Address [7:0] Dummy byte Byte 0 Read Data Byte n Table 4-2 Host Memory Read Transaction Copyright © Bridgetek Pte Ltd 13 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 4.1.4 Clearance No.: BRT#154 Host Memory Write For SPI memory write transactions, the host sends a ‘1’ bit and ‘0’ bit, followed by the 22-bit address. This is followed by the write data. 7 6 1 0 5 4 3 2 1 0 Address [21:16] Write Address Address [15:8] Address [7:0] Byte 0 Write Data Byte n Table 4-3 Host Memory Write Transaction 4.1.5 Host Command When sending a command, the host transmits a 3 byte command. Table 4-5 lists all the host command functions. For SPI command transactions, the host sends a ‘0’ bit and ‘1’ bit, followed by the 6-bit command code. The 2nd byte can be either 00h, or the parameter of that command. The 3rd byte is fixed at 00h. All SPI commands except the system reset can only be executed when the SPI is in the Single channel mode. They will be ignored when the SPI is in either Dual or Quad channel mode. Some commands are used to configure the device and these configurations will be reset upon receiving the SPI PWRDOWN command, except those that configure the pin state during power down. These commands will be sticky unless reconfigured or power-on-reset (POR) occurs. 7 6 0 1 5 4 3 2 1 0 Command [5:0] 1st Byte 2nd Byte Parameter for the command 0 0 0 0 0 0 0 0 3rd Byte Table 4-4 Host Command Transaction 1st Byte 2nd byte 3rd byte Command Description Power Modes 00000000b 00000000b 00000000b 00h ACTIVE 01000001b 00000000b 00000000b 41h STANDBY 01000010b 00000000b 00000000b 42h Copyright © Bridgetek Pte Ltd Switch from Standby/Sleep/PWRDOWN modes to active mode. Dummy memory read from address 0(read twice) generates ACTIVE command. Put BT817/8 core to standby mode. Clock gate off, PLL and Oscillator remain on. ACTIVE command to wake up. Put BT817/8 core to sleep mode. Clock 14 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 1st Byte 2nd byte 3rd byte Command SLEEP 01000011b 01010000b 00000000b 00000000b 43h/50h PWRDOWN Clearance No.: BRT#154 Description gate off, PLL and Oscillator off. ACTIVE command to wake up. Switch off 1.2V core voltage to the digital core circuits. Clock, PLL and Oscillator off. SPI is alive. ACTIVE command to wake up. Clock and Reset 01000100b 00000000b 00000000b 44h CLKEXT 01001000b 00000000b 00000000b 48h CLKINT Select PLL input from external crystal oscillator or external input clock. No effect if external clock is already selected, otherwise a system reset will be generated Select PLL input from internal relaxation oscillator (default). No effect if internal clock is already selected, otherwise a system reset will be generated Select the system clock frequency. Note that software shall also update the register value for REG_FREQUENCY to align with system clock selected. This command will only be effective when the PLL is stopped (SLEEP mode). For compatibility to FT800/FT801, set Byte2 to 0x00. This will set the PLL clock back to default (60 MHz). Byte2 sets the clock frequency [5:0] 01100001b 01100010b 01101000b xx 00000000b 00000000b 00000000b 61h/62h CLKSEL 68h RST_PULSE 0 Set to default clock speed 1 Reserved 2 to 6 2 to 6 times the osc frequency (i.e. 24 to 72MHz with 12MHz oscillator) Byte2 [7:6] sets the PLL range 0 When Byte2[5:0] = 0, 2, 3 1 When Byte2[5:0] = 4, 5, 6 Send reset pulse to BT817/8 core. The behaviour is the same as POR except that settings done through SPI commands will not be affected Configuration 01110000b xx Copyright © Bridgetek Pte Ltd 00000000b 70h PINDRIVE This will set the drive strength for various pins. For FT800/FT801 compatibility, by default those settings are from the GPIO registers. BT817/8 supports setting the drive strength via SPI command instead. When PINDRIVE for a pin from the SPI command is not updated, the drive strength will be determined by its corresponding GPIO register bits, if they exist. If they don’t exist, a hard coded 15 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 1st Byte 2nd byte 3rd byte Command Clearance No.: BRT#154 Description setting is used. Please refer to Table 4-23 for default values. When PINDRIVE for a pin from the SPI command is updated, it will override the corresponding setting in the GPIO register bits. Byte2 determines which pin and the setting are to be updated. Byte2[1:0] determine the drive strength. Refer to Table 6-4 for pin group and drive strength currents. Byte2[1:0] 0h 1h 2h 3h Drive Strength Degree DSD1 Low DSD2 Medium DSD3 High DSD4 Maximum Byte2[7:2] determine which group to set: Byte2 Pin / Pin Group [7:2] Copyright © Bridgetek Pte Ltd pin/pin 00h GPIO 0 01h GPIO 1 02h GPIO 2 03h GPIO 3 04-07h Reserved 08h DISP 09h DE 0Ah VSYNC / HSYNC 0Bh PCLK 0Ch BACKLIGHT 0Dh R[7:0], G[7:0], B[7:0] 0Eh AUDIO_L 0Fh INT_N 10h CTP_RST_N 11h CTP_SCL 12h CTP_SDA 13h SPI MISO/MOSI/IO2/IO3 16 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 1st Byte 01110001b 2nd byte xx 3rd byte 00000000b Command 71h PIN_PD_STA TE Clearance No.: BRT#154 Description 14h SPIM_SCLK 15h SPIM_SS_N 16h SPIM_MISO 17h SPIM_MOSI 18h SPIM_IO2 19h SPIM_IO3 Others Reserved Note: GPIO0 shares the same pin as SPI IO2 and GPIO1 with SPI IO3. When SPI is set in Quad mode, IO2 and IO3 will inherit the drive strength set in GROUP 13h; otherwise GPIO0 and GPIO1 will inherit the drive strength from GROUP 00h and 01h respectively. During power down, I/O pins will have different state as compared to normal operating mode. Please refer to Table 4-23 for their default power down state. These settings will only be effective during power down and will not affect normal operations. Also note that these configuration bits are sticky and, unlike other configuration bits, will not reset to default values upon exiting power down. Only POR will reset them. Byte2 determines which pin and the setting are to be updated. Byte2[1:0] determine the pin state. Byte2 [1:0] Pin Setting 0h Float 1h Pull-Down 2h Pull-Up 3h Reserved Byte2[7:2] determine which pin/pin group to set. Please refer to the table in command PINDRIVE entry. Table 4-5 Host Command List Note: Any command code not specified is reserved and should not be used by the software 4.1.6 Interrupts The interrupt output pin is enabled by REG_INT_EN. When REG_INT_EN is 0, INT_N is tri-state (pulled to high by external pull-up resistor). When REG_INT_EN is 1, INT_N is driven low when any of the interrupt flags in REG_INT_FLAGS are high, after masking with REG_INT_MASK. Writing a ‘1’ in any bit of REG_INT_MASK will enable the corresponding interrupt. Each bit in REG_INT_FLAGS is set by a Copyright © Bridgetek Pte Ltd 17 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 corresponding interrupt source. REG_INT_FLAGS is readable by the host at any time, and clears when read. The INT_N pin is open-drain (OD) output by default. It can be configured to push-pull output by register REG_GPIOX. Bit Interrupt Source Conditions 0 INT_SWAP Display list swap occurred 1 INT_TOUCH touch detected 2 INT_TAG Touch-screen tag value change 3 INT_SOUND Sound effect ended 4 INT_PLAYBACK Audio playback ended 5 6 7 8 INT_CMDEMPTY Command FIFO empty Command FIFO flag INT_CONV_COMPLETE Touch-screen conversions completed INT_UNDERRUN Graphics pipeline underrun INT_CMDFLAG Table 4-6 Interrupt Flags bit assignment 4.2 System Clock 4.2.1 Clock Source The BT817/8 can be configured to use any of the three clock sources for system clock:    Internal relaxation oscillator clock (default) External 12MHz crystal External 12MHz square wave clock Figure 4-4, Figure 4-5 and Figure 4-6 show the pin connections for these clock options. Figure 4-4 Internal relaxation oscillator connection Copyright © Bridgetek Pte Ltd 18 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 Figure 4-5 Crystal Oscillator Connection Figure 4-6 External Clock Input 4.2.2 Phase Locked Loop There are 2 PLLs inside the chip, system PLL(PLL1) and PCLK PLL(PLL2). The system PLL takes an input clock from the oscillator, and generates clocks to all internal circuits, including the graphics engine, audio engine and touch engine. The PCLK PLL (PLL2) takes an input clock from the oscillator, and generates clocks for RGB interface when configured in Exsync mode. 4.2.3 Clock Enable At power-on the BT817/8 is in sleep mode. The internal relaxation oscillator is selected for the PLL clock source. The system clock will be enabled when the following step is executed:  Host sends an “ACTIVE” command If the application chooses to use the external clock source (12MHz crystal or clock), the following steps shall be executed:   4.2.4 Host sends a “CLKEXT” command Host sends an “ACTIVE” command Clock Frequency By default the system clock is running at 60MHz when the input clock is 12MHz. The host is allowed to switch the system clock to other frequencies by the host command “CLKSEL”. The clock switching command shall be sent in SLEEP mode only. After the chip is put into Active mode, software shall update the REG_FREQUENCY value to align with the chosen system clock frequency by CLKSEL command, if the default 60MHz is changed. Copyright © Bridgetek Pte Ltd 19 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 When using the internal relaxation oscillator, its clock frequency is trimmed to be 12MHz at factory. Software is allowed to change the frequency to a lower value by programming the register REG_TRIM. Note that software shall not change the internal oscillator frequency to be higher than 12MHz. 4.3 Graphics Engine 4.3.1 Introduction The graphics engine executes the display list once for every horizontal line. It executes the primitive objects in the display list and constructs the display line buffer. The horizontal pixel content in the line buffer is updated if the object is visible at the horizontal line. Main features of the graphics engine are:        The primitive objects supported by the graphics processor are: lines, points, rectangles, bitmaps (comprehensive set of formats), text display, plotting bar graph, edge strips, and line strips, etc. Operations such as stencil test, alpha blending and masking are useful for creating a rich set of effects such as shadows, transitions, reveals, fades and wipes. Anti-aliasing of the primitive objects (except bitmaps) gives a smoothing effect to the viewer. Bitmap transformations enable operations such as translate, scale and rotate. Display pixels are plotted with 1/16th pixel precision. Four levels of graphics states Tag buffer detection The graphics engine also supports customized built-in widgets and functionalities such as ASTC decode, jpeg decode, screen saver, calibration etc. The graphics engine interprets commands from the MPU host via a 4 Kbyte FIFO in the BT817/8 memory at RAM_CMD. The MPU/MCU writes commands into the FIFO, and the graphics engine reads and executes the commands. The MPU/MCU updates the register REG_CMD_WRITE to indicate that there are new commands in the FIFO, and the graphics engine updates REG_CMD_READ after commands have been executed. Main features supported are:       Drawing of widgets such as buttons, clock, keys, gauges, text displays, progress bars, sliders, toggle switches, dials, gradients, etc. JPEG and motion-JPEG decode Inflate functionality (zlib inflate is supported) Timed interrupt (generate an interrupt to the host processor after a specified number of milliseconds) In-built animated functionalities such as displaying logo, calibration, spinner, screen saver and sketch Snapshot feature to capture the current graphics display For a complete list of graphics engine BT81X_Series_Programming_Guide, Chapter 4. 