FT51A-EVM
FT51A-EVM
    BRIDGETEK
    FT51A EVAL BRD
FT51A-EVM 数据手册
FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 Future Technology Devices International Datasheet FT51A-EVM Development Module FT51A-EVM is an FT51A development module with the following features: display, heart-rate monitor, temperature sensor and force sensitive resistor. 1 Introduction The FT51A-EVM is a development module for FTDI’s FT51AQ, one of the devices from FTDI’s range of 8-bit microcontrollers with USB interface bridging features integrated. FT51A is a MCU which includes the following features: USB client and USB hub interfaces, 8051 core, 8-bit ADC, UART, SPI, I2C, 245 FIFO and PWM. The FT51A-EVM demonstrates the FT51A series I2C and SPI interfaces, the ADC input, PWM and GPIO features. It contains a 28 pin header which allows easy access to all the FT51AQ’s IO pins, as well as the debug and reset pins. This module also comes preloaded with the FT51A-EVM firmware that allows users to use all the features of the module without developing firmware. In addition to the features listed in the FT51A datasheet, the FT51A-EVM has the following features:  20 X 2 characters, LCD display, with I2C interface and RGB backlight.  Heart-Rate Monitor with filtered and amplified analogue output  Force sensitive resistor  SPI temperature sensor  Push buttons controls and LED indicator  Interface footprints to allow for communication with FTDI’s FT8xx modules and TTL-232R cables  Upstream and downstream USB ports which allows for direct connection cascading.  Debugger interface header used for debugging and programming the FT51AQ. Designer for operation with FTPD-1. See FTPD-1 datasheet for details about this module.  Onboard jumper for configuring the module to be in self pow ered or USB powered. 1.1 Features The FT51A-EVM is fitted with a FT51AQ; many of the features of the FT51A series can be utilized with this module. For a full list of the FT51A series features please see the FT51A datasheet which can be found by clicking here. N either the whole nor any part of the information c ontained in, or the produc t des c ribed in this manual, may be adapted or reproduc ed in any material or elec tronic form without the prior written c ons ent of the c opyright holder. T his produc t and its doc umentation are s upplied on an as - is basis and no warranty as to their s uitability for any partic ular purpos e is either made or implied. Future T ec hnology D evices I nternational L td will not ac c ept any c laim for damages hows oever arising as a res ult of u s e or failure of this produc t. Y our s tatutory rights are n ot affec ted. T his produc t or any variant of it is not intended for us e in any medic al appliance, device or s ystem in whic h the failure of the produc t might reas onably be expected to res ult in pers onal in jury. T his doc ument provides preliminary information that may be s ubject to c hange without notice. N o freedom to us e patents or other intellectual property rights is implied by the publication of this doc ument. Future T echnology D evic es I nternational L td, U ni t 1 , 2 Seaward P lac e, C enturion Business P ark, G la sgow G 4 1 1HH U nited Kingdom. Sc otland Registered C ompany N umber: SC 1 3 6 6 4 0 Copyright © 2015 Future Technology Devices International Limited 1 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 Table of Contents 1 Introduction ................................................................. 1 1.1 Features ................................................................................ 1 2 Driver Support .............................................................. 3 3 Ordering Information .................................................... 4 4 FT51A-EVM Signals and Configurations .......................... 5 4.1 FT51A-EVM Pin Out ................................................................ 5 4.2 Connector Descriptions .......................................................... 