4.3.2 display commands and widgets refer to ASTC ASTC stands for Adaptive Scalable Texture Compression, an open standard developed by ARM for use in mobile GPUs. ASTC is a block-based lossy compression format. The compressed image is divided into a number of blocks of uniform size, which makes it possible to quickly determine which block a given texel (unit of a texture map) resides in. Each block has a fixed memory footprint of 128 bits, but these bits can represent varying numbers of texels (the block footprint). Block footprint sizes are not confined to powers-of-two, and are also not confined to be square. For 2D formats the block dimensions range from 4 to 12 texels. Using ASTC for the large ROM fonts can save considerable space. Encoding the four largest fonts in ASTC 8x8 formats gives no noticeable loss in quality and reduces the ROM size from 1 Mbytes to about 640 Kbytes. Copyright © Bridgetek Pte Ltd 20 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 4.3.3 Clearance No.: BRT#154 ROM and RAM Fonts The BT817/8 has built in ROM character bitmaps as font metrics. The graphics engine can use these metrics when drawing text fonts. There are a total of 19 ROM fonts, numbered with font handle 1634. Fonts 31-34 are large ROM fonts encoded in ASTC 8x8 format. The user can define and load customized font metrics into RAM_G or external flash, making it possible to support a full range of Unicode characters with UTF-8 coding points. Each ROM font metric block has a 148 byte font table which defines the parameters of the font and the pointer of font image. The font table format is shown in Table 4-7. Address Offset 0 128 132 136 140 144 Size(byte) Parameter Description 128 width of each font character, in pixels 4 font bitmap format, for example L1, L4 or L8 4 font line stride, in bytes 4 font width, in pixels 4 font height, in pixels 4 pointer to font image data in memory Table 4-7 Font Table Format The ROM fonts are stored in the memory space ROM_FONT. The ROM font table is also stored in the ROM. The starting address of the ROM font table for font index 16 is stored at ROM_FONT_ADDR, with other font tables following. The ROM font table and individual character width (in pixel) are listed in Table 4-8, Table 4-9 and Table 4-10. Font index 16, 18 and 20-31 are for basic ASCII characters (code 0-127), while font index 17 and 19 are for Extended ASCII characters (code 128255). The character width for font index 16 through 19 is fixed at 8 pixels for any of the ASCII characters. 1 6 L 1 1 7 L 1 1 8 L 1 1 9 L 1 2 0 L 1 2 1 L 1 2 2 L 1 2 3 L 1 2 4 L 1 2 5 L 1 2 6 L 4 2 7 L 4 2 8 L 4 Line stride 1 1 1 1 2 2 2 3 3 4 7 8 9 Font width (max) 8 8 8 8 1 1 1 3 1 7 1 8 2 5 3 4 1 3 1 5 Font height 8 8 1 6 1 6 1 3 1 7 2 0 2 2 2 9 3 8 1 6 2 0 Font Index Font format 1 9 2 9 L 4 1 1 2 1 3 0 L 4 1 4 2 8 3 1 L 4 1 8 3 7 3 2 L 4 2 3 4 9 3 3 L 4 3 0 6 3 2 5 2 8 3 6 4 9 6 3 8 3 3 4 L 4 3 9 8 2 1 0 8 Table 4-8 ROM Font Table ASCII Character width in pixels Font Index => 0 NULL 1 SOH 2 STX 3 ETX 4 EOT 5 ENQ 6 ACK 7 BEL 8 BS 9 HT 10 LF 11 VT 12 FF 13 CR 14 SO 16/ 18 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Copyright © Bridgetek Pte Ltd 2 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 4 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 5 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 6 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 7 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 9 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 4 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 21 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Font Index => 15 SI 16 DLE 17 DC1 18 DC2 19 DC3 20 DC4 21 NAK 22 SYN 23 ETB 24 CAN 25 EM 26 SUB 27 ESC 28 FS 29 GS 30 RS 31 US Spac 32 e 33 ! 34 " 35 # 36 $ 37 % 38 & 39 ' 40 ( 41 ) 42 * 43 + 44 , 45 46 . 47 / 48 0 49 1 50 2 51 3 52 4 53 5 54 6 55 7 56 8 57 9 58 : 59 ; 60 < 61 = 62 > 63 ? 64 @ 65 A 66 B 67 C Clearance No.: BRT#154 16/ 18 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 4 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 5 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 6 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 7 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 9 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 4 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 3 3 4 6 6 9 8 2 4 4 4 6 3 4 3 3 6 6 6 6 6 6 6 6 6 6 3 3 6 5 6 6 11 7 7 8 4 4 5 8 8 12 10 3 5 5 7 9 3 4 3 4 8 8 8 8 8 8 8 8 8 8 3 4 8 9 8 8 13 9 9 10 5 5 6 9 9 14 11 3 6 6 6 10 4 5 4 5 9 9 9 9 9 9 9 9 9 9 4 4 10 10 10 9 17 11 11 12 5 6 5 10 10 16 13 3 6 6 7 10 5 6 5 5 10 10 10 10 10 10 10 10 10 10 5 5 10 11 10 10 18 13 13 14 6 6 8 14 13 22 17 6 8 8 10 14 6 8 6 7 13 13 13 13 13 13 13 13 13 13 6 6 15 15 15 12 25 17 17 18 9 9 12 19 18 29 22 6 11 11 13 19 9 11 9 9 18 18 18 18 18 18 18 18 18 18 9 9 19 19 19 18 34 22 22 24 3 3 5 10 8 11 9 3 5 5 7 9 3 6 3 6 8 8 8 8 8 8 8 8 8 8 3 3 8 8 8 7 13 9 9 9 4 4 6 11 10 13 11 4 6 6 8 10 4 7 4 7 10 10 10 10 10 10 10 10 10 10 4 4 9 9 9 9 15 11 10 11 5 6 7 14 11 16 14 4 7 8 10 12 4 10 6 9 12 12 12 12 12 12 12 12 12 12 6 6 11 13 11 10 19 13 14 13 6 6 8 15 15 17 15 5 9 8 11 14 5 11 7 10 14 14 14 14 14 14 14 14 14 14 6 6 12 14 13 12 21 15 15 15 8 9 12 19 18 23 19 7 11 10 14 17 7 15 8 13 17 17 17 17 17 17 17 17 17 17 7 8 16 18 16 15 28 20 19 20 10 11 15 26 25 31 26 10 15 14 18 24 9 18 11 17 24 24 24 24 24 24 24 24 24 24 10 10 21 23 22 20 37 27 27 26 13 15 19 33 31 40 34 11 18 18 24 30 12 24 14 22 30 30 30 30 30 30 30 30 30 30 13 14 28 30 29 26 49 34 34 34 18 19 25 44 41 52 44 15 24 24 31 41 16 32 19 29 40 40 40 40 40 40 40 40 40 40 18 18 36 40 37 34 63 45 45 45 23 25 33 57 54 68 57 20 31 31 40 52 20 41 24 38 52 52 52 52 52 52 52 52 52 52 23 23 46 52 48 44 82 58 58 58 Copyright © Bridgetek Pte Ltd 22 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Font Index => 68 D 69 E 70 F 71 G 72 H 73 I 74 J 75 K 76 L 77 M 78 N 79 O 80 P 81 Q 82 R 83 S 84 T 85 U 86 V 87 W 88 X 89 Y 90 Z 91 [ 92 \ 93 ] 94 ^ 95 _ 96 ` 97 A 98 B 99 C 100 D 101 E 102 F 103 G 104 H 105 I 106 J 107 K 108 L 109 M 110 N 111 O 112 P 113 Q 114 R 115 S 116 T 117 U 118 V 119 W 120 X 121 Y 16/ 18 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 2 0 8 7 6 8 8 3 5 7 6 9 8 8 7 8 7 7 5 8 7 9 7 7 7 3 3 3 6 6 3 5 6 5 6 5 4 6 6 2 2 5 2 8 6 6 6 6 4 5 4 5 6 8 6 5 2 1 10 9 8 11 10 4 7 9 8 12 10 11 9 11 10 9 9 10 9 13 9 9 9 4 4 4 7 8 5 8 7 7 8 8 4 8 8 3 3 7 3 11 8 8 8 8 5 7 4 7 7 10 7 7 Copyright © Bridgetek Pte Ltd 2 2 12 11 10 13 12 4 8 11 9 13 12 13 11 13 12 11 10 12 11 15 11 11 10 5 5 5 8 9 6 9 9 8 9 9 5 9 9 3 4 8 3 14 9 9 9 9 5 8 5 9 8 12 8 8 2 3 14 13 12 15 14 6 10 13 11 16 14 15 13 15 14 13 12 14 13 18 13 13 12 5 5 5 9 11 4 11 11 10 11 10 6 11 10 4 4 9 4 16 10 11 11 11 6 9 6 10 10 14 10 10 2 4 18 16 14 19 18 8 13 18 14 21 18 18 16 18 17 16 16 18 17 22 17 16 15 7 7 7 12 14 7 13 14 12 14 13 8 14 13 6 6 12 6 20 14 13 14 14 9 12 8 14 13 18 12 13 2 5 24 22 20 25 24 9 16 22 18 27 24 25 22 26 24 22 20 24 22 31 22 22 20 9 9 9 16 18 11 18 18 16 18 18 9 18 18 7 7 16 7 27 18 18 18 18 11 16 9 18 16 23 16 16 2 6 9 7 7 9 9 4 8 9 7 11 9 10 9 10 9 9 10 9 9 12 9 9 9 4 6 4 6 8 4 8 8 8 8 8 6 8 8 3 3 7 3 11 8 8 8 8 5 7 6 8 7 11 7 7 2 7 11 9 9 11 11 5 9 11 9 14 11 12 10 12 11 11 12 11 11 15 11 10 11 5 7 5 7 10 5 9 9 9 10 9 7 10 9 4 4 9 4 15 9 10 9 10 6 9 7 9 9 13 9 9 2 8 14 12 12 14 15 6 12 14 12 19 15 14 14 14 13 12 14 13 14 18 13 14 13 6 9 7 9 11 7 11 11 11 12 11 8 11 11 6 6 11 6 18 11 12 11 12 7 11 8 12 11 16 11 11 2 9 17 13 13 16 17 7 13 16 13 21 17 16 15 17 15 14 15 17 15 21 15 15 14 7 10 7 10 13 8 13 14 12 14 12 10 14 14 6 6 13 6 21 14 13 14 13 9 12 9 14 12 18 12 12 3 0 22 16 17 22 23 9 17 19 17 26 23 22 19 22 19 20 19 21 20 27 20 19 18 9 13 9 13 16 10 17 17 16 17 16 12 18 17 7 8 16 7 27 17 17 17 17 11 17 11 17 16 23 16 16 3 1 28 23 22 28 29 12 23 26 22 35 29 28 26 29 27 26 26 28 27 36 27 26 25 12 18 12 18 21 13 23 24 22 24 22 15 24 24 10 11 22 10 36 24 24 24 24 15 22 14 24 21 32 21 21 Clearance No.: BRT#154 3 2 36 29 29 37 37 15 30 34 29 46 37 37 34 38 33 33 32 37 34 46 34 34 32 15 22 15 23 26 17 30 31 28 31 29 19 31 31 13 14 28 13 47 31 31 31 31 19 29 17 31 27 41 27 27 3 3 48 39 39 48 50 20 40 45 39 62 50 49 45 50 45 43 42 48 45 61 45 45 42 19 29 19 30 34 22 39 40 37 40 37 25 41 41 18 18 36 18 63 41 40 40 40 25 38 23 41 36 54 36 36 3 4 63 50 50 62 65 26 50 58 51 79 65 63 58 64 58 56 56 62 58 79 58 58 55 25 38 25 38 43 29 50 52 48 52 48 31 52 52 23 23 47 23 80 52 52 51 52 32 48 29 52 46 70 46 46 23 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Font Index => 122 Z 123 { 124 | 125 } 126 ~ 127 DEL î ì Ä Å Symbol ï Decimal è Symbol ë Decimal ê Symbol ç Decimal å Symbol à 3 4 46 31 23 31 63 23 Decimal ä 3 3 36 24 18 24 47 18 Symbol â 3 2 27 18 14 18 36 13 Decimal é 3 3 0 1 15 22 11 15 7 10 10 15 21 29 5 10 pixels Symbol Decimal 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 ü 2 2 8 9 11 12 8 8 5 6 7 9 14 15 5 6 width in Decimal Symbol Ç 2 2 2 2 2 2 2 2 0 1 2 3 4 5 6 7 5 7 8 9 12 16 8 9 3 5 6 6 8 11 5 6 3 3 4 5 6 9 3 4 3 5 6 6 8 11 5 6 7 8 10 10 14 19 10 11 4 0 0 0 0 0 0 3 Table 4-9 ROM font ASCII character Symbol Decimal 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 16/ 18 8 8 8 8 8 8 Clearance No.: BRT#154 É 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 á 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 ░ 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 └ 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 ╨ 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 α 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 Ξ æ Æ ô ö ò û ù ÿ Ö Ü ₵ £ ¥ Pt ƒ í ó ú ñ Ñ ª º ¿ ⌐ ¬ ½ ¼ ¡ ▒ ▓ │ ┤ ╡ ╢ ╖ ╕ ╣ ║ ╗ ╝ ╜ ┴ ┬ ├ ─ ┼ ╞ ╟ ╚ ╔ ╩ ╦ ╠ ═ ╤ ╥ ╙ ╘ ╒ ╓ ╫ ╪ ┘ ┌ █ ▄ ▌ ╛ ╬ ▐ ┐ ╧ » ▀ Table 4-10 ROM Font Extended ASCII Characters « ß Γ ∏ Σ σ µ τ Φ θ Ω δ ω φ Ɛ Π ± ≥ ≤ ⌠ ⌡ ÷ ≈ ° • · √ ⁿ ² ■ nbsp Note 1: Font 17 and 19 are extended ASCII characters, with width fixed at 8 pixels for all characters. Note 2: All fonts included in the BT817/8 ROM are widely available to the market-place for general usage. 4.4 SPI NOR Flash Interface The BT817/8 implements a SPI master to connect to external SPI NOR Flash. Graphics assets such as Unicode fonts and images can be stored in the flash memory. The BT817/8 graphics engine can fetch these graphics assets directly without going through external host MCU, thus significantly offloading the host MCU from feeding display contents. The BT817/8 supports various NOR flash memory device from different vendors such as Cypress, Macronix, Winbond, Micron, ISSI and Gigadevice. The flash shall support XIP operation. The interface will work at system clock speed at 4 bit mode, providing the maximum data read throughput of 288 Mbit/s. Copyright © Bridgetek Pte Ltd 24 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 Figure 4-7 Flash Interface States The register REG_FLASH_STATE indicates the state of the flash subsystem. At boot the flash state is FLASH_STATE_INIT. After detection has completed flash is in state FLASH_STATE_DETACHED or FLASH_STATE_BASIC, depending on whether an attached flash device was detected. If no device is detected, then all SPIM signals are driven to low or high, except SPIM_MISO which is HiZ. When the host MCU calls CMD_FLASHFAST, the flash system attempts to go to full-speed mode, setting state to FLASH_STATE_FULL (Note: the 4K byte flash blob file needs to program to the flash before the flash can enter full-speed mode). At any time the user can call CMD_FLASHDETACH in order to disable flash communications. In the detached state, commands CMD_FLASHSPIDESEL, CMD_FLASHSPITX and CMD_FLASHSPIRX can be used to control the SPI bus. If detached, the host MCU can call CMD_FLASHATTACH to re-establish communication with the flash device. Direct rendering of bitmaps from flash is only possible in FLASH_STATE_FULL. After modifying the contents of flash, the MCU should clear the on-chip bitmap cache by calling CMD_CLEARCACHE. If the flash is blank (or erased using the CMD_FLASHERASE), it is recommended to use CMD_FLASHPROGRAM to program the flash in order to achieve fastest programming speed. For Micron MT25QL and Cypress S25FL-L series NOR flash, typical programming speed is about 900 kByte/s (assume SPI clock 10MHz or higher in Single SPI mode). 4.5 Parallel RGB Interface The RGB parallel interface consists of 29 signals - DISP, PCLK, VSYNC, HSYNC, DE, 8 signals each for R, G and B. A set of RGB registers configure the LCD operation and timing parameters. REG_PCLK is used to select the display mode and clock divisor. The default value is 0, which means the display scanout is disabled and all RGB signals output Low. When REG_PCLK is set to 1, the display output will be in EXTSYNC mode, where the PCLK frequency is controlled by REG_PCLK_FREQ from PLL2. The maximum PLL2 frequency is 228MHz. The PCLK Copyright © Bridgetek Pte Ltd 25 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 frequency can be set up to 96MHz to align with the optimized PCLK frequency of the selected LCD panel. If PCLK frequency is equal to or higher than system clock frequency (up to double the system clock frequency), the REG_PCLK_2X needs to be 1 so that the graphics engine can send two pixels per system clock to the EXTSYNC block. Note that in this 2X mode, the values loaded in the following registers must be even: REG_HSIZE, REG_HOFFSET, REG_HCYCLE, REG_HSYNC0, REG_HSYNC1. The PCLK frequency in EXTSYNC mode can be calculated as: PLL2 frequency = 12MHz * REG_PCLK_FREQ[8:4] PCLK frequency = PLL2 frequency / REG_PCLK_FREQ[3:0] / 2 REG_PCLK_FREQ[10:9] is determined by PLL2 frequency range: 00: 01: 10: 11: 20 – 40 MHz 40 – 80 MHz 80 – 160 MHz 160 – 228 MHz Table 4-11 lists some of the valid PCLK frequency and REG_PCLK_FREQ values in EXTSYNC mode. fpclk (MHz) REG_PCLK_ FREQ (hex) 96 90 84 78 72 66 60 57 54 D01 CF1 CE1 8D1 8C1 8B1 8A1 D32 891 fpclk (MHz) REG_PCLK_ FREQ (hex) fpclk (MHz) REG_PCLK_ FREQ (hex) fpclk (MHz) REG_PCLK_ FREQ (hex) 51 D12 32 D03 22 8B3 48 881 30 451 21 872 45 CF2 28.5 D34 19.5 8D4 42 871 28 CE3 18 31 39 8D2 27 892 16.5 8B4 38 D33 26 8D3 16 883 36 461 25.5 D14 15 452 34 D13 24 441 13.5 894 33 8B2 22.5 CF4 12 21 Table 4-11 RGB PCLK Frequency in EXTSYNC mode fpclk (MHz) REG_PCLK_ FREQ (hex) 10.5 10 9 8 7.5 6 4.5 4 3 874 453 32 443 454 22 34 23 24 When REG_PCLK is set to 2 to 255, the display out is in pass-through mode, where the PCLK frequency can be calculated as: PCLK frequency = System Clock frequency / REG_PCLK The BT817/8 system clock frequency is programmable. Some of the possible PCLK frequencies that BT817/8 supports in pass-through mode are listed in Table 4-12. System Clock Frequency (MHz) REG_PCLK 2 3 4 5 6 7 8 9 10 72 60(default) 48 36 30 24 24 20 16 18 15 12 14.5 12 9.6 12 10 8.0 10.3 8.6 6.9 9 7.5 6.0 8 6.7 5.3 7.2 6.0 4.8 Table 4-12 RGB PCLK Frequency in Pass-Through 36 18 12 9.0 7.2 6.0 5.1 4.5 4.0 3.6 mode 24 12 8.0 6.0 4.8 4.0 3.4 3.0 2.7 2.4 REG_PCLK_POL defines the clock polarity, with 0 for positive active clock edge, and 1 for negative clock edge. REG_CSPREAD controls the transition of RGB signals with respect to the PCLK active clock edge. When REG_CSPREAD=0, R[7:0], G[7:0] and B[7:0] signals change following the active edge of PCLK. When REG_CSPREAD=1, R[7:0] changes a PCLK clock early and B[7:0] a PCLK clock later, which helps reduce the switching noise. Copyright © Bridgetek Pte Ltd 26 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 REG_DITHER enables colour dither. To improve image quality, the graphics engine applies a 2x2 color dither matrix to output pixels. This option improves the half-tone appearance on displays, even on 1bit displays. Note that the dither function is not applicable to 2X mode (REG_PCLK_2X=1). REG_OUTBITS gives the bit width of each colour channel. The default is 8/8/8 bits for each R/G/B colour, giving total colour depth of 16,777,216 colours. A lower value means fewer bits are output for that colour channel, allowing dithering on lower precision LCD displays. A typical lower precision LCD has 6/6/6 bits for each R/G/B colour, giving total colour depth of 262,144 colours. For 6/6/6 bits configuration, pins R2-R7, G2-G7 and B2-B7 will be used, while pins R0,R1,G0,G1,B0,B1 can be left un-connected. REG_SWIZZLE controls the arrangement of the output colour pins, to help PCB routing with different LCD panel arrangements. Bit 0 of the register causes the order of bits in each colour channel to be reversed. Bits 1-3 control the RGB order. Setting Bit 1 causes R and B channels to be swapped. Setting Bit 3 allows rotation to be enabled. If Bit 3 is set, then (R, G, B) is rotated right if bit 2 is one, or left if bit 2 is zero. REG_SWIZZLE b3 b2 b1 b0 0 X 0 0 X 0 0 X 1 0 X 1 1 0 0 1 0 0 1 0 1 1 0 1 1 1 0 1 1 0 1 1 1 1 1 1 Table 4-13 R7, R6, R5, R4, R3, R2, R1, R0 0 R[7:0] 1 R[0:7] 0 B[7:0] 1 B[0:7] 0 B[7:0] 1 B[0:7] 0 G[7:0] 1 G[0:7] 0 G[7:0] 1 G[0:7] 0 R[7:0] 1 R[0:7] REG_SWIZZLE RGB PINS G7, G6, B7, B6, G5, G4, B5, B4, G3, G2, B3, B2, G1, G0 B1, B0 G[7:0] B[7:0] G[0:7] B[0:7] G[7:0] R[7:0] G[0:7] R[0:7] R[7:0] G[7:0] R[0:7] G[0:7] R[7:0] B[7:0] R[0:7] B[0:7] B[7:0] R[7:0] B[0:7] R[0:7] B[7:0] G[7:0] B[0:7] G[0:7] RGB Pins Mapping REG_HCYCLE, REG_HSIZE, REG_HOFFSET, REG_HSYNC0 and REG_HSYNC1 define the LCD horizontal timings. Each register has 12 bits to allow programmable range of 0-4095 PCLK cycles. REG_VCYCLE, REG_VSIZE, REG_VOFFSET, REG_VSYNC0 and REG_VSYNC1 define the LCD vertical timings. Each register has 12 bits to allow a programmable range of 0-4095 lines. Vertical Horizontal Register REG_HCYCLE Display Parameter TH REG_HSIZE REG_HOFFSET THD THF + THP + THB REG_HSYNC0 REG_HSYNC1 THF THF + THP REG_VCYCLE TV REG_VSIZE REG_VOFFSET TVD TVF + TVP + TVB REG_VSYNC0 REG_VSYNC1 TVF TVF + TVP Description Total length of line (visible and non-visible) (in PCLKs) Length of visible part of line (in PCLKs) Length of non-visible part of line. Must be < TH THD (in PCLK cycles) Horizontal Front Porch (in PCLK cycles) Horizontal Front Porch plus Hsync Pulse width (in PCLK cycles) Total number of lines (visible and non-visible) (in lines) Number of visible lines (in lines) Number of non-visible lines. Must be < TV - TVD (in lines) Vertical Front Porch (in lines) Vertical Front Porch plus Vsync Pulse width (in lines) Table 4-14 Registers for RGB Horizontal and Vertical Timings Copyright © Bridgetek Pte Ltd 27 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 Figure 4-8 RGB Timing Waveforms BT817/8 supports adaptive HSYNC and adaptive framerate operations. In adaptive HSYNC mode the graphics engine may delay the start of the scanout line up to the cycle count given in REG_AH_HCYCLE_MAX, while keeping PCLK running. Adaptive HSYNC is enabled when REG_AH_HCYCLE_MAX is set to a non-zero value between REG_HCYCLE and 4095. In adaptive framerate mode the graphics engine may suspend PLCK if the next scanout line is not ready. BT817/8 supports Horizontal Scanout Filter (HSF) operation. The HSF applies a high-quality filter to output pixels, correcting for LCD panels with non-square pixels (the physical size of the LCD pixel is not square). HSF is enabled and disabled with CMD_HSF. Note that HSF and 2X are not supported together. Table 4-15 lists all the supported display modes for the RGB interface. EXTSYNC 2X adaptive HSF No No No No passthrough mode No No framerate No passthrough, adaptive framerate No No hsync No passthrough, adaptive hsync No No * Yes not supported Yes No No No extsync mode Yes No No Yes extsync, HSF Yes No framerate No Yes No framerate Yes Yes No hsync No extsync, adaptive framerate extsync, adaptive framerate, HSF extsync, adaptive hsync Yes No hsync Yes extsync, adaptive hsync, HSF Copyright © Bridgetek Pte Ltd Description 28 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 Yes Yes No No extsync mode, 2X pixels Yes Yes framerate No extsync, 2X, adaptive framerate Yes Yes hsync No extsync, 2X, adaptive hsync Yes Yes * Yes not supported Table 4-15 Display mode 4.6 Miscellaneous Control 4.6.1 Backlight Control Pin The backlight dimming control pin (BACKLIGHT) is a Pulse-width Modulation (PWM) signal controlled by two registers: REG_PWM_HZ and REG_PWM_DUTY. REG_PWM_HZ specifies the PWM output frequency, the range is 250-10000 Hz. REG_PWM_DUTY specifies the duty cycle; the range is 0-128. A value of 0 means that the PWM is completely off and 128 means completely on. The BACKLIGHT pin will output low when the DISP pin is not enabled (i.e. logic 0). 4.6.2 DISP Control Pin The DISP pin is a general purpose output that can be used to enable, or reset the LCD display panel. The pin is controlled by writing to Bit 7 of the REG_GPIO register, or bit 15 of REG_GPIOX. 4.6.3 General Purpose IO pins The BT817/8 can be configured to use up to 4 GPIO pins. These GPIO pins are controlled by the REG_GPIOX_DIR and REG_GPIOX registers. Alternatively the GPIO0 and GPIO1 pins can also be controlled by REG_GPIO_DIR and REG_GPIO to maintain backward compatibility with the FT800/FT801. When the QSPI is enabled in Quad mode, GPIO0/IO2 and GPIO1/IO3 pins are used as data lines of the QSPI. 4.6.4 Pins Drive Current Control The output drive current of output pins can be changed as per the following table by writing to bit[6:2] of REG_GPIO register or bit[14:10] of REG_GPIOX register. Alternatively, use the SPI command PINDRIVE to change the individual pin drive strength. REG_GPIO REG_GPIOX Value Drive Strength Degree 00b# DSD1 Pins Bit[6:5] Bit[14:13] 01b 10b DSD2 DSD3 GPIO0 GPIO1 GPIO2 GPIO3 CTP_RST_N 11b DSD4 Bit[4] Bit[12] 0b# 1b DSD1 DSD2 00b# Bit[3:2] Bit[11:10] 01b 10b DSD1 DSD2 PCLK DISP VSYNC HSYNC DE R7..R0 G7..G0 B7..B0 BACKLIGHT DSD3 MISO MOSI IO2 IO3 INT_N SPIM_SCLK SPIM_SS_N SPIM_MOSI SPIM_MISO SPIM_IO2 SPIM_IO3 Table 4-16 Output Drive Current Selection Note: #Default value Copyright © Bridgetek Pte Ltd 29 11 b D S D 4 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 4.7 Audio Engine BT817/8 provides mono audio output with sigma-delta modulation through a digital output pin, AUDIO_L. It outputs two audio sources, the sound synthesizer and audio file playback. 