6 4.3 I/O Pin Feature Options ........................................................10 5 Module Configurations ................................................ 11 5.1 Jumper Configuration Options ...............................................11 6 Using Preloaded Firmware........................................... 12 7 Programming Firmware to the MTP Memory................. 13 8 Module Dimensions ..................................................... 14 9 UMFT51AA Module Circuit Schematic ........................... 15 10 Contact Information .................................................... 20 Appendix A – References ................................................. 18 Document References ...................................................................18 Acronyms and Abbreviations .........................................................18 Appendix B – List of Figures and Tables............................ 19 List of Figures ...............................................................................19 List of Tables ................................................................................19 Appendix C – Revision History.......................................... 20 Copyright © 2015 Future Technology Devices International Limited 2 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 2 Driver Support Driver support for the FT51A USB Device Firmware Updater (DFU) is available as part of the FT51A SDK and is available for the following OS:  Windows 10 32,64-bit  Windows 8.1 32,64-bit  Windows 8 32,64-bit  Windows 7 32,64-bit The DFU driver files can be found at the following PC location once the FT51A SDK has been installed: C:\Users\Username\Documents\FTDI\FT51A_SDK\version\drivers NOTE: “username” will be different for each user that logs into a PC. Copyright © 2015 Future Technology Devices International Limited 3 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 3 Ordering Information Module Code Utilised IC Code Description UMFT51A-EVM FT51AQ FT51A evaluation platform Other modules in the FT51A range: Module Code Utilised IC Code Description UMFT51AA-01 FT51AQ 8051 compatibility module. Copyright © 2015 Future Technology Devices International Limited 4 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 4 FT51A-EVM Signals and Configurations 4.1 FT51A-EVM Pin Out Figure 4.1 – Module Pin Out Figure 4.1 illustrates the signals available on the header pins. Copyright © 2015 Future Technology Devices International Limited 5 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 4.2 Connector Descriptions Pin No. Name Type CN1-1 and CN1-4 NC CN1-2 VCC5V Power 5 volt power input. (Protected by zenor diode.) CN1-3 RESET# Signal Active low reset CN1-5 DBG Signal Debugger data line, single line half-duplex UART. CN1-6 GND Ground 0 volt ground. Not Conected Description Floating pin. Table 4.1 – Debugger Port Pin Out Description Pin No. Name Type Description CN2-1 VCC Power 5 volt power input. CN2-2 GND Ground 0 volt ground. Table 4.2 – Power Port Pin Out Description Pin No. Name Type Description CN3-1 VBUS Power 5 volt power output. CN3-2 DM Signal USB Data - to downstream device CN3-3 DP Signal USB Data + to downstream device CN3-4 GND Ground 0 volt ground. Table 4.3 – Downstream USB Port Pin Out Description Pin No. Name Type Description CN4-1 GND Ground 0 volt ground. CN4-2 UART_RTS# Signal UART Ready to Send output. Active low. CN4-3 NC NC No Connect CN4-4 UART_RX Signal UART RX Data input. CN4-5 UART_TX Signal UART TX Data output. CN4-6 UART_CTS# Signal UART Clear to Send input. Active low. Table 4.4 – UART Port Pin Out Description Note: CN4 is not fitted by default. Copyright © 2015 Future Technology Devices International Limited 6 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 Pin No. Name Type Description CN5-1 VBUS Power CN5-2 DM Signal USB Data - from upstream device CN5-3 DP Signal USB Data + from upstream device CN5-4 GND Ground 0 volt ground. 5 volt power input. To enable bus power mode close JP1 Table 4.5 – Upstream USB Port Pin Out Description Pin No. Name Type Description CN6-1 VCC3V3 Power 3.3 volt power output CN6-2 VCC5V Power 5 volt power output CN6-3 DBG Signal Debugger interface pin, bi-directional, open-drain Input/Output output with on-board pull-up resistor CN6-4 RST Signal Input FT51A reset pin, active high CN6-5 AIO0 I/O Signals JP4 1-2 short: Unused analog IO pin JP4 2-3 short: No connection CN6-6 SW1 Signal Input (DIO0) Active low when SW1 pressed. CN6-7 AIO1 I/O Signals Unused analog IO pin CN6-8 FSR_LED Signal Output (DIO1) Drive the LED indicating FSR pressure. CN6-9 AIO2 I/O Signals Unused analog IO pin CN6-10 DIO2 Signal Output When connecting the FT51A-EVM to a FTDI FT800, DIO2 can be used as the SPI master CS# net. CN6-11 AIO3 I/O Signals Unused analog IO pin CN6-12 SPI MOSI Signal output (DIO3) Master Out, Slave In SPI signal CN6-13 AIO4 I/O Signals Unused analog IO pin CN6-14 SPI MISO Signal input (DIO4) Master In, Slave Out SPI signal CN6-15 AIO5 I/O Signals Unused analog IO pin CN6-16 SPI SCLK Signal output (DIO5) SPI clock output CN6-17 AIO6 I/O Signals Unused analog IO pin Copyright © 2015 Future Technology Devices International Limited 7 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 Pin No. Name Type Description CN6-18 DIO6 Signal Output CN6-19 SW3 Signal Input (AIO7) Active low when SW3 pressed. CN6-20 SW2 Signal Input (DIO7) Active low when SW2 pressed. CN6-21 SW4 Signal Input (AIO8) Active low when SW4 pressed. CN6-22 LCD_RST# Signal Output CN6-23 AIO9 I/O Signals Unused analog IO pin CN6-24 DIO9 Signal I/O Unused digital IO. CN6-25 AIO10 I/O Signals Can be used as SPI CS# to temperature sensor, can be over written by jumper JP2. (DIO8) Controls the reset feature of the LCD module JP3 1-2 short: Unused analog IO pin JP3 2-3 short: No connection CN6-26 UART RTS# Output signal (DIO10) UART Ready To Send signal. Active low. CN6-27 HB_LED Signal Output CN6-28 UART RX Signal Input (DIO11) UART data receive signal CN6-29 LCD_PWM (R ) Signal Output (AIO12) control the LCD backlight red signal CN6-30 UART CTS# Signal Input CN6-31 LCD_PWM (G) Signal Output CN6-32 I2C_SCL Signal Output CN6-33 LCD_PWM (B) Signal Output CN6-34 I2C_SDA Signal IO CN6-35 VBUS_PWR Signal Input (AIO15) Indicates if power is present on USB bus CN6-36 UART TX Signal (DIO15) UART TX signal output. Active low. CN6-37, CN6-38 GND Ground 0V Ground CN6-39, CN6-40 NC - No connection (AIO11) Used to drive the on board heartbeat indicator LED (DIO12) UART clear to send signal input. Active low. (AIO13) control the LCD backlight gree n signal (DIO13) I2C clock output. Used to communicate with the LCD display (AIO14) control the LCD backlight blue signal (DIO14) Bidirectional I2C data line. Used to communicate with the LCD display Table 4.6 – Module IO Pin Out Description Note: The term “Únused” means the IO pin is not used by the on-board electronics. These IOs are free to be used by user’s add-on circuit. Copyright © 2015 Future Technology Devices International Limited 8 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 Pin No. Name Type Description CN7-1 SPI_SCLK Signal SPI CLK output CN7-2 SPI_MOSI Signal SPI Master Output Slave Input. Output signal CN7-3 SPI_MISO Signal SPI Master Input Slave Output. Input signal CN7-4 CS# Signal Active low EVE chip select signal output CN7-5 INT# Signal Active low EVE interrupt signal input CN7-6 PD# Signal Active low EVE power down signal output CN7-7 5V Power 5V power output CN7-8 NC - No connection CN7-9 GND GND Ground 0 volts. CN7-10 GND GND Ground 0 volts. Table 4.7 – EVE/SPI Pin Out Description Note: CN7 is not fitted by default. Copyright © 2015 Future Technology Devices International Limited 9 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 4.3 I/O Pin Feature Options The following features can be configured using the FT51A’s multiplexer to bring signal to the available pins. FT51A IO Signal Option Available On Pin Description GPIO DIO0-15 and AIO0-15 ADC AIO0-15 8-bit analog to digital converter UART DIO0-15 UART interface. Data rates up to 3 Mbaud. SPI