4.7.1 Sound Synthesizer A sound processor, AUDIO ENGINE, generates the sound effects from a small ROM library of waves table. To play a sound effect listed in Table 4.3, load the REG_SOUND register with a code value and write 1 to the REG_PLAY register. The REG_PLAY register reads 1 while the effect is playing and returns a ‘0’ when the effect ends. Some sound effects play continuously until interrupted or instructed to play the next sound effect. To interrupt an effect, write a new value to REG_SOUND and REG_PLAY registers; e.g. write 0 (Silence) to REG_SOUND and 1 to PEG_PLAY to stop the sound effect. The sound volume is controlled by register REG_VOL_SOUND. The 16-bit REG_SOUND register takes an 8-bit sound in the low byte. For some sounds, marked "pitch adjust" in the table below, the high 8 bits contain a MIDI note value. For these sounds, a note value of zero indicates middle C. For other sounds the high byte of REG_SOUND is ignored. Value Effect 00h Silence 01h square wave 02h sine wave 03h sawtooth wave 04h triangle wave 05h Beeping 06h Alarm 07h Warble 08h Carousel 10h 11h 12h 13h 14h 15h 16h 17h 18h 19h 1 short pip 2 short pips 3 short pips 4 short pips 5 short pips 6 short pips 7 short pips 8 short pips 9 short pips 10 short pips 1Ah 11 short pips 1Bh 12 short pips 1Ch 13 short pips 1Dh 14 short pips Copyright © Bridgetek Pte Ltd Conti nuous Y Y Y Y Y Y Y Y Y N N N N N N N N N N N N N N Pitch adjus t Value Effect N 32h DTMF 2 Y 33h DTMF 3 Y 34h DTMF 4 Y 35h DTMF 5 Y 36h DTMF 6 Y 37h DTMF 7 Y 38h DTMF 8 Y 39h DTMF 9 Y 40h harp Y Y Y Y Y Y Y Y Y 41h 42h 43h 44h 45h 46h 47h 48h 49h xylophone tuba glockenspiel organ trumpet piano chimes music box bell Y 50h click Y 51h switch Y 52h cowbell Y 53h notch Y 54h hihat Conti nuous Y Pitch adjus t N Y N Y N Y N Y N Y N Y N Y N N N N N N N N N N N Y Y Y Y Y Y Y Y Y N Y N N N N N N N N N 30 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 1Eh 15 short pips 1Fh 16 short pips 23h DTMF # 2Ch DTMF * 30h DTMF 0 31h DTMF 1 N N Y Y Y Y Y 55h kickdrum Y 56h pop N 57h clack N 58h chack N 60h mute N 61h unmute Clearance No.: BRT#154 N N N N N N N N N N N N Table 4-17 Sound Effect MIDI note ANSI note Freq (Hz) MIDI note ANSI note Freq (Hz) 21 A0 27.5 65 F4 349.2 22 A#0 29.1 66 F#4 370.0 23 B0 30.9 67 G4 392.0 24 C1 32.7 68 G#4 415.3 25 C#1 34.6 69 A4 440.0 26 D1 36.7 70 A#4 466.2 27 D#1 38.9 71 B4 493.9 28 E1 41.2 72 C5 523.3 29 F1 43.7 73 C#5 554.4 30 F#1 46.2 74 D5 587.3 31 G1 49.0 75 D#5 622.3 32 G#1 51.9 76 E5 659.3 33 A1 55.0 77 F5 698.5 34 A#1 58.3 78 F#5 740.0 35 B1 61.7 79 G5 784.0 36 C2 65.4 80 G#5 830.6 37 C#2 69.3 81 A5 880.0 38 D2 73.4 82 A#5 932.3 39 D#2 77.8 83 B5 987.8 40 E2 82.4 84 C6 1046.5 41 F2 87.3 85 C#6 1108.7 42 F#2 92.5 86 D6 1174.7 43 G2 98.0 87 D#6 1244.5 44 G#2 103.8 88 E6 1318.5 45 A2 110.0 89 F6 1396.9 46 A#2 116.5 90 F#6 1480.0 47 B2 123.5 91 G6 1568.0 48 C3 130.8 92 G#6 1661.2 49 C#3 138.6 93 A6 1760.0 Copyright © Bridgetek Pte Ltd 31 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 4.7.2 Clearance No.: BRT#154 50 D3 146.8 94 A#6 1864.7 51 D#3 155.6 95 B6 1975.5 52 E3 164.8 96 C7 2093.0 53 F3 174.6 97 C#7 2217.5 54 F#3 185.0 98 D7 2349.3 55 G3 196.0 99 D#7 2489.0 56 G#3 207.7 100 E7 2637.0 57 A3 220.0 101 F7 2793.8 58 A#3 233.1 102 F#7 2960.0 59 B3 246.9 103 G7 3136.0 60 C4 261.6 104 G#7 3322.4 61 C#4 277.2 105 A7 3520.0 62 D4 293.7 106 A#7 3729.3 63 D#4 311.1 107 B7 3951.1 64 E4 329.6 108 C8 Table 4-18 MIDI Note Effect 4186.0 Audio Playback The BT817/8 can play back recorded sound through its audio output. To do this, load the original sound data into the BT817/8’s RAM, and set registers to start the playback. The registers controlling audio playback are: REG_PLAYBACK_START: the start address of the audio data REG_PLAYBACK_LENGTH: the length of the audio data, in bytes REG_PLAYBACK_FREQ: the playback sampling frequency, in Hz REG_PLAYBACK_FORMAT: the playback format, one of LINEAR SAMPLES, uLAW SAMPLES, or ADPCM SAMPLES REG_PLAYBACK_LOOP: if zero, the sample is played once. If one, the sample is repeated indefinitely REG_PLAYBACK_PLAY: a write to this location triggers the start of audio playback, regardless of writing ‘0’ or ‘1’. Read back ‘1’ when playback is ongoing, and ‘0’ when playback finishes REG_VOL_PB: playback volume, 0-255 The mono audio formats supported are 8-bits PCM, 8-bits uLAW and 4-bits IMA-ADPCM. For ADPCM_SAMPLES, each sample is 4 bits, so two samples are packed per byte, the first sample is in bits 0-3 and the second is in bits 4-7. The current audio playback read pointer can be queried by reading the REG_PLAYBACK_READPTR. Using a large sample buffer, looping, and this read pointer, the host MPU/MCU can supply a continuous stream of audio. 4.8 Touch-Screen Engine The BT817/8 touch-screen engine supports both resistive and capacitive touch panels. BT818 supports resistive touch, while BT817 supports capacitive touch. 4.8.1 Resistive Touch Control The resistive touch-screen consists of a touch screen engine, ADC, Axis-switches, and ADC input multiplexer. The touch screen engine reads commands from the memory map register and generates Copyright © Bridgetek Pte Ltd 32 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 the required control signals to the axis-switches and inputs mux and ADC. The ADC data is acquired, processed and updated in the respective register for the MPU/MCU to read. BT818 Y+ XP YP XM YM X- Resistive Touch Screen X+ Y- Figure 4-9 Resistive Touch Screen Connection The host controls the TOUCH SCREEN ENGINE operation mode by writing the REG_TOUCH_MODE. REG_TOUCH_MODE 0 1 2 3 Mode OFF Description Acquisition stopped, only touch detection interrupt is still valid. ONE-SHOT Perform acquisition once every time the MPU writes '1' to REG_TOUCH_MODE. FRAME-SYNC Perform acquisition for every frame sync (~60 data acquisition/second. CONTINUOUS Perform acquisition continuously at approximately 1000 data acquisition / second. Table 4-19 Resistive Touch Controller Operating Mode The Touch Screen Engine captures the raw X and Y coordinate and writes to register REG_TOUCH_RAW XY. The range of these values is 0-1023. If the touch screen is not being pressed, both registers read 65535 (FFFFh). These touch values are transformed into screen coordinates using the matrix in registers REG_TOUCH_TRANSFORM_A-F. The post-transform coordinates are available in register REG_TOUCH_SCREEN_XY. If the touch screen is not being pressed, both registers read -32768 (8000h). The values for REG TOUCH TRANSFORM A-F may be computed using an on-screen calibration process. If the screen is being touched, the screen coordinates are looked up in the screen's tag buffer, delivering a final 8-bit tag value, in REG TOUCH TAG. Because the tag lookup takes a full frame, and touch coordinates change continuously, the original (x; y) used for the tag lookup is also available in REG_TOUCH_TAG_XY. Screen touch pressure is available in REG_TOUCH_RZ. The value is relative to the resistance of the touch contact, a lower value indicates more pressure. The register defaults to 32767 when touch is not detected. The REG_TOUCH_RZTHRESH (valid in touch continuous mode, frame mode and one-shot mode) can be set to accept a touch only when the force threshold is exceeded. 4.8.2 Capacitive Touch Control The Capacitive Touch Screen Engine (CTSE) of the BT817 communicates with the external capacitive touch panel module (CTPM) through an I2C interface. The CTPM will assert its interrupt line when there is a touch detected. Upon detecting CTP_INT_N line active, the BT817/8 will read the touch data through I2C. Up to 5 touches can be reported and stored in BT817 registers. The BT817 built-in ROM code supports Focaltech, Hycontek and Goodix touch controllers, as well as touch host mode (refer to Copyright © Bridgetek Pte Ltd 33 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 section 4.8.7). For a supported CTPM list please refer to AN_336 FT8xx - Selecting an LCD Display. For other touch controller IC, consult Bridgetek. The BT817 uses the I2C address value in the REG_TOUCH_CONFIG register to differentiate Focaltech/Hycontek and Goodix touch controllers. For Focaltech/Hycontek IC the I2C address must be set as 0x38-0x3F (example: REG_TOUCH_CONFIG = 0x0380), while for Goodix IC the I2C address must be set as 0x5D (example: REG_TOUCH_CONFIG = 0x05D0). The touch engine requires a reset if changing I2C address from default value, as shown below: Write REG_CPURESET = 2 Write REG_TOUCH_CONFIG = 0x05D0 Write REG_CPURESET = 0 //For Goodix touch controller The BT817 supports I2C clock stretch. This is particularly useful for supporting Hycontek touch IC. VCCIO2 (1.8-3.3V) BT817 1K 1K CTP_SCL SCL CTP_SDA SDA CTP_INT_N INTN CTP_RST_N RSTN Capacitive Touch Panel Module Figure 4-10 Touch Screen Connection The host controls the CTSE operation mode by writing the REG_CTOUCH_MODE. REG_CTOUCH_MODE 0 1-2 3 Mode OFF Reserved CONTINUOUS Description Acquisition stopped Reserved Perform acquisition continuously at the reporting rate of the connected CTPM. Table 4-20 Capacitive Touch Controller Operating Mode The BT817 CTSE supports compatibility mode and extended mode. By default the CTSE runs in compatibility mode where the touch system provides an interface very similar to the resistive touch engine. In extended mode, the touch register meanings are modified, and a second set of registers are exposed. These allow multi-touch detection (up to 5 touches). 4.8.3 Compatibility Mode The CTSE reads the X and Y coordinates from the CTPM and writes to register REG_CTOUCH_RAW_XY. If the touch screen is not being pressed, both registers read 65535 (FFFFh). These touch values are transformed into screen coordinates using the matrix in registers REG_CTOUCH_TRANSFORM_A-F. The post-transform coordinates are available in register REG_CTOUCH_SCREEN_XY. If the touch screen is not being pressed, both registers read -32768 (8000h). The values for REG_CTOUCH_TRANSFORM_A-F may be computed using an on-screen calibration process. If the screen is being touched, the screen coordinates are looked up in the screen's tag buffer, delivering a final 8-bit tag value, in REG_TOUCH_TAG. Because the tag lookup takes a full frame, and touch coordinates change continuously, the original (x; y) used for the tag lookup is also available in REG_TOUCH_TAG_XY. Copyright © Bridgetek Pte Ltd 34 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 4.8.4 Clearance No.: BRT#154 Extended Mode Setting REG_CTOUCH_EXTENDED to 1b’0 enables extended mode. In extended mode a new set of readout registers are available, allowing gestures and up to five touches to be read. There are two classes of registers: control registers and status registers. Control registers are written by the MCU. Status registers can be read out by the MCU and the BT817/8’s hardware tag system. The five touch coordinates are packed in REG_CTOUCH_TOUCH0_XY, REG_CTOUCH_TOUCH1_XY, REG_CTOUCH_TOUCH2_XY, REG_CTOUCH_TOUCH3_XY, REG_CTOUCH4_X and REG_CTOUCH4_Y. Coordinates stored in these registers are signed 16-bit values, so have a range of -32768 to 32767. The no-touch condition is indicated by x=y= -32768. These coordinates are already transformed into screen coordinates based on the raw data read from the CTPM, using the matrix in registers REG_CTOUCH_TRANSFORM_A-F. To obtain raw (x,y) coordinates read from CTPM, the user sets the REG_CTOUCH_TRANSFORM_A-F registers to the identity matrix. The BT817/8 tag mechanism is implemented by hardware, where up to 5 tags can be looked up. In touch extended mode, the INT_TOUCH bit in REG_INT_FLAG register will not be set upon touch down event. It is recommended to use INT_CONV_COMPLETE bit instead. 4.8.5 Short-Circuit Protection For resistive touch it is useful to protect the chip from permanent damage due to potential shortcircuits on the 4 XY lines. When a short circuit on the touch screen happens, the BT818 can detect it and stop the touch detection operation, leaving the 4 XY pins in the high impedance state. The short-circuit protection can be enabled/disabled by the REG_TOUCH_CONFIG. 4.8.6 Capacitive Touch Configuration On a capacitive touch system some users may need to adjust the CTPM default values, such as the registers affecting touch sensitivity. To do this the following sequence shall be executed once after chip reset: - Hold the touch engine in reset (set REG_CPURESET = 2) Write the CTPM configure register address and value to the BT817 designated memory location Up to 10 register address/value can be added Release the touch engine reset (set REG_CPURESET = 0) Sample codes are listed below for configuring Focaltech touch controller: #define FW_RD(a) VC.rd16(RAM_JTBOOT + 2 * (a)) #define FW_WR(a, v) VC.wr16(RAM_JTBOOT + 2 * (a), (v)) void init_custom_touch(size_t num_regs, uint8_t *reg_value) { while (VC.rd(REG_CPURESET) != 0) ; VC.wr(REG_CPURESET, 2); uint16_t uint16_t uint16_t uint16_t main = FW_RD(0) & 0xfff; i_set = 0x4000 | (main - 4); patch = main + 1; i_eol = FW_RD(patch); while (num_regs--) { uint8_t reg = *reg_value++; uint8_t val = *reg_value++; FW_WR(patch++, 0x8000 | val); FW_WR(patch++, 0x8000 | reg); Copyright © Bridgetek Pte Ltd 35 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 FW_WR(patch++, i_set); } FW_WR(patch, i_eol); VC.wr(REG_CPURESET, 0); } The CTPM can be enabled in low power state when the touch function is not required by the application. Setting the low-power bit in REG_TOUCH_CONFIG will enable the low power mode of the CTPM. When the low-power bit is cleared, the BT817 touch engine will send a reset to the CTPM, thus re-enabling the touch detection function. 4.8.7 Host Driven Multi-Touch If the host MCU can provide touch inputs, it can supply them directly to the BT817 using touch host mode. By using touch host mode, an application can choose to select a touch controller that is not in the BT817 direct support list. For example, Touch Host mode would allow controllers to be used from other manufacturers beyond Focaltech and Goodix. To use the touch host mode, the host MCU shall be connected to the touch panel directly. The four touch related pins of the BT817 can be left unconnected on the PCB. The host MCU is responsible for communicating with the touch controller, fetching the touch data when reported, and writing the touch data to the BT817 for touch TAG lookup and reporting. The touch host mode can be entered by setting bit 14 in register REG_TOUCH_CONFIG and resetting the touch engine: - Hold the touch engine in reset (set REG_CPURESET = 2) Write 1 to bit 14 in REG_TOUCH_CONFIG (set REG_TOUCH_CONFIG = 0x4000) Release the touch engine reset (set REG_CPURESET = 0) Figure 4-11 Touch Host Mode Connections In touch host mode, the host supplies touch information via four registers: BT817 address 0x30210c Register Name Bits REG_EHOST_TOUCH_X 0x302118 REG_EHOST_TOUCH_Y 0x302114 0x302170 REG_EHOST_TOUCH_ID Touch ID / phase REG_EHOST_TOUCH_ACK Acknowledgement Table 4-21 Registers for Touch Host Mode Unsigned 16-bit Unsigned 16-bit 4-bit 4-bit Description Touch x coordinate Touch y coordinate The host writes raw (x; y) coordinates and IDs to the above registers. Up to 5 touches can be set, using touch IDs 0-4. The host indicates no touch by supplying coordinates (0x8000; 0x8000). When Copyright © Bridgetek Pte Ltd 36 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 the host writes 0xf to the ID register, BT817 sets the ACK register to 0, transforms all the raw coordinates, and writes the results to the regular touch registers. Pseudocode: wait until REG_EHOST_TOUCH_ACK is 1 for each touch: write write write write x coordinate to REG_EHOST_TOUCH_X y coordinate to REG_EHOST_TOUCH_Y id to REG_EHOST_TOUCH_ID 0xf to REG_EHOST_TOUCH_ID As soon as BT817 has converted the coordinates, it writes 1 to the ACK register and sets the INT_CONV_COMPLETE interrupt flag. The ID should be zero in touch compatibility mode. The host should indicate no touch at all by writing (0x8000; 0x8000) with ID 0. In extended mode, the multiple touches may be sent in any order. Any IDs not assigned are assumed to be not pressed. Again, the host should indicate no touch at all by writing (0x8000; 0x8000) with ID 0. The host can use three methods to ensure that BT817 is ready to accept touch inputs: 1. poll the ACK register until it is 1 2. use the INT_CONV_COMPLETE interrupt flag 3. supply touches slower than 1000 Hz, since BT817 guarantees to process the touches in under 1 ms. Note that report rates from capacitive touch panels are about 100 Hz Like the direct capacitive driver, this touch host mode works when REG_CTOUCH_EXTENDED is both CTOUCH_MODE_EXTENDED and CTOUCH_MODE_COMPATIBILITY. CTOUCH_MODE_COMPATIBILITY should be used for the calibration procedure, just as when using native capacitive support. After changing mode, the BT817 touch engine must be reset. 4.8.8 Touch Detection in none-ACTIVE State When the BT817/8 is in non-ACTIVE state, a touch event can still be detected and reported to the host through the INT_N pin. In other words, a touch event can wake-up the host if needed. For resistive touch, the INT_N pin will be asserted low when the screen is touched, regardless of the setting of the interrupt registers. This will happen when the BT818 is in STANDBY or SLEEP state, but not in POWERDOWN state. For capacitive touch, the INT_N pin will follow CTP_INT_N pin when the BT817 is in STANDBY, SLEEP or POWERDOWN state. 4.9 Power Management 4.9.1 Power Supply The BT817/8 may be operated with a single supply of 3.3V applied to VCC and VCCIO pins. For operation with a host MPU/MCU at a lower supply, connect the VCCIO1 to the MPU IO supply to match the interface voltage. For operation with LCD/touch panels at lower voltages, connect the VCCIO2 to the LCD/touch IO supply. Symbol VCCIO1 VCCIO2 Typical 1.8V, or 2.5V, or 3.3V 1.8V, or 2.5V, or 3.3V Copyright © Bridgetek Pte Ltd Description Supply for Host interface digital I/O pins Supply for RGB and touch interface I/O pins 37 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 VCCIO3 VCCA VCC VOUT1V2, VCC1V2 1.8V, or 2.5V, or 3.3V 3.3V 3.3V 1.2V Clearance No.: BRT#154 Supply for NOR Flash interface I/O pins Supply for AUDIO_L pin and ADC circuit Supply for 3.3V circuits and internal 1.2V regulator Supply for digital core. Generated by internal regulator Table 4-22 Power Supply 4.9.2 Internal Regulator and POR The internal regulator outputs 1.2V to supply power to the core circuit. The internal regulator requires a compensation capacitor (minimum 3.3uF) to be stable. A typical design uses a 4.7uF or 10uF capacitor between the VOUT1V2 and GND pins. Do not connect any other load to the VOUT1V2 pin. The internal regulator will generate a Power-On-Reset (POR) pulse when the output voltage rises above the POR threshold. The POR will reset all the core digital circuits. 4.9.3 Power Modes When the supply to VCCIO and VCC is applied, the internal regulator is powered by VCC. An internal POR pulse will be generated during the regulator power up until it is stable. After the initial power up, the BT817/8 will stay in the SLEEP state. When needed, the host can set the BT817/8 to the ACTIVE state by performing a SPI ACTIVE command. The graphics engine, the audio engine and the touch engine are only functional in the ACTIVE state. To save power the host can send a command to put the BT817/8 into any of the low power modes: STANDBY, SLEEP and POWERDOWN. In addition, the host is allowed to put the BT817/8 in POWERDOWN mode from ACTIVE mode by driving the PD_N pin to low. Refer to Figure 4-12 for the power state transitions. Command VCC/VCCIO “PWRDOWN” Power ON POWERDOWN SLEEP Command “ACTIVE” Command “PWRDOWN” Command Command “PWRDOWN” “SLEEP” Command “ACTIVE” STANDBY ACTIVE Command “STANDBY” Figure 4-12 Power State Transition Copyright © Bridgetek Pte Ltd 38 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 4.9.3.1 Clearance No.: BRT#154 ACTIVE state In ACTIVE state, the BT817/8 is in normal operation. The clock oscillator and PLL are functioning. The system clock applied to the BT817/8 core engines is enabled. 4.9.3.2 STANDBY state In STANDBY state, the clock oscillator and PLL remain functioning; the system clock applied to the BT817/8 core engines is disabled. All register contents are retained. 4.9.3.3 SLEEP state In SLEEP state, the clock oscillator, PLL and system clock applied to the BT817/8 core engines are disabled. All register contents are retained. 4.9.3.4 POWERDOWN state In POWERDOWN state, the clock oscillator, the PLL and the system clock applied to the BT817/8 core is disabled. The core engines are powered down while the SPI interface for host commands remains functional. All register contents are lost and reset to default when the chip is next switched on. The internal regulator remains on. 4.9.3.5 Wake up to ACTIVE from other power states When in the POWERDOWN state, if the device enters this state via an SPI command, then only the SPI ACTIVE command will bring the device back to the ACTIVE state, provided PD_N pin is also high. However, if PD_N is used instead, then making PD_N high followed by a SPI ACTIVE command will wake up the device. Upon exiting this state, the device will perform a global reset, and will go through the same power up sequence. All settings from SPI commands will be reset except those that pertain to pin states during power down. The clock enable sequence mentioned in section 4.2.3 shall be executed to properly select and enable the system clock. From the SLEEP state, the host MPU sends an SPI ACTIVE command to wake the BT817/8 into the ACTIVE state. The host needs to wait for at least 20ms before accessing any registers or commands. This is to guarantee the clock oscillator and PLL are up and stable. From the STANDBY state, the host MPU sends SPI ACTIVE command to wake the BT817/8 into the ACTIVE state. The host can immediately access any register or command. 