Master DIO0-15 SPI master interface. Clock frequency up to 24MHz SPI Slave DIO0-15 SPI slave interface 245 FIFO DIO0-15 8 bit parallel data interface with handshake. Data rates up to 7MB/s. 2 I C Master DIO0-15 I2C master interface. Data rates up to 3.4Mb/s I2C Slave DIO0-15 I2C slave interface PWM DIO0-15 and AIO0-15 BCD Detect DIO0-15 and AIO0-15 General purpose IO Pulse Width Modulation output. Indicates a dedicated charger port has been detected on upstream USB port. Table 4.8 – I/O Signal Options Copyright © 2015 Future Technology Devices International Limited 10 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 5 Module Configurations 5.1 Jumper Configuration Options Solder Setting Status Description JP1 2-3 NonDefault Self-Powered mode. This setting removes the connection between VBUS and VCC5V. For self-powered operation 5V power is received from CN2-1. JP1 1-2 Default Setting Status Description JP2 1-2 NonDefault Disable the temperature sensor’s SPI outputs. JP2 2-3 Default Allow the FT51A to control the CS# line of the temperature sensor. Table 5.2 – Jumper JP2 Modes Setting Status Description JP3 1-2 NonDefault Disable the heart rate monitor. JP3 2-3 Default Allow the FT51A to monitor the heart rate sensor output. Table 5.3 – Jumper JP3 Modes Setting Status Description JP4 1-2 NonDefault Disable the force sensitive resistor. JP4 2-3 Default Link No. Solder Link No. Solder Link No. Solder Link No. Bus-Powered mode. This setting creates a connection between VBUS and VCC5V. For bus-powered operations 5V power will be outputted from CN21 when the module is connected to an upstream USB port. Table 5.1 – Jumper JP1 Modes Allow the FT51A to monitor the force sensitive resistor. Table 5.4 – Jumper JP4 Modes Copyright © 2015 Future Technology Devices International Limited 11 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 6 Using Preloaded Firmware The preloaded firmware of the FT51A_EVM evaluation module will display sensor da ta on the LCD panel. The data which is displayed is from the temperature sensor (U4). This firmware may be replaced either via the debugger / programmer module FTPD-1 using supplied code from FTDI or with the users own application. Alternatively as the default firmware includes DFU (Device Firmware Update) on the upstream USB port the firmware may be reprogrammed over USB using the DFU. Copyright © 2015 Future Technology Devices International Limited 12 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 7 Programming Firmware to the MTP Memory The FT51AQ of the FT51A-EVM is programmed with the FT51A-EVM firmware which allows users to interface with the temperature sensor. For users wishing to apply their own code or other supplied examples, the FT51AQ can be programmed using the FTPD-1 or over USB using DFU. Connector CN-1 is used as a dedicated port that interfaces w ith the FTPD-1. A list of available examples (at time of writing) is shown below and source code can be found in ‘C:\Users\Username\Documents\FTDI\FT51A_SDK\version\examples’ after installing the FT51A SDK:  AN_344_FT51A_DFU_Sample  AN_345 FT51A Keyboard Sample  AN_346 FT51A Mouse Sample  AN_347 FT51A Test and Measurement Sample  AN_348 FT51A FT800 Sensors Sample  AN_349 FT51A FT800 Spaced Invaders Sample  AN_351 FT51A Compatibility Module  AN_354 FT51A Standalone Demo Application Copyright © 2015 Future Technology Devices International Limited 13 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 8 Module Dimensions Figure 8.1 – FT51A-EVM Module Dimensions All dimensions are given in millimetres. The height of the assembled module(including the rubber standing) is 15mm. The FT51A-EVM module exclusively uses lead free components, and is fully compliant with European Union directive 2002/95/EC. Copyright © 2015 Future Technology Devices International Limited 14 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 9 UMFT51AA Module Circuit Schematic Copyright © 2015 Future Technology Devices International Limited 15 