4.9.4 Reset and Boot-up Sequence There are a few hardware and software reset events which can be triggered to reset the BT817/8. Hardware reset events:   Power-on-Reset(POR) A low pulse of 5ms on PD_N pin (applicable when chip is in ACTIVE or STANDBY state) Software reset events:    SPI command RST_PULSE SPI command to switch between the internal clock and the external clock SPI command to enter POWERDOWN then wakeup After reset the BT817/8 will be in the SLEEP state. Upon receiving the SPI ACTIVE command (or CLKEXT followed by SPI ACTIVE command if external clock source is used), the clock oscillator and PLL will start up. Once the clock is stable, the chip will check and repair its internal RAM, running the configuration and then entering into normal operations. The boot-up may take up to 300ms to complete. During boot up process, software should not access BT817/8 register or RAM except reading REG_ID and REG_CPURESET. Copyright © Bridgetek Pte Ltd 39 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 4.9.5 Clearance No.: BRT#154 Pin Status at Different Power States The BT817/8 pin status depends on the power state of the chip. See the following table for more details. At the power transition from ACTIVE to STANDBY or ACTIVE to SLEEP, all pins retain their previous status. The software needs to set AUDIO_L, BACKLIGHT to a known state before issuing power transition commands. The pin status in the power down state can be changed by SPI command PIN_PD_STATE. AUDIO_L SCK Default Drive Strength Degree DSD4 - MISO DSD1 MOSI CS_N IO2 GPIO0 IO3 GPIO1 GPIO2 INT_N PD_N GPIO3 SPIM_SCLK SPIM_MISO SPIM_MOSI SPIM_SS_N SPIM_IO2 SPIM_IO3 X1/CLK X2 XP YP XM YM CTP_RST_N CTP_INT_N CTP_SCL CTP_SDA BACKLIGHT DE VSYNC HSYNC DISP PCLK R/G/B DSD1 - Pin Name Copyright © Bridgetek Pte Ltd DSD1 DSD1 DSD1 DSD1 DSD1 DSD1 DSD1 DSD1 DSD1 DSD1 DSD1 DSD1 DSD1 DSD4 DSD4 DSD1 DSD1 DSD1 DSD1 DSD1 DSD1 DSD1 Reset Out, Float In Out, Float (CS_N = 1) In In In In In In In OD, Float In In Float Float Float Float Float Float In Out IO, Float IO, Float IO, Float IO, Float Low In OD OD Low Low Low Low Low Low Low Table 4-23 Pin Status Out In Power Down (Default) Retain In IO Out, Float IO In IO IO IO IO IO OD / Out In IO Out IO IO Out IO IO In Out IO IO IO IO Out IO I/OD I/OD Out Out Out Out Out Out Out In In Float Float Float Float Float Float In Float Float Float Float Float Float Float In High High High Retain Retain Pull Low In Float Float Pull Low Pull Low Pull Low Pull Low Pull Low Pull Low Pull Low Normal 40 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 5 Memory Map All memory and registers in the BT817/8 core are memory mapped in 22-bit address space with a 2bit SPI command prefix. Prefix 0'b00 for read and 0'b10 for write to the address space, 0'b01 is reserved for Host Commands and 0'b11 undefined. The following are the memory space definition. Start Address 00 0000h 20 0000h 30 0000h 30 2000h 30 8000h 30 9800h 30 B000h 80 0000h End Address 0F FFFFh 2F FFFFh 30 1FFFh 30 2FFFh 30 8FFFh 30 98FFh 30 B7FFh 107F FFFFh Size NAME Description 1024 kB 1024 kB 8 kB 4 kB 4 kB 128 B 2 kB 256 MB RAM_G ROM RAM_DL RAM_REG RAM_CMD RAM_ERR_REPORT RAM_JTBOOT FLASH General purpose graphics RAM ROM codes, font table and bitmap Display List RAM Registers Command buffer Coprocessor fault report RAM Touch control codes External NOR flash memory. Maximum 256MB. The address is used by internal command only. Table 5-1 BT817/8 Memory Map Note 1: The addresses beyond this table are reserved and shall not be read or written unless otherwise specified. 5.1 Registers Table 5-2 shows the complete list of the BT817/8 registers. BT81X_Series_Programming_Guide, Chapter 3 for details of the register function. Address (hex) 302000 h Register Name Bit s 8 r/ w r/o Reset value 7Ch 302004h 302008h 30200Ch REG_FRAMES REG_CLOCK REG_FREQUENCY 32 32 28 r/o r/o r/w 0 0 48000000 302010h REG_RENDERMODE 1 r/w 0 302014h REG_SNAPY 11 r/w 0 302018h 30201Ch 302020h REG_SNAPSHOT REG_SNAPFORMAT REG_CPURESET 1 6 3 r/w r/w r/w 20h 2 302024h REG_TAP_CRC 32 r/o - 302028h 30202Ch 302030h 302034h 302038h 30203Ch 302040h 302044h 302048h 30204Ch 302050h REG_TAP_MASK REG_HCYCLE REG_HOFFSET REG_HSIZE REG_HSYNC0 REG_HSYNC1 REG_VCYCLE REG_VOFFSET REG_VSIZE REG_VSYNC0 REG_VSYNC1 32 12 12 12 12 12 12 12 12 10 10 r/w r/w r/w r/w r/w r/w r/w r/w r/w r/w r/w FFFFFFFFh 224h 02Bh 1E0h 000h 029h 124h 00Ch 110h 000h 00Ah REG_ID Copyright © Bridgetek Pte Ltd Refer to Description Identification register, always reads as 7Ch Frame counter, since reset Clock cycles, since reset Main clock frequency (Hz). Firmware sets to 60000000 at boot. Rendering mode: 0 = normal, 1 = single-line Scanline select for RENDERMODE 1 Trigger for RENDERMODE 1 Pixel format for scanline readout Graphics, audio and touch engines reset control. Bit2: audio, bit1: touch, bit0: graphics Live video tap crc. Frame CRC is computed every DL SWAP. Live video tap mask Horizontal total cycle count Horizontal display start offset Horizontal display pixel count Horizontal sync fall offset Horizontal sync rise offset Vertical total cycle count Vertical display start offset Vertical display line count Vertical sync fall offset Vertical sync rise offset 41 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Address (hex) 302054h 302058h Register Name Clearance No.: BRT#154 REG_DLSWAP REG_ROTATE Bit s 2 3 r/ w r/w r/w Reset value 0 0 30205Ch REG_OUTBITS 9 r/w 0 302060h 302064h 302068h 30206Ch REG_DITHER REG_SWIZZLE REG_CSPREAD REG_PCLK_POL 1 4 1 1 r/w r/w r/w r/w 1 0 1 0 302070h REG_PCLK 8 r/w 0 302074h 302078h 30207Ch 302080h 302084h 302088h 30208Ch 302090h REG_TAG_X REG_TAG_Y REG_TAG REG_VOL_PB REG_VOL_SOUND REG_SOUND REG_PLAY REG_GPIO_DIR 11 11 8 8 8 16 1 8 r/w r/w r/o r/w r/w r/w r/w r/w 0 0 0 FFh FFh 0 0h 80h 302094h 302098h REG_GPIO REG_GPIOX_DIR 8 16 r/w r/w 00h 8000h 30209Ch 3020A0h 3020A4h 3020A8h 3020Ach 3020B0h REG_GPIOX Reserved 16 - r/w - 0080h - 9 1 9 r/o r/w r/w 000h 0 1FFh 3020B4h 3020B8h REG_PLAYBACK_START REG_PLAYBACK_LENGTH 20 20 r/w r/w 0 0 3020BCh REG_PLAYBACK_READPTR 20 r/o - 3020C0h REG_PLAYBACK_FREQ 16 r/w 8000 3020C4h 3020C8h 3020CCh 3020D0h REG_PLAYBACK_FORMAT REG_PLAYBACK_LOOP REG_PLAYBACK_PLAY REG_PWM_HZ 2 1 1 14 r/w r/w r/w r/w 0 0 0 250 3020D4h REG_PWM_DUTY 8 r/w 128 3020D8h 3020DCh 3020E0h – 3020F4h 3020F8h REG_MACRO_0 REG_MACRO_1 Reserved 32 32 - r/w r/w - 0 0 - Interrupt flags, clear by read Global interrupt enable, 1=enable Individual interrupt enable, 1=enable. Firmware sets to ffh at boot. Audio playback RAM start address Audio playback sample length (bytes) Audio playback current read pointer Audio playback sampling frequency (Hz) Audio playback format Audio playback loop enable Start audio playback BACKLIGHT PWM output frequency (Hz) BACKLIGHT PWM output duty cycle 0=0%, 128=100% Display list macro command 0 Display list macro command 1 Reserved REG_CMD_READ 12 r/w 0 Command buffer read pointer REG_INT_FLAGS REG_INT_EN REG_INT_MASK Copyright © Bridgetek Pte Ltd Description Display list swap control Screen rotation control. Allow normal/mirrored/inverted for landscape or portrait orientation. Output bit resolution, 3 register bits each for R/G/B data pins. 0 indicates 8 bits, 1-7 indicates 1-7 bits respectively. Output dither enable Output RGB signal swizzle Output clock spreading enable PCLK polarity: 0: output on PCLK rising edge, 1: output on PCLK falling edge PCLK frequency divider 0: disable 1: EXTSYNC mode 2-255: divider from system clock Tag query X coordinate Tag query Y coordinate Tag query result Volume for playback Volume for synthesizer sound Sound effect select Start effect playback Legacy GPIO pin direction, 0 = input , 1 = output Legacy GPIO read/write Extended GPIO pin direction, 0 = input , 1 = output Extended GPIO read/write Reserved 42 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Address (hex) 3020FCh 302100h 302104h 302108h Register Name 30210Ch REG_TOUCH_CHARGE REG_EHOST_TOUCH_X 302110h 302114h 302118h Bit s 12 13 2 1 r/ w r/o r/w r/w r/w Reset value 0 0 3 1 16 r/w 9000 REG_TOUCH_SETTLE 4 r/w 3 REG_TOUCH_OVERSAMPL E REG_EHOST_TOUCH_ID REG_TOUCH_RZTHRESH REG_EHOST_TOUCH_Y 4 r/w 7 16 r/w FFFFh REG_CMD_WRITE REG_CMD_DL REG_TOUCH_MODE REG_TOUCH_ADC_MODE REG_CTOUCH_EXTENDED 30211Ch REG_TOUCH_ RAW_XY REG_CTOUCH_TOUCH1_X Y 32 r/o - 302120h REG_TOUCH_RZ REG_CTOUCH_TOUCH4_Y 16 r/o - 302124h REG_TOUCH_ SCREEN_XY REG_CTOUCH_TOUCH0_X Y 32 r/o - 302128h REG_TOUCH_ TAG_XY REG_TOUCH_TAG REG_TOUCH_ TAG1_XY REG_TOUCH_TAG1 REG_TOUCH_ TAG2_XY REG_TOUCH_TAG2 REG_TOUCH_ TAG3_XY REG_TOUCH_TAG3 REG_TOUCH_ TAG4_XY REG_TOUCH_TAG4 REG_TOUCH_TRANSFORM _A REG_TOUCH_TRANSFORM _B REG_TOUCH_TRANSFORM _C REG_TOUCH_TRANSFORM _D 32 r/o - 8 32 r/o r/o - 8 32 r/o r/o - 8 32 r/o r/o - 8 32 r/o r/o - 8 32 r/o r/w 00010000h 32 r/w 00000000h 32 r/w 00000000h 32 r/w 00000000h 30212Ch 302130h 302134h 302138h 30213Ch 302140h 302144h 302148h 30214Ch 302150h 302154h 302158h 30215Ch Copyright © Bridgetek Pte Ltd Clearance No.: BRT#154 Description Command buffer write pointer Command display list offset Touch-screen sampling mode Set Touch ADC mode Set capacitive touch operation mode: 0: extended mode (multi-touch) 1: FT800 compatibility mode (single touch). Touch charge time, units of 6 clocks Touch host mode: touch x value updated by host Touch settle time, units of 6 clocks Touch oversample factor Touch host mode: touch ID, 0-4 Touch resistance threshold Touch host mode: touch x value updated by host Compatibility mode: touch-screen raw (x-MSB16; y-LSB16) Extended mode: touch-screen screen data for touch 1 (xMSB16; y-LSB16) Compatibility mode: touchscreen resistance Extended mode: touch-screen screen Y data for touch 4 Compatibility mode: touch-screen screen (x-MSB16; y-LSB16) Extended mode: touch-screen screen data for touch 0 (xMSB16; y-LSB16) Touch-screen screen (x-MSB16; y-LSB16) used for tag 0 lookup Touch-screen tag result 0 Touch-screen screen (x-MSB16; y-LSB16) used for tag 1 lookup Touch-screen tag result 1 Touch-screen screen (x-MSB16; y-LSB16) used for tag 2 lookup Touch-screen tag result 2 Touch-screen screen (x-MSB16; y-LSB16) used for tag 3 lookup Touch-screen tag result 3 Touch-screen screen (x-MSB16; y-LSB16) used for tag 4 lookup Touch-screen tag result 4 Touch-screen transform coefficient (s15.16) Touch-screen transform coefficient (s15.16) Touch-screen transform coefficient (s15.16) Touch-screen transform coefficient (s15.16) 43 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Address (hex) 302160h Register Name Bit s 32 r/ w r/w Reset value 00010000h 32 r/w 00000000h 16 r/w 8381h (BT818) 0381h (BT817) Clearance No.: BRT#154 Description 302168h REG_TOUCH_TRANSFORM _E REG_TOUCH_TRANSFORM _F REG_TOUCH_CONFIG 30216Ch REG_CTOUCH_TOUCH4_X 16 r/o - 302170h REG_EHOST_TOUCH_ACK 4 r/w 0 302174h REG_BIST_EN 1 r/w 0 Touch-screen transform coefficient (s15.16) Touch-screen transform coefficient (s15.16) Touch configuration. RTP/CTP select RTP: short-circuit, sample clocks CTP: I2C address, CTPM type, low-power mode, touch host mode Extended mode: touch-screen screen X data for touch 4 Touch host mode: acknowledgement BIST memory mapping enable 302178h 302187C h 302180h 302184h 302188h Reserved - - - Reserved REG_TRIM REG_ANA_COMP REG_SPI_WIDTH 5 8 3 r/w r/w r/w 0 0 0 30218Ch REG_TOUCH_DIRECT_XY 32 r/o - 32 r/o - - - Internal relaxation clock trimming Analogue control register QSPI bus width setting Bit [2]: extra dummy cycle on read Bit [1:0]: bus width (0=1-bit, 1=2-bit, 2=4-bit) Compatibility mode: Touch screen direct (x-MSB16; y-LSB16) conversions Extended mode: touch-screen screen data for touch 2 (xMSB16; y-LSB16) Compatibility mode: Touch screen direct (z1-MSB16; z2-LSB16) conversions Extended mode: touch-screen screen data for touch 3 (xMSB16; y-LSB16) Reserved 302164h REG_CTOUCH_TOUCH2_X Y 302190h REG_TOUCH_DIRECT_Z1Z 2 REG_CTOUCH_TOUCH3_X Y 302194h 302560h 302564h 302574h Reserved 302578h 30257Ch 3025ECh REG_CMDB_WRITE REG_ADAPTIVE_FRAMERA TE REG_PLAYBACK_PAUSE 3025F0h REG_DATESTAMP REG_CMDB_SPACE 128 12 r/o r/w FFCh 32 1 w/o r/w 0 1 1 r/w 0 REG_FLASH_STATUS 2 r/w 0 3025F4h302608h 30260Ch 302610h Reserved - - - REG_UNDERRUN REG_AH_HCYCLE_MAX 32 12 r/o r/w 0 302614h REG_PCLK_FREQ 16 r/w 0 Copyright © Bridgetek Pte Ltd Stamp date code Command DL (bulk) space available Command DL (bulk) write Reduce frame rate during complex drawing Audio playback control. 0: play, 1: pause Flash status. 0: INIT, 1: DETACHED, 2: BASIC, 3: FULL Reserved Line underrun counter Adaptive Hsync: maximum horizontal total PCLK cycles. 0 means Adaptive Hsync is disabled. Fractional PCLK 44 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Address (hex) Register Name 302618h REG_PCLK_2X 309000h 309004h 309008h 30900Ch 309010h 309014h 309018h 309024h Bit s r/ w 1 r/w REG_TRACKER REG_TRACKER_1 REG_TRACKER_2 REG_TRACKER_3 REG_TRACKER_4 REG_MEDIAFIFO_READ REG_MEDIAFIFO_WRITE REG_FLASH_SIZE 32 32 32 32 32 32 32 32 r/w r/w r/w r/w r/w r/o r/w r/o 30902Ch REG_ANIM_ACTIVE 32 r/o 30914Eh REG_PLAY_CONTROL 8 r/w Table 5-2 Overview Reset value Clearance No.: BRT#154 Description frequency/enable. Firmware sets to 08A1h at boot. 0 Core scan out 2 pixel data per system clock 0 Tracker register 0 0 Tracker register 1 0 Tracker register 2 0 Tracker register 3 0 Tracker register 4 - Media FIFO read offset 0 Media FIFO write offset - Detected flash capacity, in Mbytes - 32-bit mask of currently playing animations 0 Video playback control. 0: pause, 1: play, ffh: exit of BT817/8 Registers Note: All register addresses are 4-byte aligned. The value in the “Bits” column refers to the number of valid bits from bit 0 unless otherwise specified; other bits are reserved. 5.2 Chip ID The BT817/8 Chip ID can be read at memory location 0C0000h – 0C0003h. The reset values of these bytes are: - 0C0000h: 0C0001h: 0C0002h: 0C0003h: 08h 17h (BT817), 18h(BT818) 01h 00h Note that the Chip ID memory location is part of RAM_G, which can be over-written by the user software. A reset event defined in section 4.9.4 will bring back the Chip ID information in these memory locations. Copyright © Bridgetek Pte Ltd 45 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 6 Devices Characteristics and Ratings 6.1 Absolute Maximum Ratings The absolute maximum ratings for the BT817/8 devices are as follows. These are in accordance with the Absolute Maximum Rating System (IEC 60134). Exceeding these may cause permanent damage to the device. Parameter Value Storage Temperature -65 to +150 Floor Life (Out of Bag) At Factory Ambient 168 (IPC/JEDEC J-STD-033A MSL Level (30°C / 60% Relative Humidity) 3 Compliant)* Ambient Temperature (Power Applied) -40 to +85 VCC Supply Voltage 0 to +4 VCCIO Supply Voltage 0 to +4 DC Input Voltage -0.5 to + 5.5V Table 6-1 Absolute Maximum Ratings Unit °C Hours °C V V V * If the devices are stored out of the packaging, beyond this time limit, the devices should be baked before use. The devices should be ramped up to a temperature of +125°C and baked for up to 17 hours. 6.2 ESD and Latch-up Specifications Description Specification Human Body Mode (HBM) > ± 2kV Machine mode (MM) > ± 200V Latch-up > ± 200mA Table 6-2 ESD and Latch-Up Specifications 6.3 DC Characteristics Typical condition refers to: VCC=3.3V, VCCIO=3.3V, Ta=25 °C, unless otherwise stated Parameter VCCIO1/ VCCIO2/ VCCIO3 VCC/ VCCA Icc1 Icc2 Icc3 Icc4 Description VCCIO operating supply voltage Minimum 1.62 2.25 3.0 3.0 Typical 1.8 2.5 3.3 3.3 Maximum 1.98 2.75 3.6 3.6 Units V V V V Conditions Normal Operation - 0.2 - mA Power down mode Sleep Mode Standby Mode Normal Operation VCC operating supply voltage Power Down current Sleep current Standby current Operating current Table 6-3 0.6 mA 3.6 mA 30 mA Operating Voltage and Current Pin Group Normal Operation drive strength 1.8V 2.5V 3.3V Unit DSD1 1.2 2 2.5 mA DSD2 2.4 4 5 mA DSD3 DSD4 3.6 4.8 6 8 7.5 10 mA mA DSD1 2.4 3.8 5 mA DSD2 4.8 7.6 10 mA DSD3 7.2 11.4 15 mA DSD4 9.6 15.2 Table 6-4 Digital Output Pin Drive Strength 20 mA Pin group A: R[7:0], G[7:0], B[7:0], PCLK, HSYNC, VSYNC, DE, DISP, BACKLIGHT, CTP_RST_N, CTP_INT_N, CTP_SCL, CTP_SDA Pin group B: MOSI, MISO, GPIO0/IO2, GPIO1/IO3, INT_N, GPIO2, GPIO3, AUDIO_L, SPIM_SCK, SPIM_MOSI, SPIM_MISO, SPIM_CS_N, SPIM_IO2, SPIM_IO3 Copyright © Bridgetek Pte Ltd 46 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Parameter Voh Vol Vih Vil Vth Iin Ioz Rpu Rpd Parameter Voh Vol Vih Vil Vth Iin Ioz Rpu Rpd Parameter Voh Vol Vih Vil Vth Iin Ioz Rpu Rpd Clearance No.: BRT#154 Description Minimum Typical Maximum Units Output Voltage VCCIO-0.5 V High Output Voltage 0.4 V Low Input High 2.0 5.5 V Voltage Input Low 0.8 V Voltage Schmitt 0.22 0.3 V Hysteresis Voltage Input leakage -10 10 uA current Tri-state output -10 10 uA leakage current Pull-up resistor 42 kΩ Pull-down resistor 44 kΩ Table 6-5 Digital I/O Pin Characteristics (VCCIO = +3.3V) Conditions Ioh: refer to Table 6-4 Iol: refer to Table 6-4 Description Minimum Typical Maximum Units Output Voltage V VCCIO-0.4 High Output Voltage 0.4 V Low Input High 1.7 3.6 V Voltage Input Low 0.7 V Voltage Schmitt 0.2 0.3 V Hysteresis Voltage Input leakage -10 10 uA current Tri-state output -10 10 uA leakage current Pull-up resistor 57 kΩ Pull-down resistor 59 kΩ Table 6-6 Digital I/O Pin Characteristics (VCCIO = +2.5V) Conditions Ioh: refer to Table 6-4 Iol: refer to Table 6-4 Description Minimum Typical Maximum Units Output Voltage VCCIO-0.4 V High Output Voltage 0.4 V Low Input High 1.2 2.75 V Voltage Input Low 0.6 V Voltage Schmitt 0.17 0.3 V Hysteresis Voltage Input leakage -10 10 uA current Tri-state output -10 10 uA leakage current Pull-up resistor 90 kΩ Pull-down resistor 97 kΩ Table 6-7 Digital I/O Pin Characteristics (VCCIO = +1.8V) Conditions Ioh: refer to Table 6-4 Iol: refer to Table 6-4 - Copyright © Bridgetek Pte Ltd Vin = VCCIO or 0 Vin = VCCIO or 0 Vin = VCCIO or 0 Vin = VCCIO or 0 Vin = VCCIO or 0 Vin = VCCIO or 0 47 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Parameter Rsw-on Rsw-off Rpu Vth+ Vth- Rl Description Minimum Typical Maximum X-,X+,Y- and Y+ 6 10 Drive On 9 16 resistance X-,X+,Y- and Y+ 10 Drive Off resistance Touch sense pull 78 100 125 up resistance Touch Detection 1.59 2.04 rising-edge 0.58 0.68 threshold on XP pin Touch Detection 1.23 1.55 falling-edge 0.51 0.56 threshold on XP pin X-axis and Y-axis 200 drive load resistance Table 6-8 Touch Sense Characteristics Units Ω Ω Clearance No.: BRT#154 Conditions VCCIO=3.3V VCCIO=1.8V MΩ kΩ V V VCCIO=3.3V VCCIO=1.8V V V VCCIO=3.3V VCCIO=1.8V Ω 6.4 AC Characteristics 6.4.1 System Clock and Reset Parameter Internal Relaxation Clock Minimum Value Typical Maximum Units Trimmed frequency target - 12 - MHz Trimmed frequency accuracy ±1.2 ±3.0 Trimmed frequency variation over ±4.0 temperature and voltage Crystal Frequency 12.000 X1/X2 Capacitance 10 External clock input Frequency 12.000 Duty cycle 45 50 55 Input voltage on X1/CLK 3.3 Reset Reset pulse on PD_N (active state) 5 Table 6-9 System Clock Characteristics Copyright © Bridgetek Pte Ltd % % MHz pF MHz % V Ms 48 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 6.4.2 Clearance No.: BRT#154 SPI Interface Timing Figure 6-1 SPI Interface Timing Parameter Tsclk Tsclkl Tsclkh Tsac Tisu Tih Tzo Toz Tod Tcsnh 6.4.3 Parameter Tpclk Td Th VCCIO=1.8V VCCIO=2.5V VCCIO=3.3V Min Min Min Units Description Max Max Max SPI clock period 33.3 33.3 33.3 SPI clock low 13 13 13 duration SPI clock high 13 13 13 duration SPI access time 4 3.5 3 Input Setup 4 3.5 3 Input Hold 0 0 0 Output enable delay 16 13 Output disable delay 13 11 Output data delay 15 12 CSN hold time 0 0 0 Table 6-10 SPI Interface Timing Specifications Ns ns ns ns ns ns ns ns ns ns 11 10 11 RGB Interface Timing Description Pixel Clock period Output delay relative to PCLK rising edge (REG_PCLK_POL=0) or falling edge (REG_PCLK_POL=1). Applied for all the RGB output pins. Output hold time relative to PCLK rising edge (REG_PCLK_POL=0) or falling edge (REG_PCLK_POL=1). Applied for all the RGB output pins. Table 6-11 RGB Interface Copyright © Bridgetek Pte Ltd Min 10.4 Value Typ Max 4 0.5 Units ns Ns Ns Timing Characteristics 49 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 Figure 6-2 RGB Interface Timing Copyright © Bridgetek Pte Ltd 50 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 7 Application Examples Figure 7-1 BT817 RGB application circuit Copyright © Bridgetek Pte Ltd 51 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 Figure 7-2 BT817 LVDS application circuit Copyright © Bridgetek Pte Ltd 52 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 8 Package Parameters The BT817/8 is available in VQFN-64 package. The package dimensions, markings and solder reflow profile for all packages are described in following sections. 8.1 Part Markings 8.1.1 Top Side 64 1 BRT XXXXXXXXXX BT817Q YYWW-B Line 1 – BRT Logo Line 2 – Wafer Lot Number Line 3 – BRT Part Number Line 4 – Date Code, Revision Notes: 1. YYWW = Date Code, where YY is year and WW is week number 2. BRT part number will be either BT817Q or BT818Q as per device selected. 8.1.2 Bottom Side No markings should be placed on the bottom side. Copyright © Bridgetek Pte Ltd 53 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 8.2 VQFN-64 Package Dimensions A A1 MIN. 0.7 0.00 NOM. 0.75 0.035 MAX. 0.8 0.05 A3 b D E 0.2 0.203 0.25 0.3 9 9 J K 5.9 5.9 6 6 6.1 6.1 e 0.50 L L1 T 0.35 0.3 2.45 0.4 0.4 2.55 0.45 0.45 2.65 Figure 8-1 VQFN-64 Package Dimensions All dimensions are in millimetres (mm). Tolerance aaa/bbb/ccc/ddd/eee: 0.1. Copyright © Bridgetek Pte Ltd 54 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 8.3 Solder Reflow Profile The recommended solder reflow profile for the package is shown in Figure 8-2. Temperature, T (Degrees C) tp Tp Critical Zone: when T is in the range TL to Tp Ramp Up TL tL TS Max Ramp Down TS Min tS Preheat 25 T = 25º C to TP Time, t (seconds) Figure 8-2 BT817/8 Solder Reflow Profile The recommended values for the solder reflow profile are detailed in Figure 8-2. Values are shown for both a completely Pb free solder process (i.e. the BT817/8 is used with Pb free solder), and for a non-Pb free solder process (i.e. the BT817/8 is used with non-Pb free solder). Profile Feature Average Ramp Up Rate (Ts to Tp) Preheat - Temperature Min (Ts Min.) - Temperature Max (Ts Max.) - Time (ts Min to ts Max) Pb Free Solder Process 3°C / second Max. Non-Pb Free Solder Process 150°C 200°C 60 to 120 seconds 100°C 150°C 60 to 120 seconds 3°C / Second Max. Time Maintained Above Critical Temperature TL: 217°C 183°C 60 to 150 seconds - Temperature (TL) 60 to 150 seconds - Time (tL) Peak Temperature (Tp) 260°C 240°C Time within 5°C of actual Peak 20 to 40 seconds 20 to 40 seconds Temperature (tp) Ramp Down Rate 6°C / second Max. 6°C / second Max. Time for T= 25°C to Peak Temperature, 8 minutes Max. 6 minutes Max. Tp Table 8-1 Reflow Profile Parameter Values Copyright © Bridgetek Pte Ltd 55 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 9 Contact Information Head Quarters – Singapore Branch Office – Taipei, Taiwan Bridgetek Pte Ltd 178 Paya Lebar Road, #07-03 Singapore 409030 Tel: +65 6547 4827 Fax: +65 6841 6071 Bridgetek Pte Ltd, Taiwan Branch 2 Floor, No. 516, Sec. 1, Nei Hu Road, Nei Hu District Taipei 114 Taiwan, R.O.C. Tel: +886 (2) 8797 1330 Fax: +886 (2) 8751 9737 E-mail (Sales) E-mail (Support) E-mail (Sales) E-mail (Support) sales.apac@brtchip.com support.apac@brtchip.com sales.apac@brtchip.com support.apac@brtchip.com Branch Office - Glasgow, United Kingdom Branch Office – Vietnam Bridgetek Pte. Ltd. Unit 1, 2 Seaward Place, Centurion Business Park Glasgow G41 1HH United Kingdom Tel: +44 (0) 141 429 2777 Fax: +44 (0) 141 429 2758 Bridgetek VietNam Company Limited Lutaco Tower Building, 5th Floor, 173A Nguyen Van Troi, Ward 11, Phu Nhuan District, Ho Chi Minh City, Vietnam Tel : 08 38453222 Fax : 08 38455222 E-mail (Sales) E-mail (Support) E-mail (Sales) E-mail (Support) sales.emea@brtichip.com support.emea@brtchip.com sales.apac@brtchip.com support.apac@brtchip.com Web Site http://brtchip.com/ Distributor and Sales Representatives Please visit the Sales Network page of the Bridgetek Web site for the contact details of our distributor(s) and sales representative(s) in your country. System and equipment manufacturers and