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 Copyright © 2015 Future Technology Devices International Limited C learance N o.: FT DI# 4 7 8 16 10K R27 10K R23 SW2 SW1 Copyright © 2015 Future Technology Devices International Limited GND C27 0.1uF R19 47K GND LCD_PWM_R LCD_PWM_G LCD_PWM_B LCD_RST# I2C_SCL I2C_SDA GND GND 4.7uF C22 R18 10K GND GND C24 0.1uF 470R 470R 470R GND R32 10K 4.7uF C23 GND C26 1uF 9 10 11 12 1uF VDD GND CT INT 1 2 3 4 5 6 7 8 R21 47K GND C25 ADT7310 SCLK DOUT DIN CS U4 VCC3V3 1 2 3 4 MCP6002 SPI_SCLK SPI_MISO SPI_MOSI SPI_CS# GND R29 R30 R31 1K 1K 1K GND R33 R34 R35 3 1 680K 0.1uF VCC3V3 R15 U3A 2 R20 33K VCC3V3 C21 0.1uF C18 GND LCD A K-R K-G K-B RST SCL SDA VSS VDD VOUT C1+ C1- LCD1 8 7 6 5 R25 10K VCC3V3 VCC3V3 GND R22 33K 5 U3B 6 R16 C19 R26 10K TS_CT TS_INT MCP6002 7 680K 0.1uF HR_Out FSR_Out GND R28 10K R24 FSR SPI_SCLK SPI_MISO SPI_MOSI SPI_CS# LCD_RST# I2C_SCL I2C_SDA LCD_PWM_R LCD_PWM_G LCD_PWM_B SW1 SW2 FSR_LED HB_LED HR_Out FSR_Out FSR_Out HB_LED VCC3V3 SPI_SCLK SPI_MISO SPI_MOSI SPI_CS# LCD_RST# I2C_SCL I2C_SDA LCD_PWM_R LCD_PWM_G LCD_PWM_B SW1 SW2 FSR_LED HB_LED HR_Out LED2 Blue_LED R13 1K VCC3V3 FSR_LED LED3 Blue_LED R14 1K VCC3V3 D oc ument Reference N o.: FT _001140 VCC3V3 SW2 SW1 2 3 1 D_TSL260R-LF VDD OUT GND R17 510R D1 GND D2 IR-LED VCC3V3 GND C20 4.7uF/N.F. VCC3V3 VCC3V3 8 4 VCC3V3 FT51A-EVM Development Module Datasheet Version 1.0 C learance N o.: FT DI# 4 7 8 17 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 Copyright © 2015 Future Technology Devices International Limited C learance N o.: FT DI# 4 7 8 18 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 Figure 9.1 – Module Circuit Schematic Copyright © 2015 Future Technology Devices International Limited 19 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 10 Contact Information Head Office – Glasgow, UK Branch Office –Tigard, Oregon, USA Unit 1, 2 Seaward Place, Centurion Business Park Glasgow G41 1HH United Kingdom Tel: +44 (0) 141 429 2777 Fax: +44 (0) 141 429 2758 7130 SW Fir Loop Tigard, OR 97223 USA Tel: +1 (503) 547 0988 Fax: +1 (503) 547 0987 E-mail (Sales) E-mail (Support) E-mail (General Enquiries) E-Mail (Sales) E-Mail (Support) E-Mail (General Enquiries) sales1@ftdichip.com support1@ftdichip.com admin1@ftdichip.com Branch Office – Taipei, Taiwan 2F, No. 516, Sec. 1, NeiHu Road Taipei 114 Taiwan , R.O.C. Tel: +886 (0) 2 8797 1330 Fax: +886 (0) 2 8751 9737 E-mail (Sales) E-mail (Support) E-mail (General Enquiries) tw.sales1@ftdichip.com tw.support1@ftdichip.com tw.admin1@ftdichip.com us.sales@ftdichip.com us.support@ftdichip.com us.admin@ftdichip.com Branch Office – Shanghai, China Room 1103, No. 666 West Huaihai Road, Shanghai, 200052 C hina Tel: +86 (0)21 6235 1596 Fax: +86 (0)21 6235 1595 E-mail (Sales) E-mail (Support) E-mail (General Enquiries) cn.sales@ftdichip.com cn.support@ftdichip.com cn.admin@ftdichip.com Web Site http://ftdichip.com Distributor and Sales Representatives Please visit the Sales Network page of the FTDI Web site for the contact details of our distributor(s) and sales representative(s) in your country. Sys tem and equipment manufacturers and des igners are responsible to ens ure that their s ystems, and any Future T echnology D evic es I nternational L td (FTDI) devices incorporated in their s ys tems , meet all applic able s afety, regulatory and s ys tem - level performanc e requirements. A ll application-related information in this doc ument (inc luding application descriptions, s uggested FTD I devices and other materials ) is provided for referenc e only. While FT DI has taken c are to as s ure it is ac c urate, this information is s ubjec t to c us tomer c onfirmation, and FT DI disclaims all liability for s ys tem des igns and for any applic ations as s is tanc e provided by FT D I . U s e of FT D I devic es in life s upport and/or s afety applic ations is entirely at the us er’s ris k, and the us er agrees to defend, indemnify a nd hold harmles s FTDI from any and all damages , c laims, s uits or expense resulting