designers are responsible to ensure that their systems, and any Bridgetek Pte Ltd (BRT Chip) devices incorporated in their systems, meet all applicable safety, regulatory and system-level performance requirements. All application-related information in this document (including application descriptions, suggested Bridgetek devices and other materials) is provided for reference only. While Bridgetek has taken care to assure it is accurate, this information is subject to custo mer confirmation, and Bridgetek disclaims all liability for system designs and for any applications assistance provided by Bridge tek. Use of Bridgetek devices in life support and/or safety applications is entirely at the user’s risk, and the user agrees to defend, indemnify and hold harmless Bridgetek from any and all damages, claims, suits or expense resulting from such use. This document is subject to change without notice. No freedom to use patents or other intellectual property rights is implied by the publication of this document. Neither the whole nor any part of the information contained in, or the product described in this document, may be adapted or reproduced in any material or electronic form without the prior written consent of the copyright holder. Bridgetek Pte Ltd, 178 Paya Lebar Road, #07-03, Singapore 409030. Singapore Registered Company Number: 201542387H. Copyright © Bridgetek Pte Ltd 56 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 Appendix A – References Document References BT81X_Series_Programming_Guide AN_252 FT800 Audio Primer AN_254 FT800 Designs with Visual TFT AN_259 FT800 Example with 8-bit MCU AN_275 FT800 Example with Arduino AN_276 Audio File Conversion AN_277 FT800 Create User Defined Font AN_281 FT800 Emulator Library User Guide AN_291 FT800 Create Multi-Language Font AN_299 FT800 FT801 Internal Clock Trimming AN_303 - FT800 Image File Conversion AN_308 FT800 Example with an 8-bit MCU AN_312 FT800 Example with ARM AN_314 FT800 Advanced Techniques - Working with Bitmaps AN_318 Arduino Library for FT800 Series AN_320 FT800 Example with PIC AN_327 EVE Screen Editor Installation Guide AN_336 FT8xx - Selecting an LCD Display FT800 Series Sample Application EVE Frequently Asked Questions Acronyms and Abbreviations Terms Description ADPCM Adaptive Differential Pulse Code Modulation ASCII American Standard Code for Information Interchange ASTC Adaptive Scalable Texture Compression CTPM Capacitive Touch Panel Module CTSE Capacitive Touch Screen Engine EVE Embedded Video Engine HMI Human Machine Interfaces I2C Inter-Integrated Circuit LCD Liquid Crystal Display LED Light Emitting Diode MCU Micro Controller Unit MPU Micro Processor Unit PCM Pulse Code Modulation PLL Phased Locked Loop Copyright © Bridgetek Pte Ltd 57 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 PWM WVGA ROM SPI VQFN Clearance No.: BRT#154 Pulse Width Modulation Wide Video Graphics Array Read Only Memory Serial Peripheral Interface Very Thin Quad Flat Non-Leaded Package Copyright © Bridgetek Pte Ltd 58 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 Appendix B - List of Figures and Tables List of Figures Figure 2-1 BT817/8 Block Diagram ............................................................................................... 3 Figure 2-2 BT817/8 System Design Diagram .................................................................................. 3 Figure 3-1 Pin Configuration BT817 VQFN-64(Top View) .................................................................. 7 Figure 3-2 Pin Configuration BT818 VQFN-64 (Top View) ................................................................. 7 Figure 4-1 SPI Master and Slave in the Master Read Case .............................................................. 12 Figure 4-2 Single/Dual SPI Interface connection ........................................................................... 12 Figure 4-3 Quad SPI Interface connection .................................................................................... 13 Figure 4-4 Internal relaxation oscillator connection ....................................................................... 18 Figure 4-5 Crystal Oscillator Connection ...................................................................................... 19 Figure 4-6 External Clock Input .................................................................................................. 19 Figure 4-7 Flash Interface States ................................................................................................ 25 Figure 4-8 RGB Timing Waveforms.............................................................................................. 28 Figure 4-9 Resistive Touch Screen Connection .............................................................................. 33 Figure 4-10 Touch Screen Connection ......................................................................................... 34 Figure 4-11 Touch Host Mode Connections ................................................................................... 36 Figure 4-12 Power State Transition ............................................................................................. 38 Figure 6-1 SPI Interface Timing .................................................................................................. 49 Figure 6-2 RGB Interface Timing ................................................................................................. 50 Figure 7-1 BT817 RGB application circuit ..................................................................................... 51 Figure 7-2 BT817 LVDS application circuit .................................................................................... 52 Figure 8-1 VQFN-64 Package Dimensions .................................................................................... 54 Figure 8-2 BT817/8 Solder Reflow Profile ..................................................................................... 55 List of Tables Table 3-1 BT817/8 Pin Description .............................................................................................. 10 Table 4-1 QSPI Channel Selection ............................................................................................... 11 Table 4-2 Host Memory Read Transaction .................................................................................... 13 Table 4-3 Host Memory Write Transaction .................................................................................... 14 Table 4-4 Host Command Transaction ......................................................................................... 14 Table 4-5 Host Command List .................................................................................................... 17 Table 4-6 Interrupt Flags bit assignment ..................................................................................... 18 Table 4-7 Font Table Format ...................................................................................................... 21 Table 4-8 ROM Font Table .......................................................................................................... 21 Table 4-9 ROM font ASCII character width in pixels ....................................................................... 24 Table 4-10 ROM Font Extended ASCII Characters ......................................................................... 24 Table 4-11 RGB PCLK Frequency in EXTSYNC mode ...................................................................... 26 Table 4-12 RGB PCLK Frequency in Pass-Through mode ................................................................ 26 Table 4-13 REG_SWIZZLE RGB Pins Mapping ............................................................................... 27 Copyright © Bridgetek Pte Ltd 59 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 Table 4-14 Registers for RGB Horizontal and Vertical Timings ......................................................... 27 Table 4-15 Display mode ........................................................................................................... 29 Table 4-16 Output Drive Current Selection ................................................................................... 29 Table 4-17 Sound Effect ............................................................................................................ 31 Table 4-18 MIDI Note Effect ....................................................................................................... 32 Table 4-19 Resistive Touch Controller Operating Mode .................................................................. 33 Table 4-20 Capacitive Touch Controller Operating Mode ................................................................ 34 Table 4-21 Registers for Touch Host Mode .................................................................................. 36 Table 4-22 Power Supply ........................................................................................................... 38 Table 4-23 Pin Status ................................................................................................................ 40 Table 5-1 BT817/8 Memory Map ................................................................................................. 41 Table 5-2 Overview of BT817/8 Registers .................................................................................... 45 Table 6-1 Absolute Maximum Ratings .......................................................................................... 46 Table 6-2 ESD and Latch-Up Specifications .................................................................................. 46 Table 6-3 Operating Voltage and Current ..................................................................................... 46 Table 6-4 Digital Output Pin Drive Strength.................................................................................. 46 Table 6-5 Digital I/O Pin Characteristics (VCCIO = +3.3V) ............................................................. 47 Table 6-6 Digital I/O Pin Characteristics (VCCIO = +2.5V) ............................................................. 47 Table 6-7 Digital I/O Pin Characteristics (VCCIO = +1.8V) ............................................................. 47 Table 6-8 Touch Sense Characteristics ........................................................................................ 48 Table 6-9 System Clock Characteristics ....................................................................................... 48 Table 6-10 SPI Interface Timing Specifications ............................................................................. 49 Table 6-11 RGB Interface Timing Characteristics .......................................................................... 49 Table 8-1 Reflow Profile Parameter Values ................................................................................... 55 Copyright © Bridgetek Pte Ltd 60 BT817/8 Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000302 Clearance No.: BRT#154 Appendix C - Revision History Document Title: BT817/8 Advanced Embedded Video Engine Datasheet Document Reference No.: BRT_000302 Clearance No.: BRT#154 Product Page: http://brtchip.com/product Document Feedback: Send Feedback Revision Changes Date 1.0 Initial Release 25-08-2020 Copyright © Bridgetek Pte Ltd 61
BT817Q-R 价格&库存
很抱歉,暂时无法提供与“BT817Q-R”相匹配的价格&库存,您可以联系我们找货