from s uc h us e. T his document is s ubject to c hange without notic e. N o freedom to us e patents or other intellectual property rights is implied by the public ation of this doc ument. N eith er the whole nor any part of the information c ontained in, or the produc t des cribed in this document, may be adapted or reproduc ed in any mate rial or elec tronic form without the prior written c ons ent of the c opyright holder. Future T ec hnology D evic es I nternational L td, U n it 1 , 2 Seaward P lac e, C enturion Busines s P ark, G las gow G 4 1 1 H H , U nited Kingdom. Sc otland Regis tered C ompany N umber: SC 1 3 6 6 4 0 Copyright © 2015 Future Technology Devices International Limited 20 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 Appendix A – References Document References DS_FT51A – FT51A datasheet DS_FTPD-1 – FT51A programmer module AN_289 – FT51A Programming Guide Acronyms and Abbreviations Terms Description DFU Device Firmware Update EVE Embedded Video Engine I2C Inter integrated Circuit LCD Liquid Crystal Display LED Light Emitting Diode MCU Micro Controller Unit MTP Multiple Time Programmable USB Universal Serial Bus Copyright © 2015 Future Technology Devices International Limited 18 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 Appendix B – List of Figures and Tables List of Figures Figure 4.1 – Module Pin Out .................................................................................................................. 5 Figure 6.1 – FT51A-EVM Module Dimensions......................................................................................... 14 Figure 7.1 – Module Circuit Schematic .................................................................................................. 19 List of Tables Table 4.1 – Debugger Port Pin Out Description........................................................................................ 6 Table 4.2 – Power Port Pin Out Description ............................................................................................. 6 Table 4.3 – Downstream USB Port Pin Out Description ............................................................................ 6 Table 4.4 – UART Port Pin Out Description .............................................................................................. 6 Table 4.5 – Upstream USB Port Pin Out Description ................................................................................ 7 Table 4.6 – Module IO Pin Out Description .............................................................................................. 8 Table 4.7 – EVE/SPI Pin Out Description ................................................................................................. 9 Table 4.8 – I/O Signal Options.............................................................................................................. 10 Table 5.1 – Jumper JP1 Modes.............................................................................................................. 11 Table 5.2 – Jumper JP2 Modes.............................................................................................................. 11 Table 5.3 – Jumper JP3 Modes.............................................................................................................. 11 Table 5.4 – Jumper JP4 Modes.............................................................................................................. 11 Copyright © 2015 Future Technology Devices International Limited 19 FT51A-EVM Development Module Datasheet Version 1.0 D oc ument Reference N o.: FT _001140 C learance N o.: FT DI# 4 7 8 Appendix C – Revision History Document Title: FT51A-EVM Development Module Datasheet Document Reference No.: FT_001140 Clearance No.: FTDI# 478 Product Page: http://www.ftdichip.com Document Feedback: Send Feedback Revision Version 1.0 Changes Initial Release Date 2015-11-18 Copyright © 2015 Future Technology Devices International Limited 20
FT51A-EVM 价格&库存
很抱歉,暂时无法提供与“FT51A-EVM”相匹配的价格&库存,您可以联系我们找货
